Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: 2012 TT RS turns over but won't run
  1. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    09-30-2012 09:53 AM #1
    As I was ascending a hill at approximately 50 mph, the tach and speedometer froze and the lights went out in the entire gauge cluster. I made it home, where I parked the car.
    A few hours later, I attempted to start the car to no avail. The lights on the gauge cluster are still out and the car merely turns over but does not run.
    Audi is going to look at it tomorrow (they have no idea based on the above narrative what could be wrong) but I'm wondering if anyone has encountered this problem or has any idea what could be the cause.
    APR stage 1/down pipe, intercooler, and 8500 ci radar are the only mods currently installed.
    Appreciate any insights....
    Jul 14th, 2000
    Bay area, California
    2012 TT-RS
    09-30-2012 12:40 PM #2
    That doesn't sound good! Seems like an electrical issue, and hopefully a quick fix.
    I'm very curious how Audi handles the repair given the ECU and other mods. Please keep us posted!
    2012 TT-RS in Suzuka Gray
  3. Member LynxFX's Avatar
    May 17th, 2012
    SoCal
    2013 TT-RS; APR Stage 2, 2012 Triumph Speed Triple R
    09-30-2012 02:48 PM #3
    Please keep us updated on what they find. Seeing that you have an APR tune, that could be cause for concern. Hopefully it is completely unrelated.
  4. Junior Member
    Apr 24th, 2012
    Sacramento,Ca
    2004 B6 Audi S4, BMW 330i and 2013 Daytona Grey Pearl TTRS
    09-30-2012 03:50 PM #4
    Sorry to hear that, but the more I hear about problems after mods the more I hesitate to modify the engine despite how tempting it is!!
  5. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    09-30-2012 04:54 PM #5
    Quote Originally Posted by jmofo View Post
    They've been doing it in EU since 09 or I would feel the same.
    2012 TTRS: Daytona Gray, Tech Pack, Heated Alcantara, CF Mirrors, Nexon CF Steering Wheel, DG Rear Valence
    GIAC Stage 2+, AWE SwitchPath + cat-deletes, AWE FMIC, H&R RSB, MSS Sport Springs, HRE P40, AWE Boost Gauge, Tinted Tails and Reflectors, OSIR Coolant Tank CF Shield
    Winter/Track Wheels: Borbet LV5
  6. 09-30-2012 06:19 PM #6
    sounds like a electrical fault like others have said. Same happened to my friends bmw 335i, turned out to be a dodgy relay.
    Audi TTRS: APR Tuned
    Fully built motor, Forge Race FMIC, Scorpion Titanium TBE, 8 pot calipers, braided lines.
  7. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    09-30-2012 09:00 PM #7
    This note may describe mere coincidence but I had no problems w/the car (post tune and hardware installs) until I got it back from Audi after its initial service.
    I have no reason to suspect Audi and am leaning toward the idea that problem stems from an electrical fault. After speculating a bit w/a few local owners, there might be reason to suspect the problem could be related to the fuel pump (power, relay, etc). The oddity is that the gauge cluster lights are also out (though, no blown fuses).
    In any event, Audi has it tomorrow...my fear w/this kind of thing always lies w/the novelty of the problem. If the techs havn't seen it before, troubleshooting an unknown can end up taking days to months.
    Will keep this post updated...cheers and thanks for the concern.
  8. Junior Member
    Nov 8th, 2011
    Bend, OR
    10-01-2012 12:01 AM #8
    It sounds like it could be the immobilizer?
  9. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-01-2012 01:05 AM #9
    Quote Originally Posted by as350 View Post
    I'm revealing my ignorance here, but the immobilizer?
  10. 10-01-2012 09:04 AM #10
    The cars security system
  11. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-01-2012 10:13 AM #11
    Check.
    Well, while it may not have tripped properly, it certainly works
    I'll bring it up w/Audi.
    Thanks for the insight.
    Jan 14th, 2003
    Houston, TX
    2012 Porsche Carrera 991
    10-01-2012 10:57 AM #12
    Kind of a longshot, but on the original Gen I TT's, instrument cluster failures were pretty common. It was relatively advanced tech for the day and I guess quality control just wasn't there yet.
