#106
#107
#108
On the upswing these at least work. On the later temp-matic cars it may have had some big ol' pushbuttons but there was a pretty good chance that depending on what mood your car was in that day it was going to give you the finger and just blast hot air out of every vent... on a 100 degree day...because it can.
Bob
#109
I think you are complaining a bit too much. Why:
1. You have another unlock button. Its on your key fob
2. You can program the car to unlock your doors when the keyfob is pulled out of the receptacle. You have a choice of just the driver door or all 4.
What more do you want?
#110
Hazard placement win: R56 MINI. Right on top of the speedometer...when I had to put them on suddenly on I40 yesterday when the car in front of me wrecked and 3 lanes had to come to a grinding halt, all I had to do was blindly slap the top of the dash.
Pic of accident and my car with hazards:
The dump truck nearly split that Impala in half.
Also...what's up with the blink rate of the hazards changing on some cars depending if the key is on or not? When the key is on, engine running, the hazards blink at normal pace...but with the car off, they blink quicker. What's the reasoning for that?
#111
Didn't it occur to you that the Germans perhaps decided to develop (quite unsuccessfully) sense of humor overnight? All they wanted to do is teach the fat 'Muricans not to eat and drink in their cars but rather sit down in a cafe/restaurant like normal people around the world and enjoy their drink/food.
Yes, I own an E90 and I do agree: the cupholders on this car are a joke. They are not designed to hold anything bigger than a 12 oz drink. Your best bet are soda cans. They fit perfectly and there is much smaller chance of liquids splashing onto you or the center console.
#112
#113
i nominate any switches around the cluster on a discovery 1 or 2
impossible to see around the steering wheel to know which switch is where, and whether theyre pressed or not.
#114
#115
Dave
#116
I really wish everyone would update their location in their profile!
Someone buy my car already!!
Always looking for free firewood to feed my hungry wood stove!
#117
I wonder who was the idiot at Honda/Acura who decided to change the trunk opening mechanism on the Integra from the 94-97 models to the 98-01 models. The previous 94-97 had a simple cable operated hatch you can open from the inside, or you can turn the key and it opens. Then for some reason on the 98-01 models, they remove the interior cable mechanism with a electronic actuator that fails and costs a lot to fix, when I bought my 2000 this year, the trunk was actually working for the first month or so, then out of nowhere I couldn't open it. The only way to open it is to remove the key and use the backup method of turning the key, holding it for a bit and lifting the hatch.
I'll have to try this fix
http://www.team-integra.net/forum/bl...-actuator.html
#118
Alfa Romeo 75/Milano power window switches. They are mounted in the ceiling. I can imagine people pulling up to toll booths, the cockpit a flurry of activity as they try to figure out how the hell to put the window down.Gloriously Italianate.
There's also the GM Tilt column. So many hot rodders love to boast "yeah, it's got a big block, a/c, tilt, cruise, all the goodies..."
But that GM Tilt column is awful! There are three positions available for the steering wheel:
1. Horizontal like a bus (aka, the fat guy setting)
2. Sort of okay but always just a few degrees from where you really want it![]()
3. Sitting in your balls (really, does anyone EVER use that position??)
Yet they used that bloody mechanism for eons. I never understood it.
Classicmotoringllc.com - my new brokerage and consulting business based out of a lavishly converted first floor bedroom in Allentown, PA. I am always looking for quality enthusiast cars to consign, research projects or consultation opportunities. Keep an eye on my page as you can see my blabberings about cars and other such junk in the blog section!
#120
| 2012 Nissan Leaf | 1995 Jeep Wrangler | 1999 Olds 88
| 2007 Toyota Prius | 1999 Plymouth Voyager | 1993 Toyota Previa AWD
#121
I actually got caught by that one when test-driving an old beater Impreza. I came home, mentioned that the car had a bad washer pump, and my wife just started laughing and asked me if I used the stalk the right way (she drives a Forester).
The Citation wasn't the first GM with the vertical radio, the C2 Corvette had one too. It's not really ergonomically bad for a pushbutton AM/FM like that, it just means the presets go top to bottom, volume on top, tune on the bottom. The last year or two of the Citation got the same basic dash layout as the A-body cars (Celebrity, etc) and a standard GM 1.5-DIN radio.
I don't practice llanteria
#122
I've always hated the trunk and fuel door switches in older fords. You had to lean over, open the glove box and then press a tiny button.
#123
Exactly. The only one that makes sense is the temp slider, and maybe the defrost. The bottom two? It's anyone's guess unless they have an owners' manual, or ask on The Samba*.
*Usually followed by "where is the washer fluid reservoir?" and "My wife wants shoulder belts in the back."
#124
I believe it was because they used the same cylinder in every GM product and ran out of key patterns.
The chances of your key working on another car in the parking lot were rising every time another car rolled off the assembly line. Their solution was to issue two keys, so even if you were able to open another GM in the parking lot, your other key wouldn't work in the ignition.
