VWVortex.com - It's not an LTD... it's not a Roadmaster... it's a Suburban! Now tell me about them!
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 61
    Thread: It's not an LTD... it's not a Roadmaster... it's a Suburban! Now tell me about them!
    1. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      Please See Signature.
      09-30-2012 03:38 AM #1
      A 1988 Suburban, to be exact. 101k miles, 350 (5.7L) V8. Apparently it's an '88, but it's carb'd... which contradicts what Wikipedia says, as that in '86-'87 GM switched to the TBI?
      Learn me about this generation of Suburbans! The interior in this one is immaculate, and the exterior has absolutely zero rust. MPGs are going to be bullocks, but if I can do a few things to squeeze out 3-4mpg that'd be great (The last thing that would make this truck PERFECT would be if it were the 6.2 Diesel!). I know for a fact that I will be upping the tire size 1-2 (but not raising the height) sizes - is the speedometer adjustable to compensate? I don't know what gears the rear end has and I don't know if it's the three or four speed transmission.
      The A/C also doesn't work, which is rightfully so as I'd need to convert it to R134 anyway. How much would the conversion (compressor, lines, any other defunct part) run me if I did the work myself (minus evac/recharge)?
      The motor definitely needs a full tune up (plugs, wires, cap, rotor, oil, filters... everything), and I'm even looking into seeing how much it would cost to swap in a 6.2 diesel. The car will be 25 years old, officially in January of 2013, so there will be no more emissions inspection for it. I'm thinking catless pipes with resonators? Helping the flow should help mileage 1 or 2, in addition to some headers. What about adjusting the timing with the addition to a higher octane? What about a whole new 350 TBI?
      So... tell me, what are the good sides and bad sides to this generation of Suburban? What should I do to the motor knowing it's been sitting a while, besides the obvious tune up? What can I do to squeeze a few single-digit MPGs out of it? Or power, even? Rear end? What else should I do to this tank, while keeping in mind that it is going to be my hauler/grocery-getter/cruiser (GTI for all trips over 5 miles )?
      Here's a few pictures for your troubles. I take delivery on Monday.
      5.3 LS-Swapped '87 Volvo 740 | '87 Crown Vic | '90 Grand Marquis | '98 Volvo V70
    2. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      09-30-2012 03:49 AM #2
      "I owe it to myself, and to my choir students, to not be upset about barns."
    3. Member personman's Avatar
      Sep 24th, 2008
      TX
      03 Golf, 15 CX-5
      09-30-2012 03:49 AM #3
      If it's an 88 it should be TBI. Look for an adapter plate or an aftermarket intake manifold.
      My guess is it has a 700R4, which is a 4 speed transmission. Increasing tire size while trying to get more MPGs sounds very contradictory.
      A/C should be easy - I'd guess less than $500.
      Motor swap is probably not worth it, unless the motor that's in the truck is just too tired.
    4. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 03:56 AM #4
      Doesn't load for me?
      Quote Originally Posted by personman View Post
      It very well could be TBI, and now that I've looked on Google, it appears that it is. Derp on my part.
      As far as increasing tire size - increasing the tire size (assuming it's 3.73 gears and not 3.41, where it won't tire out the transmission) should increase MPGs slightly by having a slightly lower RPM at speed, no?
      Good to hear about A/C, hope it's somewhere under $400 .
      And I was mostly kidding about a motor swap, unless a crate 350 TBI is cheaper (or close enough to) than the work it needs.
    5. Member personman's Avatar
      Sep 24th, 2008
      TX
      03 Golf, 15 CX-5
      09-30-2012 04:01 AM #5
      Quote Originally Posted by mm3 View Post
      Wait... did suburbans of that vintage have front and rear a/c? If so, it might be a bit more expensive.
    6. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      09-30-2012 04:04 AM #6
      Really? odd.. ok, this one is is same but just page by page.
      http://www.superchevy.com/technical/..._engine_build/
      As far as maximizing fuel economy.... WHY DID YOU BUY A 25 YEAR OLD SUBURBAN IS YOU CARE ABOUT FUEL ECONOMY?!?!?!?!?!?!?
      Sorry.... just had to get that out.
      It does look like a clean example- and these are tough vehicles (as long as you keep the rust out of the floors and rocker panels).
      2wd or 4wd?
    7. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 04:25 AM #7
      Yes, it has front and rear. But I'm content with just having the front A/C work.
      2wd or 4wd?
      Got it. Had to load it in Internet Explorer, Chrome didn't like it o_O.
      And @ fuel economy. I'm not saying that "zomg I must have 25mpg! Halp me get thar!" by any means , just wondering what little odds and ends I can do as every extra mile per gallon will soften the blow on my wallet .
      And yep yep- the complete lack of rust anywhere on the vehicle was the hook for me to buy it, my grandfather had an '84 which he ended up giving away in '00 because the rust had eaten through the frame . His was baby blue, but had all the fancy options that this one has. Should've seen the nostalgia hit him hard when I showed him the pictures of it.
      It's 2WD .
