Maybe I should say it a different way. Obviously the injectors are a EV1 clip. But I can figure out what the car is. I would either like to get adaptors or make adaptors so I don't have to mess with the factory harness.
I just recently purchased siemens 630 ev1 injectors for my 03 gli 24v vrt. I can't figure out what adapter I need to use them. And where to get them from.
im pretty sure they drop inmine did
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
check fiveO motorsports
From reading on here. Best I could tell they would drop in. Well they don't. The best I can tell The adaptor I need is a Denso-EV1. Ordered them yesterday. Should know in a few days. Just aggrivating when this is the only thing left to do before I can try and start it for the first time.
That injector is available with either ev1 or ev6 connector... sounds like you bought ev1. Oopsie.
i got mine from gabe at bluewater, he included the plug and play adaptors as well. he might be able to help you out
The ev6 clips would not have made them drop in. They would have made it so I could have at least used the adapters I had. Issue was I could not find any good info as to what the factory injector clip was on a 24v vr. So if anyone needs to know. Its a denso clip. The denso to ev1 adapter worked perfect. And the ev6 injectors would be better to use as the ev1 clip slightly touches the head. Not enough to hurt anything, but just a little.
