Very simple. Remove the two screws and push "rivets" that hold the exhaust valance on at the bottom, take out the screws that hold the fender liners in. You could remove only the ones at on the backside if you want, then pull it forward out of the way. There are two hidden 10mm bolts connecting the bumper to the quarter panel at that seam. Next is pull the taillights out, then pop the two black pieces off at the top of the bumper, then there will be four screws, two under each one. I hope all of that makes sense.
Get that sh|t!