    8. Member ABATurbo's Avatar
      Feb 10th, 2010
      2015 GTI
      09-30-2012 04:30 AM #8
      No. The bigger tires will cover more distance per revolution, but the engine is working harder to turn the wheels now that they have a larger diameter. This means you will be opening the throttle slightly farther at any given speed, which uses more gas.
      If you meant two sizes wider, then I'm not sure what effect it would have on gas mileage.
    9. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 04:37 AM #9
      Quote Originally Posted by slippinclutch View Post
      Gotcha - so, what about a taller rear end?
    10. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      09-30-2012 04:39 AM #10
      Simply put- No.
      Note at any given speed in the same gear the engine will be at a lower rpm.
      Why do you think overdrive uses less gas when you have to give it much more throttle to maintain speed?
      One rule of internal combustion engines is they are more efficient (at getting mechanical energy from the gas used) at closer to wide open throttle.
      So a lower rpm with more throttle is actually more efficient than a higher rpm with less throttle.
      On the other hand- the effect to stop and go around town fuel economy is not so easy to calculate. This is where the heavier larger diameter tires will hurt performance, but not sure on economy.
    11. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 04:46 AM #11
      Simply put- No.
      Performance I'm not worried about, really. I plan on driving it like the land barge it is, slow and calm.
    12. Member ABATurbo's Avatar
      Feb 10th, 2010
      2015 GTI
      09-30-2012 04:49 AM #12
      Simply put- No.
      How do the larger tires allow the engine to spin slower at a given speed? I'm genuinely curious, I've never bothered reading about bigger tires, because I don't have a truck.
      I'm just going by what my teacher in my suspension/alignment class told us. He didn't get very specific, but basically said bigger tires = worse economy because the tires are harder to spin due to weight and size.
    13. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 04:51 AM #13
      He'd be correct if the RPMs stayed the same, and it's a general rule, sure, as more weight and size is more rolling resistance. But, the effect of a larger sized tire causing the engine to spin at a lower RPM will overrule the slight loss from rolling resistance.
    14. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      09-30-2012 04:52 AM #14
      The best thing to do with a used vehicle is make sure everything is as good as it can be.
      Your Suburban should be 11-17 mpg in stock form.
    15. Member Tornado2dr's Avatar
      Mar 31st, 2001
      Split Pants, VA
      09-30-2012 06:47 AM #15
      This.
      And be thankful that it ISN'T the 6.2d.
    16. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 10:59 AM #16
      This.
      Oh? Go on
    17. Member
      Feb 8th, 2002
      Lincoln, NE
      1966 Corvair | 2010 Mazda5 | 2002 Chevy 2500HD | 2004 Subaru WRX
      09-30-2012 11:22 AM #17
      This.
      QFT. The people who wish for the 6.2 are people who have not driven, worked on, or owned a 6.2.
      I learned to drive on an '84 4x4 6.2d Suburban. On a left turn arrow across a wide road, you had to punch the throttle while the light was still red in order to clear the intersection during the green cycle. And they are NOT cheap to keep running in most instances.
      Quote Originally Posted by sosumi on the B6 S4 V8
      It sounds like a giant shotgun and then like a bunch of ground up Yugo's in a cement mixer followed by weeks of silence interspersed by wails from the owner.
    18. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 12:01 PM #18
      Quote Originally Posted by ArmenB View Post
      Insight is appreciated. I was looking at early 90s IDI Ford diesel pickups before I settled on the Suburban... I hear those are just as ungodly slow .
      If money were no object, I'd probably throw a crate Cummins in with a newer transmission and call it a day.
    19. Member mikes96GTI's Avatar
      Jan 22nd, 2003
      Liberal/Socialist Utopian State.
      2014 GLI Edition 30, 2012 JK, 1989 E30
      09-30-2012 12:27 PM #19
      it is a TBI. Look up your RPO codes, either under the hood, or on the glovebox door (yours is an 88 so should be on the glovebox door) and that will tell you all the options. write them down and enter here. http://lonestarthunder.com/m_rpo.php
      The trans will be a 700R4, and trucks were a heavier duty "K" case which means thicker case, cars were different. They do not put up with abuse very well though. Your axle is likely a 10 Bolt, which is the bottom level axle, also does not put up with abuse.
      TBI is easy, base gaskets leak, EGR valves stick, throttle sensors give bad messages when worn, and the ignition module and coolant temp senders are troublesome, especially at this age.
      If you are thinking of swapping in a 6.2, just take out a gun and shoot yourself in the foot. That was a bastard motor. Period. You can make that small block run so much better, with way more torque for a lot less hassle. If its diesel you are after, Duramax is the way to go if you can swing it but I would leave a 6.2 to its duties as a boat anchor. Only decent ones I've seen have the rare BANKS kit.
      Rust is the killer here. If the shell is solid, great. They rust in the floors, around the glass in the front, rockers and wheel arches. Burbs also like to rust by the back of the side windows. All patch panels are cheap and easy to get.
