Results 1 to 5 of 5
Thread: Odd E-Level Behavior
  1. Member orau22's Avatar
    Oct 15th, 2008
    NJ 08085
    SLAWbuilt MKIV & MKII Jetta Diesel
    10-01-2012 02:38 PM #1
    So I have had E-Level installed for about a year with very few headaches. Recently I have had some odd behavior with one of my height sensors. I have been driving absolutely fine, no issues, took a 6 hour drive to visit my dad, and parked the car for 2 days while visiting, when I went to get into my car before I left, level sensor one was red. I was really confused because I had not even driven, turned the car on and it was out. So I took a look at the level arm and the sensor, everything looked fine/normal. So I aired up to drive home and about 1 min into driving the light popped back on and it was good to go. Ever since then, usually when starting the car for the first time, that height sensor will be red and will usually turn on after a minute or two after driving.
    The other day, it did this, but turned on and off about 10 times while driving for 25 minutes. Today, I turned the car on and the sensor was fine. Its very random, doesn't follow a pattern, and is driving me crazy, any ideas?
    I haven't changed a thing or touched it since I installed it.
    SLAW [Straightline Autowerks]
    PM for fender rolling and coilover installs in South Jersey
  2. Banner Advertiser Jesse@AccuAir's Avatar
    Feb 9th, 2012
    San Luis Obispo
    05' Audi 3.2 TT
    10-01-2012 05:40 PM #2
    Hey dude shoot me a PM or give us a shout. Sounds like you may be getting a sensor disconnect.
    If you have a buddy around I would have them keep an eye on the controller while you wiggle the sensor plug around.
    Jesse
    Jesse Jenson
    jesse@accuaircs.com
    www.AccuAirSuspension.com | Office 805.481.6500 | Fax 805.481.2587
  3. Member orau22's Avatar
    Oct 15th, 2008
    NJ 08085
    10-01-2012 10:55 PM #3
    Quote Originally Posted by Jesse@AccuAir View Post
    Jesse
    ill give that a try when I get a chance, if no luck, ill give you guys a call, its just weird because nothing has changed since I installed it, I never touched it or anything, and it only happens sometimes, and will usually go away in a couple minutes.
  4. Member
    Apr 12th, 2007
    Phoenixville PA
    07 baggedwagon, now 12 GLI
    10-02-2012 07:27 AM #4
    you can also try switching the sensors from side to side and see if the problem follows. this will help tell you if it's the sensor, or the sensor wire.
    Jesse's the man and i'm sure will get you all sorted
  5. Member 96_VW_golf's Avatar
    Oct 8th, 2007
    Reading, Pa
    mk3 golf and G60 corrado: gone. mk4 1.8t golf and mk5 4door gti: Daily
    10-02-2012 10:55 AM #5
    I have the same exact issue I cycle the key and its gone.
    Self Made Solutions--Pm pocketrocket:R
    For all you Vw/Audi needs.
    http://http://forums.vwvortex.com/sh...eading-PA-Area
