Results 1 to 7 of 7
Thread: 2010 Passat:no rear window shade?
  1. Member bpfoley's Avatar
    Nov 30th, 2000
    Rochester, NY
    02 VW Jetta
    10-01-2012 08:33 AM #1
    I am looking to buy a used Passat and love the look of the updated 2010 interior and newer tech (bluetooth, nicer steering wheel, gauges). I have noticed so far that the two sedans I looked at did not have the rear sunshade in the doors? Is this normal? Can I retrofit door panels with the sunshades?
    I have also been looking for 2010 Wagons, but they seem extremely rare.
  2. Member Track5tar's Avatar
    Feb 16th, 2010
    Salt Lake City, UT and Las Vegas, NV
    Mine: 2010 Passat Hers: 2012 B8 A4
    10-01-2012 09:28 AM #2
    You can retrofit it because it didn't come like that from factory
    Unitronic > APR Switched from APR to UNI and never looking back
    CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
  3. 10-01-2012 12:21 PM #3
    The B6 post-2008 was stripped of a lot of options. VW moved most of the luxury to the CC. To your specific question, I think you can retrofit the rear door window sunshades.
  4. Member bpfoley's Avatar
    Nov 30th, 2000
    Rochester, NY
    02 VW Jetta
    10-01-2012 03:36 PM #4
    Is the DSG a better transmission for the 2.0T (once all the firmwares updates are applied?)
  5. Member Track5tar's Avatar
    Feb 16th, 2010
    10-02-2012 09:43 AM #5
    Quote Originally Posted by bpfoley View Post
    way better transmission.. shifts so fast but you have to remember that its an automated manual and not a true automatic. the shifts might not be as smooth. I would get the DSG flash from unitronic an fix all the problems
  6. Member wiredvw's Avatar
    Jan 17th, 2006
    Minneapolis, MN
    2010 VW Passat B6 Wagon
    10-02-2012 11:17 AM #6
    Quote Originally Posted by Track5tar View Post
    The 2010 wagon had the shades as a standard feature so finding parts should be fairly easy.
  7. Member Track5tar's Avatar
    Feb 16th, 2010
    10-02-2012 12:09 PM #7
    Quote Originally Posted by wiredvw View Post
    great to know! I had no clue