      Repop parts are plentiful and cheap. Look at LMC truck, and Classic industries. Used parts are also plentiful, GM made MILLIONS of these things.
      Here are two of my old trucks.... I wish I still had them both.
      A good plan violently executed now is better than a perfect plan executed next week.
      George S. Patton
    20. Member mm3's Avatar
      Oct 10th, 2010
      Houston née NYC
      09-30-2012 12:53 PM #20
      Quote Originally Posted by mikes96GTI View Post
      Will look into those RPO codes immediately!
      Transmission and rear-end don't put up with abuse... got it. That said, if I needed a replacement for either one in the future, finding one should be non-issue and cheap - from what I've come to understand, anyway.
      Okay okay! 6.2 is out! haha - I didn't do my research on the 6.2, I just thought to myself "ZOMG DIESEL". A swap to a Durmax (or any motor) would probably too much money and work for what it's worth... and yeah, I can definitely work with the existing 350, even if I have to rebuild it later.
      The one thing I DID do before pulling the trigger on this truck is research the rust spots, ALL of which were completely rust-free!
      Looking forward to finally owning a vehicle that is both easy to work on and cheap to maintain.
    21. Member clutchrider's Avatar
      Dec 10th, 2010
      Connecticut
      2012 GLI
      09-30-2012 12:54 PM #21
      My uncle had one for well over a decade. He finally retired it and got a 800 series. That thing was a tank though.
      Quote Originally Posted by stagman View Post
      Driving an automatic is like watching porn on your computer...sure you get the same results, but your not really participating, are you?
    22. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      09-30-2012 01:24 PM #22
      My dad had an '88 C2500 with the same drivetrain.
      Trans lasted til about 140k when the fluid started turning black and smelling burnt/fishy. Flushed it and it morphed back to black/burnt within a couple thousand miles, and O/D wasn't engaging correctly. He had an uprated rebuild installed (shift kit, upgraded internals, beefier torque converter) and that decided not to shift out of first after about 30k miles. Not a huge fan of that trans.
      That motor is NOTORIOUS for leaky valve stem seals. Dad's truck started blowing blue smoke on cold start around 20k miles. Dealer redid the heads on it, but by 100k it was doing it again. He just ignored it and added oil thereafter.
      That motor only had about 210hp stock, so don't expect much performance from it. As stated, many components related to the TBI can fail, causing poor performance...the gaskets, injectors, and coolant temp/throttle sensor all went in dad's truck over time. They're kind of a PITA to diagnose.
      The Suburban is a very old chassis design, so parts should be plentiful.
    23. Member
      Dec 30th, 2006
      1992 Volvo 740 Turbo
      09-30-2012 01:31 PM #23
      Ah, it's not that bad. It's a diesel V8 and is incredibly simple to work on. I wouldn't bother swapping one in, but it's totally livable. I've never driven a 4x4 version with a diesel and I could see that sapping a lot of the power, but in 2wd guise I thought it was fine.
      Quote Originally Posted by Mach700 View Post
      In the absence of Wars, people become lazy and sex slaves (not everybody).
    24. Member Geechie_Suede's Avatar
      Jan 17th, 2009
      Grand Rapids, MI
      1997 Volvo S90
      09-30-2012 01:34 PM #24
      Man, haven't seen a rust free Suburban of this generation in a while. BTW I just found this (below) on CL the other day. It belongs to someone I went to high school with and I want to know how rare is the Silverado trim for the Suburban?
      http://grandrapids.craigslist.org/cto/3261141595.html
      1975 chevy suberban - $2000 (forest hills)
      runs great 4 speed new clutch and flywheel looking to get 2,000 obo
      Previously Owned: 96 Discovery/65 Corvair/93 Corolla Wagon/89 LeSabre/96 Camry/99 Regal GS/95 Accord/98 C-SVT/90 LS400/89 Supra/91 Legacy SS/01 CVPI/92 Mark VII/87 200SX/90 325i/03 TL-S/98 SC2/00 JGC/02 Forester/95 LS400/95 Audi 90/01 Jetta VR6/93 LS400/96 Camry/00 Cavalier/06 Speed6/92 190E/04 Accord/95 & 05 Civic/01 Cavalier/97 Bravada
      Current: 97 Volvo S90
    25. Banned justanotherusername's Avatar
      May 26th, 2007
      Palm Beach, FL
      '08 135i, '00 4runner, '85 Huntsman (Toyota) RV
      09-30-2012 01:36 PM #25
      As far as it having a carburator, GM had a few models that could be ordered with carbs after the switchover.
      My grandfather had a Caprice Classic that he ordered with a carbed 305 instead of the fuel injected 350 because he was an old timer and didn't like all the new "electronic junk". I think it was an '87 or '88. He also had a 1 Ton pickup around that same year that was a carbed 454 with no catalytic converters on it because of some off road loop-hole. It had spark arrestors on the tail-pipes instead.
      So..point of all that is it may not be impossible that it's carburated. If it is, it's probably rare and was ordered that way likely by someone like my Grandfather.
