Results 1 to 12 of 12
Thread: Bulbs for Switches! Which ones?
    Oct 21st, 2011
    Midvale, Utah
    1993 Volkswagen Cabriolet, 2005 Mitsubishi Evolution, 1978 Mini Cooper, 2002 BMW M3
    10-01-2012 12:43 PM #1
    Hey all,
    I'm trying to brighten up the interior of my car a bit, and I noticed that a ton of bulbs are out. not my cluster or gauges because I replaced those with led's just recently. I am buying bulbs for the trunk and license plate today, but I don't want to place the order without everything that I need. I need the bulb that is in the automatic window switch, the bulbs in the hazard light switch, and the bulbs for behind the air conditioning bezel. Does anyone know which LED's these would be??
    Oct 21st, 2011
    Midvale, Utah
    10-01-2012 01:02 PM #2
    just kidding. Ignore this. I found this, so I think I will just go off of it!
    http://forums.vwvortex.com/showthrea...-apply-as-well)
  3. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    10-02-2012 02:11 AM #3
    well the switches may not have bulbs in them
    you would be surprized but i think the defrost switch has bulbs soldered to the circuit
    you have to open the casing of the defrost switch
    yeah, i replaced all the bulbs with LEDS and things still work fine
    edit- and yeah sorry my old MySpace pictures dont load anymore
    i still have all the pics if you want me to go back through 3 years of threads to edit them.........ha
    depending on your switch you may need to open it or the bulb is on the rear of the switch
    these white ones work fine on the rear plate lights
  4. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller; 2000 Jetta VR6; 1990 Vanagon Westfalia
    10-02-2012 02:18 AM #4
    Quote Originally Posted by rabbitnothopper View Post
    All interior bulbs in the 'verts are soldered, except the headlight switch.
    If you're getting LEDs for the turn indicators, you'll need a matching relay to go with them... or wire in diodes.
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  5. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    10-02-2012 02:22 AM #5
    im pretty sure my 78 has two bulbs soldered inside the defrost switch
    both are dead
    the 81 which is the one i need to fix also has a bulb inside the housing, you can only see it when you turn on the marker lights/headlights and turn the defrost switch to on
    then out the side is a tiny green hole lit up by the light
    in that case i think it is the one item preventing my dimmer from working with all the other leds
  6. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    10-02-2012 02:42 AM #6
    both are dead
    That isn't the case as the bulbs are in Parallel to the circuit.
    If none of the bulbs / led's are working, I would first measure 12v on the blue/gray wire, if it ain't there that be your issue. Then I would be sure that I have the LED's Biased correctly as they are polarity aware....
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
    Apr 15th, 2006
    Clarksville, Tennessee
    '89 Cabriolet Best Seller '95 Ford Ranger XLT
    10-02-2012 12:31 PM #7
    I agree with Brian's suggestion, as well. Speaking of the dimming capabilities, I installed LEDs a couple of years or so ago in the cluster and gauges, as well as the a/c panel (fun, since mine is one of those without a bulb-holder and had to be carefully pried/cut open). With the far lower starting point of the LEDs, the OEM dimmer range isn't capable of dropping the resistance low enough to actually turn them all the way down and off but that's never been a concern, since I wanted a brighter dash lighting arrangement to begin with. By the way, I essentially retained the OEM-look, as well , retaining the original green film and using green plug'n'play LEDs for the cluster, the white for the VDO gauges (not plug'n'play, for the gauge lighting required some creative disassembly/assembly using some of the B8.3D-W LEDs as a starting point). The wedge-base LEDs were obtained for switch installation but I have yet to make it that far:
    Quote Originally Posted by courtneybriton View Post
    Tis helpful, indeed... Study the different options here, as well: http://www.superbrightleds.com/ .
    My flying/aerial/scenic/transportation-related photography: http://www.flickr.com/photos/vfr_photography/
    Cabriolet photography from years past: http://s82.photobucket.com/albums/j2...usa/?start=all
  8. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    10-02-2012 06:31 PM #8
    superbright now has a tool you can search for the bulbs which fit your car
    prior to buying you should of course go out and compare the real bulbs to their suggestions
    i only found their mistake was on the cluster bulbs which on a westy have two different types of wedge bulbs
    i guess youre right abou the OEM dimmer rheostat not having enough resistance to dim the interior LED at all
    it just seemed odd to me that it was either off at about 5/6 closed or full on from 5/6-1/99
    im not sure why your gauges are different but the 4 i have and have 3 installed all used the 74W in your picture
    its just a bulb using the OEM bulb holder in the socket
    you can of course use the B8.3 bulbs for the cluster sockets and remove the OEM bulb holders entirely
    becareful however they are extremely tight fit.
    Oct 21st, 2011
    Midvale, Utah
    10-02-2012 09:30 PM #9
    so has anyone tried doing the lights inside the automatic window switches? i have a 93 and therefore it has automatic windows, i am just curious if anyone has tread this unknown road?
  10. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    10-02-2012 10:16 PM #10
    The later Cabriolets (from about '84 onward) do not use a separate bulb; the bulbs are fused to the holders. The easiest method, albeit more costly, is to buy the replacement holders to put the new bulbs in... plug and play. Many folks don't care to spend the extra money, so they go the more complicated route by taking the LED out of the B8.3 holder and removing the incandescent from the gauge and doing a swap, essentially.
  11. Member
    Apr 15th, 2006
    10-03-2012 02:42 PM #11
    i guess you're right abou the OEM dimmer rheostat not having enough resistance to dim the interior LED at all
    Yes, I was wondering exactly what kind of dimming you were obtaining with the OEM switch... Tis identical to the way mine reacts...
    As for my gauges, yes, they're identical and it was for the reasons Kammy explained:
    Quote Originally Posted by kamzcab86 View Post
    This is what she's referring to:
    Ben/moogie's got a number of variations of this bulb holder listed within his Ebay store:
    http://stores.ebay.com/Mk1-Autohaus
    He's got a LOT of great things, in fact, and I've always gotten excellent service when buying from him. I just couldn't afford 9.95 per bulb holder, though, and opted to disassemble the LEDs from their base to add the necessary wires. Yes, it was a royal PITA, too, and makes the bulb holders look reeeeally tempting for any future swaps... lol
    Oh, and yes, I did notice that Super Bright's using a new fitment system over their old Sylvania bulb selection link... It's been a while since I've browsed their site.
  12. Member fredges's Avatar
    Apr 27th, 2012
    Seattle...ish, WA
    1987 VW Cabriolet - (Stock, Auto)
    02-26-2013 11:55 AM #12
    Let me tell you that bulb holder has got to be worth it! I spent hours in the garage last night trying (with mild success) to fit a standard "rice" bulb into the existing black bulb-housing thing. I frankensteined it to work until I can get the holder from Autohaus. Thinking I might just go with LEDs if they're brighter... we'll see... But yeah, $10 is nothing...
