Results 1 to 11 of 11
Thread: 2.0 coolant expansion tank capcity
  1. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    95 vr6cab,92 honda civic hb si nos b18b, 93 honda civic hb jdm b18c, 1998 honda civic ek four door,
    10-02-2012 01:08 AM #1
    Anybody know how much fluid it can hold???
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-02-2012 03:51 AM #2
    Not much at all. Maybe a liter or so? Or are you asking about the entire system?
    I really suck at smog.
  3. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    10-02-2012 11:45 AM #3
    no just the resevoir .. wat bout a vr6 ?? would u know???
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    10-02-2012 01:06 PM #4
    it the same part, so same capacity. it has no real bearing on how well the system works, other than giving an expansion volume for it. Has nothing to do with cooling ability.
    FS:Sunroof Deflector
    Mar 31st, 2008
    PNW - Oregon
    10-02-2012 03:06 PM #5
    i would say it has a capacity of about HALF a litre..
    gotta remember, you still need air space in the expansion tank so the coolant can expand and not puke out..
  6. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    10-03-2012 12:36 AM #6
    Quote Originally Posted by Glegor View Post
    yes this was my concern.. less air space??im thinking the vr has a bigger container .. if there was a larger resivoir
  7. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    10-03-2012 12:55 AM #7
    it cant be the same part.. and also having the smaller resevoir , my concern is that "am i maxing out my engines cooling system with a smaller container???" I have a vr in a cabrio.. letting alone that the vr are a hot running motor...
    its like having a pot of water, the one with half a pot of water will boiler faster than one with a pot thats full of water.. i dont know thats how i see it...My car doesnt overheat but the hottest my car gets is 212 in 75-80+ degree weather?? i just wanna try and get lower temps if possible
    i am already running a external oil cooler with low temp thermo and low temp fan switch.. i think if it were hotter id be over heating
    but check it out
    2.0 bottle
    vr6 bottle
  8. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    10-03-2012 01:00 AM #8
    The mkIV's use the same tank for all the motors, 2.0, TDI,1.8T and the 12V and 24V VR6's.
    The tank has nothing to do with the cooling abilities of your system. That would be more related to the radiator, water pump and the thermostat you have. A new radiator will bring your system to maximum efficiency if you have any doubts about how it is cooling.
    But, for whatever reason VW used two diff tanks in the mkIII's, I guess they found out later it didn't need to be that way.
  9. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    10-03-2012 01:32 AM #9
    right on i jus wanted to know... i do have a new cooling system.. i forgot to mention its a vrTurbo..
    Mar 31st, 2008
    PNW - Oregon
    10-06-2012 02:51 PM #10
    Quote Originally Posted by dubdriver808 View Post
    do you really think that adding a HALF LITRE (2-3 cups more) capacity to your cooling system is going to help out?
    if you have cooling problems, get a bigger radiator, not a bigger expansion tank..
    you could have a million gallon cooling system capacity, but without a big enough radiator, it will never work right..
  11. Member dubdriver808's Avatar
    Sep 22nd, 2006
    Hawaii
    10-07-2012 11:56 PM #11
    Im not having cooling problems it was jus a question...
