Results 1 to 12 of 12
Thread: Loss of power, while in cruise control.
  1. Junior Member PineappleBrains's Avatar
    May 18th, 2011
    New Vernon, NJ
    .:R32T
    10-01-2012 12:22 AM #1
    Earlier this evening on the highway while in cruise control I had a strange issue.
    Going up a slight incline all of the sudden I lost power, my ESP and EPC lights came on, and the engine was running very strange. It wasn't stuttering but was louder and vibrating a whole lot more than normal. I pulled over and shut the car off for a couple mins, started it up, everything was normal and continued. About an hour later the same thing happened and when I started up the car again the check engine light was on.
    I had my room mate scan it when I got back and it came up with ECM and PCM processor errors.
    Not sure what kind of problems this would be. All the searches on cruise control didn't turn up anything like this.
    Anyone heard of something similar or point me in the right direction as to what the problem would be?
    The cars a turbo'd r32. Any other information you need I'll gladly supply.
    Most recent picture just because I never post. Too bad it's already a couple months old.
  2. Member rconn14's Avatar
    Sep 6th, 2006
    Connecticut
    2004 BMP R32
    10-01-2012 01:57 AM #2
    This has happened to me, but I'm not turbo'ed. When I shut the car off and turned it back on a minute or two later it went away. Scanned the car right after it happened and I had no codes. Same symptoms however. Has probably happened 3 times in 50,000 or so miles. I was cruising next to an R32 guru and he said it sounded like misfiring. Sounds like a computer error/electrical gremlin if anything...
    http://r32registry.org/802 ||| Large Garage Banners FOR SALE
    Quote Originally Posted by B3VW Hasan View Post
    I have to stop this idiot from deminishing my credibility every time he posts because my usernsme is in his sig. Who do I talk to?
  3. Member VincewagenR32's Avatar
    Nov 6th, 2010
    Turnbull Canyon, Hacienda Heights, CA
    MKIV R32-RS & 06 Specialized Rock Hopper
    10-01-2012 02:45 AM #3
    check the cam sensor screws. they get loose and have given some ppl these simalar symptoms.
    http://forums.vwvortex.com/showthrea...am+hall+sensor
    "A genius is not measured by what he knows, but with what he can figure out with what he already knows."
    Quote Originally Posted by power_mind View Post
    Also, remember that you can throw the whole parts bin at the car, you can even pick and choose, but the best modification is to tighten the loose nut behind the wheel.
  4. Member graeme86's Avatar
    Jun 27th, 2003
    Brisbane Qld
    2004 DBP R32; 1971 Superbug
    10-01-2012 02:51 AM #4
    I have a dedicated page on my Webspace for this now:
    http://www.users.on.net/~graeme86/ca...camsensor.html
    In this case, however, I would also check the function of the brake light switch on the pedal, given that it happened when the CC was engaged.
    PM if you are looking for: New Beetle RSI shift light; Euro Headlight switches; RHD folding Stubbies.
    OEM+ freaks click here: Graeme's Webspace - Latest Updates: Audi Brushed Alloy Mirror Switch; Camshaft Hall Sensors; Bulb Check System; W8 Light with Autodim Mirror Defeat Function
  5. 10-01-2012 07:29 AM #5
    Mine C2 software was doing it real bad. Will cruse for some 3-5 minutes then power loss following check engine light. Scanned with no codes.
    Flashed with UM code, problem went away. Never came back.
    So it can be code related.
    .:R32T, Stock Internals | Precision 6265 | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler | 3.5 inch exhaust |
    Looking for Sheet Metal Fabricator? Talk to me!
  6. Junior Member PineappleBrains's Avatar
    May 18th, 2011
    New Vernon, NJ
    .:R32T
    10-01-2012 04:21 PM #6
    Quote Originally Posted by graeme86 View Post
    Checked both those bolts and they were secure.
    Wouldn't the brake light switch only cause the CC to turn off? Not cause a loss of power?
  7. Senior Member abeR's Avatar
    Sep 13th, 2002
    Joe's Garage / Chicago
    3.2 electric boogaloo bitches
    10-01-2012 04:33 PM #7
    if its faulty it could probably do a number on either.
    possibly.
  8. Member VincewagenR32's Avatar
    Nov 6th, 2010
    10-01-2012 06:45 PM #8
    Quote Originally Posted by PineappleBrains View Post
    we mentionsed the CAM sensor screws as it sometimes gets overlooked as a issue. but back to the mission at hand...
    has your car had all its Recalls done? The brake light switch is one of them. check with your local dealer if you havent already.
  9. Member graeme86's Avatar
    Jun 27th, 2003
    Brisbane Qld
    10-01-2012 11:09 PM #9
    If the ECU thinks the brakes are on, then it cuts the engine power...it's a safety cut off they have programmed in.
    If you don't have the latest switch then certainly change it.
  10. Junior Member PineappleBrains's Avatar
    May 18th, 2011
    New Vernon, NJ
    .:R32T
    10-02-2012 01:43 PM #10
    Quote Originally Posted by VincewagenR32 View Post
    Just got off the phone with the dealer, the only open recall is the ignition coils. Which I made an appointment for. But everything else has already been completed.
  11. Member gnatman's Avatar
    Jun 2nd, 2007
    BMP MKIV .:R32T, B8A4, 86Z28(trkhor)
    10-02-2012 02:29 PM #11
    Did your idle change too? what if you unplug the maf. does the car still die or does it run better?
    Click me for apparel
    HAVE YOU SEEN THE VIDEO?
    I print apparel for a hobby. PM ME FOR DETAILS
    .:::Exklusiv:::.
  12. Junior Member PineappleBrains's Avatar
    May 18th, 2011
    New Vernon, NJ
    .:R32T
    10-04-2012 05:50 PM #12
    Quote Originally Posted by gnatman View Post
    The idle changed when it happened in cruise control and also after I cleared the check engine light that night it got a bit smoother. The car has never stalled out on its own before though.
    Ill check what happens with the maf unplugged later tonight after class.
