Results 1 to 3 of 3
Thread: 1999 audi a6 cruise control not working
  1. 10-01-2012 08:17 AM #1
    I have a 1999 a6 2.8 in the shop now cruise control not working. only history i know a few weeks ago someone put a used abs control module in and for some reason i cannot get into the coding. i wanted to see if there were any areas where you need to put a number if it has cruise control. I tried using the login number per ross tech website and no good. I may be tracing the wrong issue cause it does have a brake light switch fault code and i do know that was replaced recently also so where do i start VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Monday,01,October,2012,08:17:37:21714
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    Mileage: 207440km/128897miles
    Address 01: Engine Labels: 078-907-551-AHA.lbl
    Part No: 4D0 907 551 AH
    Component: 2.8L V6/5V MOTR AT D02
    Coding: 06252
    Shop #: WSC 02325
    VCID: 6CDC71731CDF2578EDD
    No fault code found.
    Readiness: 0010 0101
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4B0 927 156 G
    Component: AG5 01V 2.8l5V USA 8509
    Coding: 00000
    Shop #: WSC 00000
    VCID: 2B5EB26FD951E240A47
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-00 - Implausible Signal
    Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
    Part No: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D10
    Shop #: BB 24334
    VCID: 1C3C61B38CFF15F8DDD
    Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
    Part No: 4B0 820 043 F
    Component: A6-Klimavollautomat D61
    Coding: 00160
    Shop #: WSC 02325
    VCID: 1D3A6CB797E51CF02A3
    Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
    Part No: 4B0 959 655 H
    Component: Airbag Front+Seite 0002
    Coding: 00206
    Shop #: WSC 02324
    VCID: 356A94170F15A4B0C23
    Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
    Part No: 4B0 919 930 J
    Component: C5-KOMBIINSTR. VDO D05
    Coding: 07262
    Shop #: WSC 00000
    VCID: 2F66A67FED499E6088F
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 J
    Component: Central Lock/Alarm D32
    Coding: 15885
    Shop #: WSC 02325
    VCID: 3064A503F0778198915
    Address 36: Seat Mem. Drvr Labels: None
    Part No: 4B0 959 760 A
    Component: Sitzmemory D05
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 02325
    VCID: E0C495436017F118C15
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D001
    Coding: 00006
    Shop #: WSC 02325
    VCID: E5CA84577F359430323
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 4B0 035 186 A
    Component: Radio D02
    Coding: 00207
    Shop #: WSC 40911
    VCID: 1E386BBB9AE307E8339
  2. Forum Sponsor Santos@Ross-Tech.com's Avatar
    Feb 16th, 2007
    Willow Grove,PA
    2004 Passat Wagon 1.8t, 4motion, manual
    10-01-2012 10:46 AM #2
    That abs module does not support coding. It is plug and play. My 04 passat has the same module.
    The brake switch fault is causing your cruise control problem.
    VCDS Diagnostic System For VW/AUDI/SEAT/Skoda/Bentley
    www.Ross-Tech.com
  3. 10-01-2012 10:51 AM #3
    thank you
