Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 36 to 70 of 147
Thread: Any worse ergonomics fail than the GM hazard switches from the 1980s?
  1. Member dub01's Avatar
    Oct 15th, 2003
    York, Pa.
    Mk2 forever
    10-02-2012 02:01 PM #36
    Quote Originally Posted by Tokyosmash View Post
    I have a worse one, the switch surround from mid 90's fords broke constantly.
    Not only that, the lock button could be really sensitive. That made it easy to lock the keys in the vehicle with the engine running. We had a delivery driver that did that repeatedly.
    Quote Originally Posted by McBanagon View Post
    I got five bucks on GTE77 getting the last word.
    You're on!
  2. Member Woodski's Avatar
    Sep 14th, 2010
    Southington, CT
    '93 940, '95 SL1
    10-02-2012 02:01 PM #37
    Quote Originally Posted by gti_matt View Post
    I never understood this (70s Ford Maverick):
    What if the passenger is too cold or too hot? Only the driver is able to operate the HVAC?
    you must be trolling.
  3. Member Egz's Avatar
    May 30th, 2002
    Virginia
    2003 Ford Focus 2.3, 2006 Ford Fusion 2.3 Turbo, 2009 Civic EX Coupe
    10-02-2012 02:03 PM #38
    Quote Originally Posted by Seabird View Post
    Back when airbags were still relatively new tech for most companies and made for huge, otherwise unfunctional steering wheel hubs. The horn buttons were often like tiny little Chiclets set on the wheel spokes. Trying to hit your horn in a panic situation (like someone swerving in your lane) was always a pointless exercise in mashing your hand into the airbag with no effect.
    I used to wonder if I'd knock myself out with my own fist trying to hit the horn in a wreck while the airbag deployed.
    I went from a 66 Mustang with a center horn to a 92 Dodge with the buttons, got all lost in that for a while. When I got a Focus, I was back to the center horn, but when it came time to need it, I started looking for buttons.
    I'm glad the horn has found its rightful place back on the center of the steeting wheel.
  4. Member turkey_club's Avatar
    Apr 8th, 2009
    Atlanta
    99 Maxima SE 5Speed
    10-02-2012 02:04 PM #39
    lol duh....only the driver should operate the HVAC!
    99 Maxima SE
  5. Member clutchrider's Avatar
    Dec 10th, 2010
    Connecticut
    2012 GLI
    10-02-2012 02:04 PM #40
    I use them occasionally on the highway on my way home from work. The lane to merge onto 95N from 91S can be somewhat of a blind curve and I approach cautiously. With the sun positioning and people that are literally stopped in the line of cars while the other lanes continue on at 50-60+, it necessitates the use to let the people behind you, or those who may want to come over last minute that your not only slowing down, but stopping due to a backup of traffic.
    I won't keep them on though once the guy behind me gets it and slows down as well. Other than that I don't use them.
    I had an '84 Escort that had the hazard button on the top of the steering column so you have to either reach around or through the wheel to activate it. Also had the horn on the stalk which I found by accident.
  6. Member Tokyosmash's Avatar
    Mar 10th, 2007
    101st Airborne, douchebagistan
    2012 Cooper S Bayswater
    10-02-2012 02:09 PM #41
    When I was a kid, our neighbor had a Maserati Merak. I always thought it would suck to be the passenger and not be able to change the radio station
    Who would want to listen to the radio in one of those? The Merak V6 sounds incredible.
  7. Member 1985Jetta's Avatar
    Mar 11th, 2012
    SC
    See sig
    10-02-2012 02:16 PM #42
    We have 2 Mavericks and a Gran Torino. The hazard switch isn't that hard to operate IMO. The HVAC is on the left side of the column in all 3. Just ask the driver to change the temp.
  8. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    10-02-2012 02:17 PM #43
    Quote Originally Posted by dub01 View Post
    That's not an ergonomic fail though....
    Quote Originally Posted by BostonB6 View Post
    Try not to turn on your hazards 2-3X per trip when using the touch screen on the MFT. To make things worse, it's touch sensitive.
    that's awesome
    Well why not put a central locking button in the center of the car? The switch doesn't do just one door so why put it on the door if the scope of what it operates is all the doors?
    not sure if serious.... because you want to have buttons that you use often within the reach of the driver. That's what good ergonomics is, right?
    Another gripe about the E90 ergonomics. I always find the window switches quite a long reach.
