Results 1 to 3 of 3
Thread: The power locks in my 02 EV pop top are possessed!
  1. 10-02-2012 11:58 AM #1
    For the longest time I was having issues with my passenger side power window. It would not go down at all. The dealership identified the source as a bad window motor and wanted a sickening amount of money to install a new one. I found and purchased a new/used window motor, but before having a chance to put it in, the window started working again out of nowhere. Now the window works, but the power locks are going crazy. I cannot unlock them using the key fob anymore. I have to manually unlock the driver side door and open it quickly. All the locks proceed to lock and unlock, lock, and unlock. The only way to get them to stop is to hit the lock and then unlock buttons on the key fob and that will stop the incessant locking and unlocking. Does anybody have a clue as to what may be causing this? I tried to see if there were any codes that I could read to determine the problem, but had no luck. Maybe a bad lock actuator? Any assistance is greatly appreciated.
    Thanks!
    Mar 17th, 2000
    Hatfield, PA
    2006 Passat, 2003 Eurovan
    10-03-2012 12:27 PM #2
    The window issue could be frayed wiring. I had intermittent window problems, I moved the switches from one side to the other, still happened occasionally, took it to my mechanic and he found the decaying wire.
    As for the door locks, I had the exact same issue but it was a while ago, IIRC it was the lock actuator and it had a tear or hole in a rubber boot and therefore wasn't able to create the vacuum .
    Ian
  3. Member The Producer's Avatar
    Jun 8th, 1999
    North Vancouver
    2011 Mazda3 Sport, 1993 Corrado VR6, 1993 Eurovan MV, 1982 FT500
    10-04-2012 04:47 PM #3
    http://www.gowesty.com/library_article.php?id=314
    Good info here for troubleshooting the system.
