You, my friend, have some electrical issues. Check your fuses, make sure they're all good. Then check your grounds on the motor, make sure they're all solid, no cracks, or breaks. They're the tan colored wires. These are for injector harness for the p1425/6/7/8, your secondary air injector, and the 0300 codes are also for fuel injectors, likely related to the 1425/6/7/8 codes. I personally would go through the wiring on all 4 injectors and make sure they're not heat damaged.
Best case scenario, you've got some popped fuses, and you can just replace those. Worst case, you'll have to replace the harness. Not a tough job, but time consuming, and honestly a little daunting.