    Cars won't start because basically they're either not getting fuel, or not getting spark. Both are ultimately controlled by the ECU. Good luck.
    Houston, TX
  13. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-01-2012 11:31 AM #13
    Quote Originally Posted by mtbscoTT View Post
    Interesting bit of history. As the car turns over, I suspect its being denied fuel. In any case, you touched upon a secondary concern: the tune.
    I should have something by COB today...will post then.
  14. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-01-2012 12:00 PM #14
    I'm sure APR is keeping score on the odd-ball issues arising on cars with their tune. It could all just be coincidence and bad luck and completely unrelated but it's starting to grab my attention.
  15. Junior Member RoadTTripper's Avatar
    Aug 12th, 2012
    Massachusetts
    2013 TTS Prestige. Previously 2001 TT QC, 2004 QC and 2010 QC
    10-01-2012 12:01 PM #15
    I was one of those MkI TTs. Engine would turn over but not start. No tunes or anything, just a fried computer replaced under warrenty. Luckily I was in my driveway when it decided to quit.
  16. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-01-2012 06:54 PM #16
    Ok...just a note to follow up. After dis/reconnecting the battery, the gauge cluster and security system are operating normally. BTW, something I didn't know but the gauge cluster and security system are linked into the same module. So, it came as no surprise that both systems failed at once...though, I'm still thinking there must be a root cause.
    However, Audi asked to keep the car anothe day to conduct further tests. Not sure I'm comfortable w/a on-off switch fix, either (even though all the diagnostics they ran indicate the car is running as designed).
    I'll have it back late tomorrow morning...will follow up w/anything they find.
    Once again, thanks to all for the insights and expertise.
  17. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-01-2012 10:42 PM #17
    Reassuring yet concerning at the same time. I agree with you, there has to be a root cause.
  18. Member
    Jan 14th, 2003
    Houston, TX
    10-02-2012 09:41 AM #18
    Just to refresh a story I told on here months ago....at about 8 months/10K miles, I got a CEL twice that went out on its own. Just to be safe, I had the dealer look at it. They ended up keeping the car for two days working with Audi tech support, and the conclusion was.....they didn't know for sure.
    Keep in mind, there's a relatively small number of these cars in the US. Sure lots of stuff is standard Gen II TT, but anything that's different because of the unique engine/drivetrain is going to be new territory for them. In my case they determined it was "probably" something emissions related but inconclusive as to what was failing. The car always ran fine and continues to. I'm going to guess they give you car back and hope for the best.
    Houston, TX
  19. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-02-2012 05:52 PM #19
    Audi condemned the gauge cluster...new one being overnighted for install tomorrow.
    More to follow...
  20. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-02-2012 10:14 PM #20
    Oh boy, bad memories of my mkI days coming back. I haven't heard of any cluster failures in EU though so maybe it is 1) very isolated failure, or 2) dealer simply taking a shot in the dark.
  21. Member TT--AUDI--S4's Avatar
    May 10th, 2004
    Powell, Ohio
    '12/TT RS, '10/VW/GTI, '06/Porsche/987S
    10-02-2012 11:12 PM #21
    Interesting.
    2012 TT RS (Phantom Blk, Tech Pkg, Sport Ti Pkg, Heated Seats, CF Mirrors, Tint, Clearbra)
    2010 GTI (Tornado Red, Loaded, R taillights, OZs, DGs, Blk Roof, LEDs, Tint, Clearbra)
    2006 987S (Carerra White, GT3 Seats, PSS9s, RG5s, AWE Catback, Tint, Clearbra)
  22. Member
    Jul 14th, 2000
    2012 TT-RS
    10-03-2012 02:40 AM #22
    Quote Originally Posted by blackout-rs View Post
    More to follow...
    Any idea what caused them to deem the gauge cluster bad?
