Results 1 to 13 of 13
Thread: New turbo for my 1.8t TT!
  1. Junior Member
    Jul 23rd, 2012
    Elizabeth, NJ
    2002 Audi TT quattro (180)
    10-01-2012 11:50 PM #1
    I know the 1.8t has the k03 or the k04, but the k04 is barely any bigger and delivers almost the same PSI. The bigger question is: what other more powerful turbochargers are compatible with the 1.8t without any other mods? Which are the cheapest?
    Can anyone show me websites where I can get a new bigger more powerful turbo?
    Also, what's the most PSI the stock 1.8t engine can handle?
    Thanks!
  2. Member darrenbyrnes's Avatar
    Jan 3rd, 2005
    Minneapolis
    2000 Audi TTq
    10-02-2012 12:30 AM #2
    Quote Originally Posted by 908AudiTT View Post
    Thanks!
    What do you have? 180 or 225?
    The stock engine can handle torque up to 300. Over that and you're just asking for a Clinton, er, bent rod.
    Never underestimate the stopping power of a tree.
  3. Junior Member
    Jul 23rd, 2012
    Elizabeth, NJ
    10-02-2012 07:16 AM #3
    Quote Originally Posted by darrenbyrnes View Post
    I have the 180, but do you know how much boost it can handle?
  4. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    10-02-2012 08:22 AM #4
    A GT30 at 10psi might make 300tq while a k03 can boost 30psi and probably not touch 300tq. Your limiting factor is torque, not boost and boost makes torque.
    Frankenturbo or the Gonzo upgrade turbo package are the only two upgrades that use stock manifold/exhaust that I know of. ATP makes an eliminator kit that just doesn't seem worth it. PM either of those vendors and they can help you out.
    bagsarefordeadhookers
    -TCC
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    10-02-2012 11:29 AM #5
    As much as you can afford, which doesn't sound like much at this point.
  6. 10-03-2012 01:31 AM #6
    Its not specifically about boost, as it is flow. The two go hand in hand but you have to remember boost is a measure of resistance.
    As stated before the stock 1.8T rods are good up to 300 wheel torque.
    The K04 isnt a bad choice, it will make more HP/TQ than a K03 but is limited just the same. A step up from the K04 would be the Frankenturbo F4.
    Here is a link to the Frankenturbo F4...Franken F4
    If your looking for something a little more aggressive, theres always the F23...Franken F23
    If your looking for something even bigger, theres always the 28RS, which is really the biggest turbo you can get away with on stock rods. After rods are upgraded, you could look at the 2871, 30R, 3071, 3076 and so forth.
    A ton of options, just really depends on how much power you want and how many supporting mods you want to throw at the car.
    Verdict Motorsports | on Facebook | New England's Premiere Eurodyne & Maestro Dealer |
    Contact us about: ATP | Franken Turbo | PAG Parts | Schimmel Performance | US Rally Team | Vortech | 034 Motorsport | 42 Draft Designs |
    May 8th, 2009
    Southern Connecticut
    2000/Audi/TT Quattro 180
    10-03-2012 09:30 AM #7
    Subscribed!
    130k on original turbo 18psi! -- Death imminent!
  8. Member Mantvis's Avatar
    Jan 1st, 2010
    Chicago, IL
    2001 Audi TT 225hp, 2003 Audi TT 180hp
    10-03-2012 10:09 AM #8
    Quote Originally Posted by Sales@VerdictMotorsports View Post
    So what turbo APR Stage 3+ is using? 28RS or 2871RS?
    Ive always thought that i had 2871RS but now you made me wonder if i have 28RS
    2001 225Q (Function Car): APR Stage 3+, APR 3' Exhaust System, Brembo Brakes, Koni Suspension
    2003 180 (Form Car): Rokkor Coilovers,Custom Front Single Frame Bumper with A8 Grill Votex Sideskirts, Votex Rearlip, Axis Penta 19' Wheels, 2 Rockford Fosgate 15' Subwoofers
    May 7th, 2009
    10-03-2012 10:18 AM #9
    Quote Originally Posted by Mantvis View Post
    The 3+ kit, which is the only kit for the 225, is a 2871. Did you get the red car running?
  10. Member darrenbyrnes's Avatar
    Jan 3rd, 2005
    Minneapolis
    2000 Audi TTq
    10-03-2012 06:33 PM #10
    Quote Originally Posted by DJmart View Post
    Subscribed!
    Geez, I hope not. I'm north of 160k and have been chipped for over 80k.
  11. Member Mantvis's Avatar
    Jan 1st, 2010
    Chicago, IL
    10-03-2012 07:14 PM #11
    Quote Originally Posted by 20v master View Post
    Hmm i hought it was RS
    Still not runing, sooo much pain!
  12. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    10-03-2012 07:52 PM #12
    Thanks!
    K04-01 is ~ 70hp and 80-100tq gain over a K03s with supporting upgrades (IC/turbo-back exhaust)
    K04-2x ~ 20-40hp more and 30-50tq more than the -01
    Quote Originally Posted by DougLoBue View Post
    Right on Doug.
    PSI is a measurement of restriction. Increase the charge pipe or intercooler volume and you will have pressure drop, but that does not mean that it makes less power. Volumetric efficiency and flow dynamics come into play for power. My supercharged VR6 did 12psi with 800 CFM of flow, the new charger is 1200 CFM. A GT35 is only 700CFM. This is where cams/port work/ charge piping/intercooler efficiency increase velocity of the air entering into the bores.
    From what I remember I thought that the APR kit had a modified impeller to prevent pushing it beyond the limit of the rods ie clipped fins. Been a long time since I heard that, think it was Tony @ EPL that mentioned that.
    As for a side note, a K04-01 will do 270wtq on GIAC+ on FWD. So as max and a few others on here have mentioned, the K04-2x still have plenty of potential. Bent rods and melted pistons are only mild annoyances.
    And having done a 225 K04-2x on a MK4, it is cheaper to go with the FT or PPT 2871 kit over that route. Requires lots of fab/welding/modifying in order to get it to work.
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  13. Member
    May 7th, 2009
    10-04-2012 11:15 AM #13
    Quote Originally Posted by DeckManDubs View Post
    On the first part, I'm sure APR would like you to believe they modify turbos. However, it's an off the shelf 2871R.
    Secondly, I made 276wtq on GIAC on FWD on a K03S with basic 3" turbo back, CAI, and FMIC, and that was on pump gas, no w/m injection, stock intake mani, no cranked WG, etc etc. Well over 300wtq should be possible with a K04-001.
