VWVortex.com - Needing some 411 on master cylinder size with brake upgrade and booster removal
    Results 1 to 20 of 20
    Thread: Needing some 411 on master cylinder size with brake upgrade and booster removal
    1. Member What the Fox's Avatar
      Aug 7th, 2012
      Vancouver, BC Canada
      88 fox wgn, 93 F150, 87 1490 Gixxer, KTM300,CRF450X +R, 98 A4 B5
      10-01-2012 09:18 PM #1
      This might be better on the Audi side but will try here first, question is that I need to know the make, model and year of a 24mm MC from an Audi that does not use anti-lock . And I'm guessing at the size of the master cylinder for my brake project that is getting done in two stages (front then rear)
      What I have is Nissan 300ZX twin turbo front calipers mounted. (see pic)
      Removed the Brake booster so I'll be running dirrect pedal to MC
      1st Stage is sizing the MC for just the fronts
      2nd will be for the fronts then the rear (GTI or Scirocco rear brake assemblies added later)
      Any info on something done simular would be greatly appreciated.
      cheers all.
      Oh, added some pics on my progress as however this turns out good/bad.... to answer a question that may come up, I need the engine bay room for my engine install project thus removing brake booster and battery
      cut the MC side for mounting studs only
      [IMG][/IMG]
      cut the firewall side for the mounting plate
      [/IMG]
      Remove the studs, the base of the studs need to be ground (see below)
      [IMG][/IMG]
      discard everything but be sure to keep the shaft/spring/washer and part of the rubber seal(not shown)[IMG][/IMG]
      The shaft needed[IMG][/IMG]
      the MC mounting plate completed, use the circular plate (above pic) with the 2 studs removed as a guide when drilling into the new MC base plate, grind the two loose stud backings so it sits flush in the groove and tack weld.[IMG][/IMG]
      better angle of the MC mounting side[IMG][/IMG]
      last angle of completed base [IMG][/IMG]
      This is as far as I've gotten, if need be I can continue on pics and progress but not sure if this has been posted before... and my main question on MC sizing
    2. Awaiting Email Confirmation 90quattrocoupe's Avatar
      Feb 6th, 2002
      Long Beach, CA.
      90 Audi S8coupe, 90 Fox Wagon, 2010 Jetta TDI
      10-01-2012 11:42 PM #2
      Audis. The B3 10v and the B4 V6 use a 23+mm MC. The coupe Q, 200T use a 24+mm MC. These are all early 90s cars. I don't know about the later ones. Will not matter if they had abs or not, you can still use them.
      Greg W.
    3. Member What the Fox's Avatar
      Aug 7th, 2012
      10-02-2012 03:44 AM #3
      Greg W.[/QUOTE]
      Thank you very much Greg, now I heard not to use ABS MC (just what I read), don't they only have 2 ports which would mean re-tubing?
    4. Awaiting Email Confirmation 90quattrocoupe's Avatar
      Feb 6th, 2002
      Long Beach, CA.
      10-02-2012 08:27 AM #4
      I am not at home right now, so I can't check, but I believe the ports are there just capped or have sensors in them. You can use the early 10V B3 as it does not have ABS. Remember these audis only have one brake line to the rear anyway so you would have to replumb anyway. The outlets on the MC also have different locations.
      You can always use a splitter running to the rear. You don't need two lines, for the rear brake proportioning valve to work. Same goes for the front.
      Greg W.
    5. Member doppelfaust's Avatar
      Aug 15th, 2007
      Pullman, WA
      1988 Fox GL Wagon; 1997 Golf GTI
      10-02-2012 03:18 PM #5
      This has more to do with your booster delete...
      I am assuming the actuating shaft needs to be shortened since the MC now mounts closer to the firewall or will you be able to adjust it out at the pedal?
    6. Member doppelfaust's Avatar
      Aug 15th, 2007
      Pullman, WA
      10-02-2012 04:28 PM #6
      To add to this thread however... The Coupe Quattro MC Greg mentioned looks to be a direct replacement for ours. From what I could find, it's a 25mm MC... VW part # 441 611 021 A
      http://www.autohausaz.com/search/pro...0611%20021%20a
    7. Member What the Fox's Avatar
      Aug 7th, 2012
      10-03-2012 03:40 PM #7
      Quote Originally Posted by doppelfaust View Post
      Thanks again, 25mm is massive (and is the same size of the stock Nissan size)but this is truly a good match by the looks of it but the price ... going to look into a re-man'd unit and post.
      To answer your question on the shaft lenght best I can since this is still new to me.
      The shaft does have alot of adjustment, 2nd the booster had an intermediate shaft I wasn't planning on using. (cutting and a re-sleeve/re-weld would be rather easy) I will post some more for those that need valuable engine bay space.
      thanks again all for the input
    8. Member What the Fox's Avatar
      Aug 7th, 2012
      10-03-2012 04:04 PM #8
      Quote Originally Posted by 90quattrocoupe View Post
      Greg W.
      Thanks Greg, our Foxes use 4 lines but really trying to stay away from buying a tool to for this job and keep my prices in check... I drive in a town where you get "close calls all the time" from bad drivers and our insurance is goverment run... put another way "a stone chip and they would Write off your Ride!
