Results 1 to 12 of 12
Thread: Help jump start 16V OEM+ build
  1. Member tinker6468's Avatar
    Feb 2nd, 2006
    Poulsbo, WA
    2001 A4 1.8TQ, 1990 Cabriolet
    10-02-2012 03:04 AM #1
  2. Member tinker6468's Avatar
    Feb 2nd, 2006
    Poulsbo, WA
    10-03-2012 06:14 PM #2
  3. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-03-2012 08:24 PM #3
    I think the lack of answers is because there was no real question asked.
    Basically you said, I stopped working, where do I start?
    Ummm...
    -Josh
  4. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    92 Jetta 16vt project, 89 Jetta diesel(gone), 01 GTI VR
    10-15-2012 01:56 PM #4
    i dont think anyone can psychicly tell you where you stopped building.
    this thread is a waste of time. next time just remember what work you did and didnt do.
    whoah..16vt: http://forums.vwvortex.com/showthrea...-hopeless-quot
    Quote Originally Posted by 90dub View Post
    these pics make me wanna punch baby monkeys
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    11-07-2012 03:36 PM #5
    I really suck at smog.
  6. Member bblume's Avatar
    Aug 8th, 2001
    Colorado
    12-23-2012 07:52 PM #6
    It's not a thread jack if the thread was useless in the first place is it???
    My 9a just spun a bearing....so I'm looking at new main and rod bearings. Motor was allegedly rebuilt not that long ago, so I'm not sure what else will be necessary. This means new oil pump, new water pump, new sensors everywhere, new rings and recently honed. I am going to hot tank it since the pieces of the bearing could've been floating around.
    Pulling everything out on wed.
    Besides resizing the crankshaft and obtaining over sized bearings, is there any other suggestions/ideas/tips?
    92 Gti 2.0 16V ABD/Autotech/Techtonics/BBS RZs
    06 AVANT S-line QMT6 / REVO Stg II+ / Techtonics full exhaust & DP w/ Borla Mufflers / Carbonio / H&R Sports / RS4 rear sway / 034 HFC / VMR Boost Gauge /OEM Rev. 'D' DV / APR HPFP / 640 Mod / BSH PCV Stg II / Devil's Own W/M rocking 3zero3motorsports BOOST FUEL "MEFF" / BBS Style5s
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    12-23-2012 08:43 PM #7
    what caused it to eat a bearing?
  8. Member bblume's Avatar
    Aug 8th, 2001
    Colorado
    12-23-2012 09:05 PM #8
    Wish I knew. I suppose when I get the block out ill know more. Although it looked a bit like the bearings didn't /weren't really snapped in tightly to the rod end caps. Guy that sold the motor assembled it himself....??? Can't really think of what else could've caused it...I had just changed the oil to 20w but ran 10w before. Initially thought it was a lifter, but after replacing all lifters and the sound still existing, I dropped the pan...
  9. Member bblume's Avatar
    Aug 8th, 2001
    Colorado
    12-27-2012 11:02 PM #9
    Block is at the machinist
  10. Member bblume's Avatar
    Aug 8th, 2001
    Colorado
    02-19-2013 09:55 PM #10
    Drove it for the first time today. Tried to keep it under 3500. How long is the optimal break in period??
    The pistons are used, but new rings and refreshed crank with honed cylinders.
    Drove great btw!
    Although the defrost setting on the HVAC is making a crazy buzzing coming out of the drivers side of lower dash. . I'm wondering if its a fuse. .?
  11. 02-20-2013 07:45 AM #11
    Schools of thought differ on the break in. Usually about 1000 miles but valvers never really warm up until about 70k and there is the school of thought that says you should be running it hard (once warm) within the first 20 mi.
    General consensus also says to use pure mineral oil for the break in.
    Sounds like your blower fan resistor is gonna fail soon.
  12. Member bblume's Avatar
    Aug 8th, 2001
    Colorado
    03-30-2013 08:06 PM #12
    Been driving it when the weather is cooperating. God it's fun to have the 16v back on the road.
    Have a oil leak going now, so I'll have to see which seal I didn't quite sort properly. Only other issue was when I took the fuel tank all the way down to empty without knowing it.
