Results 1 to 10 of 10
Thread: Will mk2 1.8 8v Head fit on mk3 1.8L 8v Block??
  1. Junior Member
    Sep 28th, 2012
    Ontario
    1997 Volkswagen Golf CL 1.8
    10-02-2012 07:44 AM #1
    Hey guys I have a 97 mk3 1.8 8v Canadian edition and I want to build up my little rare 8v to have a lil more pep , I was looking to buy a port and polished head and then get rid of the mono motronic fuel injection system and replace it with multi port injection, I just need to know if this is possible, I dont want to hear swap in an ABA or Vr6... Can you guys tell me what exactly im going to need to do all of this ?
  2. 10-02-2012 08:08 AM #2
    From all the documents I have read I would say it should fit. Vw did not change much on these 8v at all. Lets put it this way, an 8v head will fit on an 2.0 block. I beleive the only difference in the canadian head is the lack of injector holes.
  3. Junior Member
    Sep 28th, 2012
    Ontario
    10-02-2012 08:19 AM #3
    perfect thanks for the input , am I going to have to change my ECU? to an mk2 one? cause ill be going from single port injection to multi
  4. Member
    Aug 14th, 2005
    Germany
    10-02-2012 10:01 AM #4
    Quote Originally Posted by CanadianDub420 View Post
    . . . I just need to know if this is possible, I dont want to hear swap in an ABA or Vr6... Can you guys tell me what exactly im going to need to do all of this ?
    . . . am I going to have to change my ECU? to an mk2 one? cause ill be going from single port injection to multi
    Yes, very possible, but that is the easy answer. For the rest of the answers to the question it would require knowing just which multi-point system you plan/want to convert over to. Each is either a little or a lot different from the other so exactly what you will require can't be listed yet.
    Mar 31st, 2008
    PNW - Oregon
    10-02-2012 03:04 PM #5
    its a waste of time to NOT SWAP IN the whole ABA..
    the 1.8L TBI engine was junk.. not a performance oriented engine in any way..
    if you must keep the 1.8 engine in there () then just swap the head and electronics from an ABA on your 1.8..
    but for the cost of the whole engine (usually under $200) i would just increase my displacement and torque at the same time..
    in stock trim, the ABA makes like 20 more horsepower.. thats a performance upgrade right there with JUST an engine swap..
    im not even sure if you can run a full motronic injection system on an old CL engine.. they might not have the spot for the crank position sensor, or the 60-2 reluctor ring..
  6. Junior Member
    Sep 28th, 2012
    Ontario
    10-09-2012 10:35 AM #6
    hmmm I see , I saw someone who acutally put the M45 Supercharger on this single injector 90hp engine and after a tune Saw around 161bhp... Can I buy the Eaton m45 kit and bolt it on this engine no problem?
  7. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    10-09-2012 12:12 PM #7
    yes and doubtful.
    FS:Sunroof Deflector
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-09-2012 04:35 PM #8
    Quote Originally Posted by ps2375 View Post
    yes and doubtful.
    I really suck at smog.
  9. Junior Member
    Sep 28th, 2012
    Ontario
    10-10-2012 02:43 AM #9
    http://www.youtube.com/watch?v=1Tdz7vSI6To
    This guy did it .. lol , says bolted right on ran 131hp then after finetuning 161 with no supporting mods.
  10. Member Mtl-Marc's Avatar
    Sep 13th, 2006
    Montreal, QC
    Sciroccos
    10-12-2012 11:05 AM #10
    Yes. I have such a kit FS less the M45.
    Sent using smoke signals.
