VWVortex.com - Mk1 Audi TT 225 Clutch suggestions and part numbers
    Results 1 to 9 of 9
    Thread: Mk1 Audi TT 225 Clutch suggestions and part numbers
    1. Member Mykal's Avatar
      Sep 7th, 2012
      Florida
      2001 Audi TT
      09-29-2012 09:08 PM #1
      I recently purchased a 2001 Audi TT Quattro 1.8t 225
      My clutch is slipping in 6th.
      I plan on having it chipped in the next month or two. Other then an intake down the road that will be it for power adders for now.
      Im looking for a clutch and flywheel.
      Im open to OEM or after market. I prefer to stay with a dual mass flywheel. A little lighter would be ok.
      From reading some of the posts I searched for, I found that Sachs is the OEM manufacturer for the clutch and fly wheel. Anyone have part numbers or links to a reputable vendor?
      I checked RockAuto but Im not sure which one I need exactly.
      Any help would be appreciated. Im new to this world. Ive always been a Jeep guy.
      Please accept my donation as payment for your time.
      (Not my car or girl)
    2. Member Mykal's Avatar
      Sep 7th, 2012
      Florida
      2001 Audi TT
      10-05-2012 09:50 PM #2
      Nothin?
      Aug 12th, 2010
      Dallas, TX
      2003 Audi TT
      10-05-2012 11:58 PM #3
      I'm in the market for a clutch too. Subscribed.
    4. 10-06-2012 09:49 AM #4
      Sachs Power unit. Running 300awtq for over 30,000 miles on it with out any issues.
      http://www.fourseasontuning.com/prod...02.FST240SBLFW
    5. Banned
      Jul 29th, 2012
      10-06-2012 04:16 PM #5
      HomeAudi®TT - Mk1 8NDrivetrainSachs / OEM ClutchValeo - Single mass Clutch & Flywheel conversion kit - 240mm - For Mk4 GTI 337, 20th AE, Jetta GLI 1.8t, TT Quattro 6-speed
      View larger image
      CODE: 52405615
      List price: $1,227.89
      Price: $729.99
      You save: $497.90 (41%)
      -41%
      Enter Year / Model / Engine code / Transmission :
      Enter VIN:
      Quantity:
      Add to wish list
      DescriptionSend to friendReviews
      Quality Valeo clutch and flywheel conversion kit for all Mk4 6-speed 02M 1.8t models that use a 240mm flywheel. A great quality, and inexpensive way to get rid of that dual-mass set up that these cars come with from the factory *Includes clutch slave / release, flywheel, clutch kit, and flywheel bolts. Some cars may develop some noise at idle with a single mass flywheel. Although this is not typical unless a lighter weight aluminum flywheel us used, it can happen with this kit and it will not hurt anything.
      Fits the following vehicles:
      -Mk4 GTI 337 / 20th AE, 1.8t 6-speed
      -New Beetle Turbo S, 1.8t 6-speed
      TT Quattro, 1.8t 6-speed
      *please note, image used for example only.
      http://www.ngpracing.com/store/index...roduct_id=6388
      or email me can help out WhanAB@gmail.com
    6. Member
      Oct 18th, 2007
      2002 Audi TT
      10-06-2012 05:17 PM #6
      LUK is also an OEM for your car. I don't believe you'll find a lighter dual mass flywheel than what OEM provides (IIRC it's around 22 - 23 pounds).
      Look @ :
      http://www.mjmautohaus.com/catalog/p...oducts_id=4150
      Which is good because it comes with the alignment tool and replacement slave cylinder/ throwout bearing.
      And:
      http://www.mjmautohaus.com/catalog/p...roducts_id=865
      Feb 6th, 2012
      Baltimore, MD
      10-06-2012 10:34 PM #7
      If you want to keep the dual mass flywheel, and I HIGHLY recommend it unless you want your car to sound like a rock tumbler at idle... the Southbend Stage 2 clutch/pressure plate is 2x higher friction material with stock pedal feel, I couldn't find any others that can be used with the DMF and still offer a little better grip... would be fine for a tuned car but not a BT
      Not recommending this seller but he has a great break down of the different SB clutches available on the MK1 Audi TT no one else seems to have. Should go with a Daily or Endurance Stage 2.
      http://www.horsepowerfreaks.com/part.../3935//Audi/TT
    8. Member Mykal's Avatar
      Sep 7th, 2012
      Florida
      2001 Audi TT
      11-17-2012 11:29 AM #8
      Thanks for the replies. Any others?
      Ill be ordering one soon.
    9. Banned
      Jul 29th, 2012
      11-17-2012 01:35 PM #9
      Quote Originally Posted by Mykal View Post
      http://www.dxdracingclutches.com/html/tt.html
      the daily or first one email me whanab@gmail.com