  9. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    10-02-2012 02:19 PM #44
    Quote Originally Posted by choochoo View Post
    At least they're finally on the door. The E30/36/46 had the worst window switch setup ever
  10. Member Bakounine's Avatar
    Jul 15th, 2002
    Ottawa
    '11 GTI; '06 Outback 3.0R; '89 Sierra K2500
    10-02-2012 02:19 PM #45
    THIS
    My old Grand Voyager and Cherokee were like that. Infurating when you actually need to use the horn.
    I also have that GM hazard switch in my Sierra. I must admit it did take me some time to figure it out. Especially how to turn it off.
  11. Member
    Mar 25th, 2009
    in a house
    2012 CC R line, 61 Merc. 220b
    10-02-2012 02:21 PM #46
    i vote everything seen below:
  12. Member addicted2vw's Avatar
    Feb 16th, 1999
    Washington, D.C.
    2009 Volvo C30 T5
    10-02-2012 02:24 PM #47
    The Citroen C4 Picasso we rented in Ireland recently had a similar setup. Climate controls were on the driver's side between the steering wheel and the door.
  13. Member 200HP4dr's Avatar
    Nov 21st, 2001
    NE. OH
    10-02-2012 02:28 PM #48
    Quote Originally Posted by rawk View Post
    Our Classic Mini has the horn in the same location... very strange and unintuitive!
    My Triumph had it too. I found it was quicker to actuate than the button as my fingers were always very close to the stalk.
    Eh, I liked it.
    Chris
    | 2012 Nissan Leaf | 1995 Jeep Wrangler |
    | 2007 Toyota Prius | 1999 Plymouth Voyager |
  14. Member Spell Check Desk's Avatar
    Mar 22nd, 2001
    Timbuk 3
    10-02-2012 02:28 PM #49
    Quote Originally Posted by Lucian1988 View Post
    That is giving me a headache.
    Sent from a cup & a string using a Sharpie
  15. Member jettagli1991's Avatar
    Sep 4th, 2002
    NY
    '91 Jetta GLI, '85 Golf, '68 Beetle 'vert, '95 Legacy
    10-02-2012 02:31 PM #50
    Because it's the driver who would normally use the switch. And it's been on the door forever, why change it? And why make the button tiny and hard to find? I was driving a Fiesta and went to unlock the doors to let someone in, and it took me a while to find the switch that wasn't located where it should have been.
  16. Member 200HP4dr's Avatar
    Nov 21st, 2001
    NE. OH
    10-02-2012 02:33 PM #51
    Quote Originally Posted by Bakounine View Post
    THIS
    Yeah, but at least the buttons on the Chrysler were nice and big and right where your thumbs go.
    Chris
  17. Member 1985Jetta's Avatar
    Mar 11th, 2012
    SC
    See sig
    10-02-2012 02:36 PM #52
    I hate the redesigned headlight switch in our 1986 Cutlass Supreme. It looks out of place to me.
    I wish the put the switches in our 1965 Skylark 4-door sedan elsewhere. Not our car pictured.
  18. Member the flying grape!'s Avatar
    Dec 4th, 1999
    08 528i, 02 VW 337, 93 F-150
    10-02-2012 02:40 PM #53
    Quote Originally Posted by jettagli1991 View Post
    I must admit I was frustrated at first with my E60 when I couldn't for the life of me find the door lock button. It just wasn't where the button is on just about every other car. Then I found it and gave myself the forehead smack.
    Now that I know where it is, it makes sense to have just the one button in a central location, and it's not hard at all to reach.
  19. Member the flying grape!'s Avatar
    Dec 4th, 1999
    10-02-2012 02:44 PM #54
    Quote Originally Posted by Numbersix View Post
    pic snip...
    In the late 70's, Ford decided that having the horn button(s) on the steering wheel was too difficult/accidentally activated/I have no idea WTF they were really thinking. Solution? Put the horn button on the end of the turn signal stalk.
    I recall more than a couple of people slamming their hands on the steering wheel to no effect when trying to use the horn in Fords of that era.
    My old Mercury Lynx had the horn on the stalk. It's fine if you are expecting or planning to honk the horn, but in an emergency situation, you're going to slam your hand into the wheel. And the result is the sound of your hand hitting the steering wheel.
  20. Member
    Mar 31st, 2009
    Puerto Rico, 00961
    2012 Frontier, 2010 4X4, SN 95, 97 ABF MK3
    10-02-2012 02:50 PM #55
    Oh the memories of ripping that switch out one to many times when my ex accidentaly had it on. Also the Super Bettle one had a tendecy to fall into the dash when you push it to turn it off.
    Why yes; that she tropper has sideburns...
