The stock 15" size on Corrolla steel rims (black) works fine when your oem is the 17". I did that, with Michelin X-Ice, used regular open ended galvanized nuts, no tpms. You could Corrolla wheel cover on I guess; I just left them plain.
#1
I am looking in buying a set of wheels that are 20x8.5f & 20x9.5r et35. I would just like some info regarding offset, tyre sizes, spacers if needed, lowering, rolling or pulling of fenders, ect. I would just like to have my car sitting pretty thanx guys for any helpful info.![]()
What are curb feelers?
#2
#3
what?
Search for a post called wheels size recommendation or how wide is too wide , there is a lot of information there
Sent from my DROID4 using Tapatalk
DO YOU SPEAK DAS AUTO?
#5
20's are tooo big.
Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
#6
If you wanna go low....19's. as for wheel choice....they are endless. BBS, Rotiform, ORT, VMR, Miro, MRR, etc...
Unitronic>Revo and hauling ass! K04 w/ RS4 injectors, Forge WINtake, Eurojet intercooler, ECS lightweight pulley, APR TBE, APR hpfp, BSH TB pipe, Forge DV, Neuspeed K04 discharge pipe, ECS dogbone mount, BFI stage 2 engine & tranny mount, 42 DD Ultimate catch can, HPFP Upgrade 145 BAR FRV, Snow Performance Stage 2 water/meth kit, Level 10 valve body rebuild
#9
You should probably try to find a wheel with _at least_ an offset of 40.
#10
I had 19s on my b5 S4 and the b6 passat seems to be a bigger car and i have seen b6's rockin 18's, and 19's and they just look small. So is there anyone that is rockin 20's. As far as rubbing goes who dosent have that problem in the rear.
#11
The passat is roughly the same size as a B5 S4 (i have a buddy with one) 20s will be way too big. But whatever floats ur boat
If you want to run 20s witu zero issues you would run a 20x8.5 235/30r20 tire with a 40-45 offset and rubbing will be minimal.
Any wider of a tire with low you'll rub, any more offset with low youll rub unless you go with a 225 width tire
Sent from my Galaxy SIII
