Results 1 to 7 of 7
Thread: 1987 VW GTI Starting Problem / Please help
  1. Member JBKorp's Avatar
    Nov 20th, 2010
    97 VW Jetta GT/ 90 VW Corrado G60 / 1987 gti 16v
    09-30-2012 08:14 AM #1
    Hey everyone
    Im having one hell of a time trying to get my car started give you a little bit of the back story.
    Its a 1987 VW GTI 16V 1.8
    Motor was running when i pulled it to replace a few parts
    Things done to the motor
    - Timing Belt
    - Head Gasket
    - Water Pump
    - Oil Pan
    Problem we are running into is that she cranks over but doesnt wanna start at all we have had pops and noises that sound like vacume but all she does is crank over and something we get white smoke from the intake which is just weird to me
    Things we have check
    -Spark
    -Timeing which seems like everything is already all marks line up
    -We are getting Fuel
    Any Ideas help im losing my mind
  2. Member JBKorp's Avatar
    Nov 20th, 2010
    09-30-2012 08:28 AM #2
    We did check the timing after trying to start it a few times and if we where correct it might have been off by 180 Degress does this mean my head is now junk .
    Starting to worry its my daily and been working on it like crazy
  3. Member JBKorp's Avatar
    Nov 20th, 2010
    09-30-2012 09:10 AM #3
    Any help and idea anyone ?
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    09-30-2012 11:11 AM #4
    Poss valves are bent. Have you done a compression test?
    FS:Sunroof Deflector
  5. 10-02-2012 03:16 AM #5
    Get out your bentley manual and check out the timing section. I think the bentley does a great job of explaining how to do the timing. When you are lining up the crank you can use the mark on the lower plastic timing cover but you can also use the flywheel marks. I prefer the flywheel side (timing hole).
    once you get the timing marks corrects then spin the motor one revolution by hand and recheck then check Compression. This will tell you if you have bent valves
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-02-2012 03:48 AM #6
    does it turn over normally or does it feel like it's lacking compression? or do a compression test to know definitively.
    cam timing is critical, and it's always good practice to turn it over by hand beforehand after double-checking.
    if that checks out, it's also common to have the plug wires on the wrong way. The firing order is 1-3-4-2 still, but the rotor spins in the reverse direction compared to the block-mounted 8v's (16v rotor goes CCW, not CW).
    I really suck at smog.
  7. Member JBKorp's Avatar
    Nov 20th, 2010
    10-04-2012 10:32 PM #7
    Did a Compression Test today
    Dry
    Piston 1 90 PSI
    Piston 2 90 PSI
    Piston 3 110 PSI
    Piston 4 90 PSI
    Wet
    Piston 1 100 PSI
    Piston 2 110 PSI
    Piston 3 120 PSI
    Piston 4 110 PSI
    Good/Bad passable lol I have no idea it is and old motor
