Results 1 to 15 of 15
Thread: 90 g60 vrt intercooler question?
    Jul 31st, 2011
    Misissippi
    2008 civic si sedan 2006 acura tsx 1997 vw golf gl 1995 vw jetta glx vr6
    09-30-2012 10:19 AM #1
    Just picked up my 90 g60 vrt yesterday it's non intercooled but I/c and piping came with it not installed. I can't for the life of me figure out the plumbing on this thing any help would be great. I wanna crank the boost up but am scared being non I/c. I'm currently on 9psi.
    2008 civic si sedan
    2006 tsx
    1997 golf gl (for sale)
    1995 jetta glx vr6
    Jul 31st, 2011
    Misissippi
    10-02-2012 07:35 PM #2
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
  3. Member skaterazn's Avatar
    Jan 9th, 2007
    Wa
    Toyota Poopra, OBD2 vrt gear eater, A3
    10-02-2012 08:23 PM #3
    add water meth if you're too lazy to figure out plumbing.
    here's mine. It's a hacked up mess until I change it later on but I'm happy with it for now. runs normally 18-26 psi
    Quote Originally Posted by ein View Post
    The only idea VW ever had that was dumber than Aktiv was the G-Lader.
    Aug 17th, 2007
    Doylestown, PA
    Everything you could imagine basically
    10-02-2012 09:03 PM #4
    You can run more boost safely with high octane and no IC.
    Or
    You can post pix of the plumbing you HAVE IN HAND and get the added security after we all see it and tell you how to plumb it.
    OR
    You can do what I did: delete AC, have custom pipes made, have a scoop feeding it from the grill, hide the IC behind the bumper, paint it black with radiator paint, run a snowperformance stage 2 meth (no water) setup, and have a stock looking car and all the plus's at 26 psi in the summer heat and never have an issue.
    Also: I'd bet a million bucks you have a .63 A/R hotside, get RID OF IT! You will kill your trans at 15+ psi!!!!!! Call Clay at CTS Turbo, order the .82 hot side first IMO. And before installing, get it ceramic-coated (or Jet Hot, your choice. 1/2 dozen of one, 6 of another)
    You will gain:
    Traction in all gears
    Less "shock" on trans when spooling
    Higher power with same boost
    Smoother boost curve
    Better "passing power" (when remaining in same gear on freeway)
    And did I mention less shock on trans? Ya, I did, twice now.
    A little story for you;
    The VERY FIRST TIME I accelerated in 3rd gear, (from 2,000 rpm's to the moment of destroying my trans) was the VERY FIRST time I hit the gas with higher boost than 14/15psi.
    The FIRST TIME!
    Protect your car; upgrade hotside, intercool it, save for meth, and then run 26 psi all day, in 100* weather and NEVER have an issue.
    Jul 31st, 2011
    Misissippi
    10-02-2012 09:30 PM #5
    Quote Originally Posted by Noobercorn View Post
    Or
    OR
    You will gain:
    The FIRST TIME!
    You are correct on the .63
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
  6. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    2013 Charger R/T - 91 Corrado - 92 Corrado VR6
    10-02-2012 11:53 PM #6
    if i can afford to go awic i plan to go just like my friend's setup... piping is all new and shiny now but gist is all the same... clean
  7. Member dasbeast3.0's Avatar
    Aug 14th, 2007
    Grizzly bear
    10-02-2012 11:57 PM #7
    Piping goes from turbo outlet through i/c to throttle body, its not that hard to figure out. you prob have 30# setup w/ stock pump so if you run much past 15psi (300whp), you'll be investing in a new motor. leave it alone, pipe in the i/c and enjoy the capabilities of your current setup without spending more $.
    Aug 17th, 2007
    Doylestown, PA
    10-03-2012 12:27 AM #8
    Quote Originally Posted by dasbeast3.0 View Post
    Piping goes from turbo outlet through i/c to throttle body, its not that hard to figure out. you prob have 36 lb injector setup w/ stock pump so if you run much past 15psi (300whp), you'll be investing in a new motor. leave it alone, pipe in the i/c and enjoy the capabilities of your current setup without spending more $.
    Fixed, noob
    Horology, Renovations, Home, Auto, anything. You need it, I can do it. If I can't, I know who can! I'm here to help! Ask me anything, ill do my best.
    MIKEPMCNAIR@GMAIL.COM
  9. Member g60racer's Avatar
    Nov 18th, 2000
    San Diego
    93 VR6 Corrado, 04 R32
    10-03-2012 12:35 AM #9
    For all you know he may still have the stock injectors. NOOB back at you!
    Not like he mentioned any of his specifics. Unless you're now a psychic in addition to your other amazing talents.
    Brendan Prout
    04 R32 114k miles
    93 VR6 Corrado 182k miles
    90 G60 Corrado 304k miles - RIP 2/12/11
    Aug 17th, 2007
    Doylestown, PA
    10-03-2012 12:46 AM #10
    Quote Originally Posted by g60racer View Post
    As u already know, I am Indeed psychic, noob.
    As for a "stage 1, NON INTERCOLED setup, yes; he could be in the stock 36#'rs, 30# if OBD2 swap was done)?but based on the brief post, he's likely at 36#
    Call me out again, I dare ya!
  11. 10-03-2012 01:01 AM #11
    call me maybe
    Quote Originally Posted by BlueVR View Post
    yes i am still into Vag...
    Aug 17th, 2007
    Doylestown, PA
    10-03-2012 01:12 AM #12
    Quote Originally Posted by hubbell View Post
    call me maybe
    I HATE that song!!!!!!!!!!!!!!!!!
    As for this thread, I got on lock son !
  13. Member
    Jul 31st, 2011
    Misissippi
    10-03-2012 04:23 AM #13
    32# injectors c2 32# file obd2 12v pauter rods glyco bearings all arp hardware brand new aaa head ATP manifold with t3/t4 50 trim 2.5 dp with around 8k miles on build. Currently on 9psi po said he ran 20 psi in a MKIII Jetta before putting motor in the rado.
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
  14. Member
    Jul 31st, 2011
    Misissippi
    10-03-2012 04:24 AM #14
    Also stock fuel pump.
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
  15. Member dasbeast3.0's Avatar
    Aug 14th, 2007
    Grizzly bear
    10-03-2012 04:22 PM #15
    I never ran the stg1 setup so I don't know offhand what specific injectors it came with.. Fact is hes on the stg 1 software/fueling/ stock pump - like I said. 26psi will demolish the guys engine, so I dont think you have this thread on lock.. son.
    OP,
    If you want to make more than 300~ whp, you will need to upgrade your tune/ fueling, intercooler, and turbo. Your t3/t4 50 trim is too small and inefficient, it will throw a ton of heat after 15-20 psi (regardless of turbine housing) and heatsoak the small front mount instantly. You will pull timing and dog the car out after 1-2 runs, keep pushing it and you will ruin the engine. I highly suggest skipping the 42# setup and going straight to 630 Pro Maf, its smoother in boost and much more flexible than the 42# software (that is, if you plan to stay with a chip tune).
    Invest $ in a proper awic setup, it is night and day difference. a/a is great also, but there's no room in the corrado for fitment or proper airflow without a ton of cutting/fab work.
    Dont waste $ on a fancy ball bearing turbo, Spend $600~ on a rebuilt or new Holset hx40Pro. It will out flow, out spool and out live any Garret or Precision turbo. They are also rebuild-able.
    Thats my advice..... or you can do what I said before, pipe in the i/c you have, run a safe 15psi n call it done.