    9. Member bluetoes591's Avatar
      Apr 3rd, 2009
      Vancouver, BC
      1989 Fox Wolfsburg, 1990 Fox Coupe GTI
      10-03-2012 04:55 PM #9
      The Wagner one might fit the bill, for $89 http://www.rockauto.com/catalog/x,ca...,parttype,1836
    10. Member doppelfaust's Avatar
      Aug 15th, 2007
      Pullman, WA
      10-03-2012 07:39 PM #10
      Quote Originally Posted by bluetoes591 View Post
      That's a 23mm MC...
      Looks like Centric has a new option on the Coupe Quattro MC. Shows a 25mm bore...
      http://www.ebay.com/itm/Centric-Part...sories&vxp=mtr
    11. Member What the Fox's Avatar
      Aug 7th, 2012
      10-03-2012 11:09 PM #11
      so many choices in MC and the links are a good start, as far as sizing it's still a guess but I'd rather go slightly smaller and have some pedal travel than larger with a stiff pedal and a tired leg. Guess some of the variable are mounting bolt pattern (to match the fox) and least 4 connection points (brake lines). 25.4mm is what the nissan uses (rear calipers are 2 piston units), 22mm would be on the small size so either 23 or 24. Thanks again and I guess it's going to take some surfing to match. Now our brake line flares are are single or double rolled and sure it's not bubble style?... guess a quick drive to view my parts car would tell me that.
    12. Member bluetoes591's Avatar
      Apr 3rd, 2009
      Vancouver, BC
      10-04-2012 01:19 AM #12
      That's a 23mm MC...
      You sure? It says one inch, which is 25.4mm where I come from.
      That Centric part is $104 from Rock Auto. http://www.rockauto.com/catalog/x,ca...,parttype,1836
    13. Member j-boogie253's Avatar
      Nov 30th, 2009
      Tacoma, WA
      90 Fox, 88 GLI, 91 Jetta (RIP), 98 A4 (RIP)
      10-04-2012 10:34 AM #13
      Yea but if you look at the picture provided on the site, it is stamped with a "23" on it.
      23mm = 0.905512 inches
      Close, but no cigar
      If you were a Volkswagen....who would your owner be?
    14. Member bluetoes591's Avatar
      Apr 3rd, 2009
      Vancouver, BC
      10-04-2012 12:21 PM #14
      Oops, missed that.
    15. Member What the Fox's Avatar
      Aug 7th, 2012
      10-10-2012 11:41 PM #15
      Thanks everyone, got the part from an 1990 Audi 100 Quatro... 23.6mm so it split the difference of what I wanted... downside with committing to these brakes are my brand new Blizzak snows and rims are on the chopping block
      Hopefully I'll move ahead soon on the rest of the fabrication
    16. Member doppelfaust's Avatar
      Aug 15th, 2007
      Pullman, WA
      12-03-2012 03:14 PM #16
      Did you make any progress with the master cylinder mounting? I picked up a stock Fox booster this weekend to cut apart for my manual brakes... I just wanted to see how far you had gotten.
    17. Member What the Fox's Avatar
      Aug 7th, 2012
      12-15-2012 12:51 AM #17
      Sorry for the late response, been on vacay and now doing 12 hr shifts
      As far as progress I'm on hold till winter passes, .. once I put the 11 rotors on, my 13 inch stock rims and new blizzak snows won't fit...on a different note, I was talking to another local foxer here and he mentioned running the master with-out the cross-over lines off the MC... meaning one chamber of the MC runs front only and vice versa for rears... stock is frnt right brakes & left rear... this way you can put in an ajustable needle (proportioning valve) just for the rears.... they said this was supirior but I'm not sure what gains there would be? Anyhow, since were on the same page for omitting the booster lets share some pros and cons...
    18. Member efritsch's Avatar
      Aug 21st, 2002
      Kelowna B.C.
      2004 Golf 2L, 1992 Passat Syncro Wagon, 1987 Fox Wagon (Project)
      12-19-2012 11:45 PM #18
      First of all, what motor are you putting in there that would require you to delete the booster?
      Manual brakes suck and stopping brakes that big with no booster is going to suck even more.
      The reason that the ports on the master are crossed, (Front Right and Rear Left on one chamber and the others on the other chamber) is so that if you blow one line, you don't end up with just front or just rear brakes. It's for control. If you just have rears, you'll lock them up and potentially skid. Same with the fronts although not as bad.
      I am old enough that I only have to be nice when I want to.
    19. Member What the Fox's Avatar
      Aug 7th, 2012
      12-23-2012 02:14 AM #19
      Quote Originally Posted by efritsch View Post
      Motor is 2000 A4 1.8t k04 with upturned turbo manifold, thus battery is in the modified spare tire well (wagon)... intake side was milled to face straight towards the drivers fender, so it was for clearance with-out moving the rad. I drove my buddies ride with a deleted booster and yes, more foot pressure but feedback was unbelievable and wasn't bad at all if you size the MC bang on! thanks for the heads up though but I knew about the safety factor on cross-over, my question was more to the pro's of doing that, not the cons.... truly in 30yrs driving never lost my brakes on any of my cars,trucks or bikes ------> knock on wood hopefully I never eat my words
    20. Member What the Fox's Avatar
      Aug 7th, 2012
      08-28-2013 07:57 PM #20
      Sorry everyone for re-posting such an old thread!
      Due to some major family issues (my father pasted so not on here much) I've put everything on hold, but was curious doppelfaust if you advanced further than I in your booster deleting? Also if anyone is interested I can PDF the adapter template (one dimensional) via e-mail ONLY, photobucket doesn't like PDF's for some reason also pending on ppl request I can detail this further on a new thread? this only works with brakes that are bordering the "why the hell are you doing that" build status.