  21. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-02-2012 02:51 PM #56
    IMO this is the worst INTERIOR of all time. Horrible, horrible, horrible.
  22. Member
    Mar 31st, 2009
    Puerto Rico, 00961
    10-02-2012 02:54 PM #57
    The beauties of french design.
  23. Senior Member VWVan's Avatar
    Feb 17th, 2000
    Langley, B.C.
    2007 Ford Fusion SE Family Hauler
    10-02-2012 02:56 PM #58
    My god.
  24. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    10-02-2012 03:04 PM #59
    My Mk3 Golf had its central locking button in the center of the dash. It's not a "all cars have always done it this way" thing. Central locking buttons are often placed on the door because it's a door-related function, but there's plenty of precedent for lock buttons in the dash or center console (along with window switches placed likewise).
    I don't practice llanteria
  25. 10-02-2012 03:04 PM #60
    Ugh. This thread is a perfect example of the mkIV/B5 interiors raising the bar for plebeian transportation. My first 5 cars had this switch and I never had a problem with it. As a matter of fact, I still miss the old GM cruise controls too.
    Exactly.
    When you consider that even mercedes didnt have an interior of the same tactile quality at the time it seriously raised the bar for all other makers.
  26. Member gonzo08452's Avatar
    Apr 16th, 2006
    yorba linda, ca
    02 BMW 325 / 97 Jetta/ 2012 Acura TSX wagon / 2007 Trailblazer SS
    10-02-2012 03:15 PM #61
    IMO, this was the worst part of my old a$$ Olds Cutlass Cierra
    I kept breaking the door key
  27. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    10-02-2012 03:15 PM #62
    Quote Originally Posted by AKADriver View Post
    I don't have a problem with the central locking button on the central console, besides it being a small button. but a lack of one on the doors seems like a glaring omission IMO.
  28. Member retro_rocket's Avatar
    Apr 17th, 2002
    Akron, PA
    08.5 Mazda 3
    10-02-2012 03:20 PM #63
    My first car was an 80's J-body. It had that horrible switch
    And my second car was a '96 Probe, and this exact piece broke apart and fell into the passenger door panel Also the backlighting in these switches started to die after a while, which meant fumbling around in the dark to try to lock the doors or put the window down.
    Put it in H!
    2008.5 Mazda 3i - 9/3/08 - present | 1983 VW Rabbit GTI - 4/30/03 - 5/6/11
  29. Member Tokyosmash's Avatar
    Mar 10th, 2007
    10-02-2012 03:25 PM #64
    Citroen?
  30. Member WD-40's Avatar
    Oct 8th, 2005
    Midwest USA
    10-02-2012 03:37 PM #65
    Quote Originally Posted by gonzo08452 View Post
    What?? Those keys were awesome! Especially the all-metal ones, without the plastic ends. They were short, simple, and easy to tell apart.
    At one point, I had three sets of them on my key ring in my pocket. To this day, they were some of the smallest car keys I ever carried - not the giant remote-control monstrosities that "modern" car keys are.
  31. Member Arachnotron's Avatar
    Jun 22nd, 2002
    Friendswood, TX
    2002 Camaro Z28, 2012 GMC Sierra 6.2
    10-02-2012 04:53 PM #66
    My 2002 Z28 has that switch.
  32. Member 1985Jetta's Avatar
    Mar 11th, 2012
    SC
    See sig
    10-02-2012 04:54 PM #67
    Quote Originally Posted by WD-40 View Post
    This.
  33. Member koston.'s Avatar
    Aug 20th, 2003
    Smell you laterville, Bellevue WA
    1996 VW GTI, 2005 Forester XT
    10-02-2012 05:53 PM #68
    VW T4 and Mk3 drivers who have the hazard switch on top of the column.
    Ergonomically, yeah its a pain to hit when in motion. But the feel of the button, and that it lights up in a huge hazard implying way? TOTALLY AWESOME.
    2.0 for life, 224k miles (unless I'm in the 2.5xt)
    Saw the light, now rocking fender gap on RPF1s
  34. Member IdontOwnAVW's Avatar
    Jun 17th, 2004
    Wilmington DE
    Trailblazer SS
    10-02-2012 06:24 PM #69
    Bitching about the lock button on an E90 makes me laugh. There wasn't even a lock button on a 2004-2005 GTO.
    WTB: 2011-2013 Corvette Grand Sport.
  35. 10-02-2012 06:27 PM #70
    I submit this:
    Also when airbags first came out and the horn was moved to the little buttons on the sides of the steering wheel (I think the Aveo still did this until like last year ).
