VWVortex.com - Skoda Octavia RS 125TDI DSG - DSG Issues
    Results 1 to 3 of 3
    Thread: Skoda Octavia RS 125TDI DSG - DSG Issues
    1. 10-01-2012 07:39 PM #1
      Hi This is my first post to the forum. I was hoping that someone could help me with the following issue.
      The car is a 2012 Skoda Octavia RS 125TDI DSG.
      After 9-10 minutes of spirited driving and then backing off to let everything cool down there was intermittently no drive and I was able to limp the car to the side of the road, where it stalled and could not be restarted for some time. After a while, maybe 20 minutes, I was able to restart it and continue.
      This was repeatable and then after cooling down was able to drive on the freeway without any problems.
      An auto scan download follows...
      and I note that the date and time on the fault record of the dsg is out by about 7 years !
      Code:
      Tuesday,02,October,2012,07:49:17:47932
      VCDS Version: Release 11.11.4
      Data version: 20120807
      Chassis Type: 7N0
      Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 69
                72 77
      VIN: TMBEH61Z8Cxxxxxxx
      01-Engine -- Status: Malfunction 0010
      02-Auto Trans -- Status: Malfunction 0010
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      10-Park/Steer Assist -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      69-Trailer -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
         Part No SW: 03L 906 022 RE    HW: 03L 906 022 GA
         Component: R4 2,0L EDC G000AG  5752
         Revision: 13H14---    Serial number:
         Coding: 0001078
         Shop #: WSC 73430 000 00000
         VCID: 79F3D03E30626ED066B
      2 Faults Found:
      000802 - Engine Speed Sensor (G28)
                     P0322 - 000 - No Signal - Intermittent
                   Freeze Frame:
                          Fault Status: 00100000
                          Fault Priority: 2
                          Fault Frequency: 1
                          Mileage: 5581 km
                          Time Indication: 0
                          Date: 2005.14.25
                          Time: 12:11:34
                   Freeze Frame:
                          RPM: 1794 /min
                          Speed: 25.0 km/h
                          Load: 49.8 %
                          Voltage: 13.60 V
                          Idle Stabilization: 0.0°KW
                          RPM: 889 /min
                          (no units): 5.0
      005522 - Altitude Sensor / Boost Pressure Sensor
                     P1592 - 000 - Implausible Correlation - Intermittent
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 1
                          Mileage: 5581 km
                          Time Indication: 0
                          Date: 2005.14.25
                          Time: 12:12:40
                   Freeze Frame:
                          RPM: 0 /min
                          Speed: 0.0 km/h
                          Voltage: 12.62 V
                          Absolute Pres.: 948.6 mbar
                          Absolute Pres.: 1111.8 mbar
                          Temperature: 16.2°C
                          (no units): 3.0
      Readiness: 0 0 0 0 0
      Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
         Part No SW: 02E 300 057 N    HW: 02E 927 770 AL
         Component: GSG DSG AG6     512 3101
         Revision: 05551213    Serial number: 00001203081548
         Coding: 0000020
         Shop #: WSC 73430 790 00090
         VCID: 244DD14AE760C33865D
      1 Fault Found:
      18202 - Selector Lever
                  P1794 - 000 - Incorrect Usage - Intermittent
                   Freeze Frame:
                          Fault Priority: 0
                          Reset counter: 40
                          Mileage: 5587 km
                          Time Indication: 0
                          Date: 2005.14.25
                          Time: 12:27:25
      Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
         Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
         Component: ESP MK60EC1   H31 0121
         Revision: 00H31001
         Coding: 163B601C092900FC680D06EA901F0082350800
         VCID: 7BFFCA36FA5E5CC0747
      No fault code found.
      Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
         Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
         Component: Climatronic   H18 0506
         Revision: 00001007
         Coding: 0000000002
         ASAM Dataset: EV_Climatronic A01010
         ROD: EV_Climatronic_SK35.rod
         VCID: 7DFBC42EEC4A52F04A3
      Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
         Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
         Component: BCM PQ35  H   110 0651
         Revision: 00110 AC
         Coding: 48000AB8E80508C040080080110001E4417000AE526D8560808440040040
         VCID: 3F877E26AEC680E018F
         Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
         Component: Wischer 21021  26  0601
         Coding: 00D7B7
         Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
         Component: RLS 220312 05  54  0403
         Coding: 0730ED
      Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
         Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
         Component: PARKHILFE 4K  H11 0005
         Revision: --H11---    Serial number: 32961208003719
         Coding: 10810F
         Shop #: WSC 13765 790 00090
         ASAM Dataset: EV_EPHVA14SKxxx0000 001001
         ROD: EV_EPHVA14SKxxx0000_SK35.rod
         VCID: 336F22169A8E5480EC7
      Address 15: Airbags        Labels: 1K0-909-605.lbl
         Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
         Component: Q7 AIRBAG VW8   020 2300
         Revision: 05020000    Serial number: 0038PD2VUJ46
         Coding: 0020791
         VCID: 3D7B042E64CA92F00A3
      Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
         Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
         Component: LENKS.MODUL   014 0140
         Revision: FF010040    Serial number: 20120324801314
         Coding: 189A140000
         ASAM Dataset: EV_SMLSNGVOLWSXS A01004
         ROD: EV_SMLSNGVOLWSXS_SK35.rod
         VCID: 7EF9C322E14C49E8539
         Multifunction steering wheel control module:
         Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
         Component: E221__MFL-URO  H07 0012
         Coding: 830000
      Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
         Part No SW: 1Z0 920 843 T    HW: 1Z0 920 843 T
         Component: KOMBI         H05 0608
         Serial number: 00000000000000
         Coding: 110A01
         Shop #: WSC 73430 031 00090
         ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
         ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
         VCID: 499360FEE8023E50B6B
      Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
         Part No SW: 7N0 907 530 M    HW: 1K0 907 951
         Component: J533  Gateway H42 1623
         Revision:   H42       Serial number: 190312F2002134
         Coding: 351303
         Shop #: WSC 23168 959 105002
         VCID: 3A710F32B5E4A5C82F1
      Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
         Part No SW: 5K0 953 234     HW: 5K0 953 234
         Component: IMMO          H05 0608
         Coding: 000000
         Shop #: WSC 00000 000 00000
         ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
         ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
         VCID: EAD17F720DC455481F1
      Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
         Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
         Component: SG EXT.PLAYER H13 0240
         Revision: A1001003    Serial number: 7660888875
         Coding: 010000
         VCID: 2953C07E40421E5056B
      Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
         Part No SW: 3T0 035 680 B    HW: 3T0 035 680 B
         Component: RNS-MID       H60 3984
         Revision: AB001001    Serial number: SKZ6Z7M9077098
         Coding: 04000402000100810000
         ASAM Dataset: ------------------------- ------
         VCID: 2F672E667EA6706088F
      Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
         Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
         Component: Tuer-SG         009 2120
         Coding: 0000756
         VCID: 489565FA3B08C758A95
      Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
         Part No: 1K0 909 144 P
         Component: EPS_ZFLS Kl. 74     3305
         Revision: 00H22000
         VCID: 3777160646F6B8A0D0F
      Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
         Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
         Coding: 0000756
         VCID: 479766C63616C820A0F
      Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
      Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
         Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
         Component: Tuer-SG         007 2101
         Coding: 0000144
         Shop #: WSC 73430 790 1012570
         VCID: 32612712AD945D88E71
      Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
         Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
         Component: Anhaenger     H09 0100
         Revision: 3A001001    Serial number: 00008030077936
         Coding: 0300000100000000
         Shop #: WSC 23168 959 99346
         VCID: 30652D1A63986F98915
      Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
         Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
         Coding: 0000144
         VCID: 336F2216528E5480EC7
      Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
         Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
         Component: TELEFON       H09 2902
         Revision: 1B001001    Serial number: 00007662125928
         Coding: 0201000000010110
         ASAM Dataset: EV_UHVNA A01719
         ROD: EV_UHVNA_SK35.rod
         VCID: 2757C6465E56282040F
      End   ---------------------------------------------------------------------
      Thanks in advance
      David
    2. 10-02-2012 11:25 PM #2
      It must be a tricky one as there are no responses yet!!!
      One other interesting piece of information was that there was no dash lights when either the dsg stopped driving or the engine stopped.
      I think that more information is required , some datalogging needs to happen.
      My guess is to log DSG temperatures, actuator voltages and the main bus voltage.
      I would welcome any suggestions.
    3. 10-02-2012 11:58 PM #3
      What about warranty ?
      major problem - 000802 - Engine Speed Sensor (G28)
      Delete all and check again.
      HOT HOT HOT !!!! MK7 MFSW with CCS https://www.youtube.com/watch?v=JQ8c...ature=youtu.be HOT HOT HOT