  23. Member pal's Avatar
    Aug 16th, 2000
    New Jersey
    2007 BMW Z4M Coupe, 2008 Audi TT Quattro 3.2 Coupe
    10-04-2012 05:13 PM #23
    My first thought was a bad cluster as well. Brought back some memories of my 2002 225 Coupe that would randomly shut down and refuse to start. And after getting towed home it would start sometimes and not at other times. I had an APR tune as well so replaced the ECU for a new one and got a GIAC flash. Car for solid for a few months and the problems started again. Replaced the cluster and all was good after that.
    MK1 clusters were made by Magneti Marelli I think- Italian electricals on a German car ...
    My 2004 was rock solid and I have not heard of cluster issues until now on the MK2s. Maybe TT RSes got a bad batch?
    2007 BMW Z4M Coupe, 2008 Audi TT 3.2 Coupe Quattro 6MT
  24. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-04-2012 06:52 PM #24
    Audi should finish installing the new cluster today...so, again, more to follow....
  25. 10-05-2012 02:03 PM #25
    you didn't get any grief about the ecu tune?
  26. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-05-2012 05:59 PM #26
    Although Audi could not determine what failed, they replaced the gauge cluster. I'll have more if it fails again, but for now all I can report is everything is back in order.
    And, no, they didn't give me a hard time about the tune.
    Till next time....
  27. 10-06-2012 07:18 PM #27
    why are people even mentioning the tune? We have had tunes in europe since 2009 and no failures of this kind!
    The most we have had is one persons ECU was bricked after audi attempted to update a s-tronic car that was flashed by MRC.
    Me and 3 of my mates have all got ttrs (they copied me ) and we get no issues at all with out heavily modded cars when we claim warranty work, which is through blatant abuse
  28. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-06-2012 07:32 PM #28
    AoA does not rule EU.
  29. 10-06-2012 08:40 PM #29
    Quote Originally Posted by Black BeauTTy View Post
    same cars though, so suspecting the tune prematurely should be a non starter.
  30. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-06-2012 08:50 PM #30
    Quote Originally Posted by Poverty View Post
    I thought you were talking about warranty coverage. AoA is clamping down on dealers apparently.
  31. 10-07-2012 11:45 AM #31
    From my own experiences, its good to have a chat with the techie who is actually doing the work on your car, if you have obvious mods or want a good job to be done, and consequently making it worth his while
  32. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-07-2012 12:11 PM #32
    Totally agree. Been dealing with the same folks since I bought my 2001 TT. It makes a world of difference to befriend the tech staff.
  33. Junior Member
    Jul 5th, 2012
    2012 Audi TT RS
    10-08-2012 12:15 AM #33
    I can second this as nearly all the cars I've owned have had tunes...GTR, EVO9, 350z, and most recently, an 800hp Shelby Super Snake. So far, I've never run into a problem with a dealer that has diagnosed the tune as the cause of any of the problems I've had with my cars. If AoA starts clamping down, then I'll have to lean in a different direction.
    So far, I don't see this as a problem.
    Cheers to all.
  34. Junior Member
    Aug 13th, 2012
    Bay Area, CA
    2013 TT RS
    03-26-2013 09:34 PM #34
    I am having a very similar gauge cluster problem in my 2013 TTRS detailed here:
    http://forums.fourtitude.com/showthr...7#post81003187
    Basically the gauge cluster starts up slowly and throws a bunch of errors that say "Problem communicating with instrument cluster" in VAGCOM. If you turn the car over while the cluster is booting, the car shuts right off. If you let the cluster finish booting, the clock is always reset but the car runs OK. Since my car had the APR Stage 2 flash, the dealer insisted I take it back to stock before proceeding. I've done that now so back to the dealer to continue investigation.
    2013 TT RS, Phantom Black, APR Stage 2, APR Downpipe, MSS Sport Springs Pre-Ordered
  35. Member J662's Avatar
    Dec 7th, 2011
    San Diego
    2012 Black TT-RS • GIAC Stage 2 • AWE SP Exhaust • AWE Intercooler • 034 M Sway • 034 SS Brake Lines
    03-28-2013 10:35 PM #35
    I keep seeing issues with people's cars and all of them have APR tunes. Just an observation.