Most simple and inexpensive solution ever.
I can't remember where I read/heard this. I might be wrong, but it makes sense to me.
#125
No, you use the physical key to open the trunk, like you would on most old cars.
No, 2006 doesn't have a trunk button either. And yes, it's a PITA to always use the key or key fob, but it's not really worse than my '63 Mercury was (you had to use the key to open the trunk on that car, as well).
I love cars, but the problem is they are like schroedinger's hobby. They're always in a quantum superstate of being both awesome and a huge waste of time and money... until observation momentarily forces them into one state or another.
#126
The push button wiper controls on the early 90's Geo metro were bad...when you pushed the "off" button to turn off the wipers, the action would often send the HI/LO/INT button flying across the cabin.
Luckily, it's a Geo, so it wasn't hard to reach over and grab it off the passenger floor.
2006 MX-5
2007 Magnum
2006 Mazda 3
#127
Yes, it is fairly amazing how the wheel DOES hide every single one. It seems almost designed that way.
Still nothing is more confusing than an older 911. The controls are just.....everywhere.......and for anything. Plenty of people here could spend an hour in one, and without an owners manual not figure out how to turn on the defroster, adjust the timing of the wipers, or open a sunroof.
Jared![]()
Originally user 22691
"I'm trying to live vicariously through jrod here and my vicarious
life would be better if he had a twin turbo. Or a ****ing pirate
ship." nm+
#128
That photo is missing the two "ejector handles" that go next to the console by the dial for autoheat. Those handles controlled the flap doors for heat. You could do ANYTHING with the dial and get nothing if you didn't pull the flaps open. Conversely you could set the dial to MINIMUM setting and if you opened the flap doors even 1/3 of the way you could roast a turkey in the car.
My father owned an 88 Carrera for 10 years. You will never convince me that the climate system in that car worked well or worked properly.
Jared![]()
ship." nm+
#129
My '05 GTO had similar odd ergonomics:
There was no door lock button--you either used the key fob or pushed down the lock tab on the door, which then caused the other door to lock. The trunk release is a tiny button in the glove box most people wont find unless they look in the manual. Gas filler release was a dash button obscured by the steering wheel. Because the car was originally RHD, the radio controls were flipped and the e-brake was on the wrong side of the shifter. The power operated seats can't be quickly pulled forward to let rear passengers in or out, so you have to wait 15 seconds for the slowest power seats in history to move 8" forward. They also had to move the gas tank to meet US regs and it both cut down on trunk space and made it so the rear seats could not be folded down.
The things like that were what ultimately led me to sell the car, even though it drove very well. 17 mpg didn't help either.
#130
The GTO was basically what happens when you take a 4-door sedan that was specifically designed for one isolated RHD market, then hastily/cheaply convert it to a coupe, then hastily/cheaply convert that coupe to LHD.
Power seats in general are a huge ergonomic fail. Manual seat adjustments - even the Recaro-style recline knobs that people hate on VWs - are always faster. Power seats in a coupe that don't have a manual flip-forward feature are almost inexcusable.
Though my car has the "no power lock button, driver's door lock tab actuates the passenger door power lock" setup and it doesn't bother me. About once a month, though, someone will come on to miata.net with a new '99 or '00 Miata and post something like "I just bought this car but the fobs are missing and the driver's door power lock doesn't work" - the driver's door isn't powered at all and these cars never had keyless entry until '01+.
#131
Yup. Even then I don't think the end product was bad; it was just a late 1990's car being sold in the mid 2000s. The styling didn't help either (I dont mind it but most people think it looks like a grand prix).
At least the interior quality was good--much better than other GMs of the vintage. Was fun to drive after i redid the suspension, too. Just a terrible daily driver/only car, IMO.
#132
I always thought the air distribution icons on my old SPG were really confusing. This was before everyone used the little dude with an arrow pointing to his face, his feet, or both. Ergonomically it was fine, but the icons were![]()
#133
#134
Placement of CD player on 6th Gen Civics, where below it, lies the cup holders which were covered by a flap. If you needed to change CDs and had a drink in the cup holder, you had to remove said drink and close the flap to replace the CD. Then to put the drink back, you had to release the flap to expose the cup holders again. Drove me nuts all the time.
#135
#136
#137
#138
after two years of ownership, i have still not figured out the HVAC controls on my 951
WHY ARE THERE TWO SLIDERS, WTF IS THE DIFFERENCE
#139
I raise all of you ...
The Pontiac G5 trunk release button ... hidden away where you'll never find it!!
#140
Okay, is this what you have?
I'm going to take a stab at it.
On the left you have a recirc button, which closes the outside vent, and below that, a windshield defrost button, which opens the defroster vent.
Then fan speed knob.
Then the sliders allow you to open the upper (dash) and lower (floor) vents to different levels.
Then the temperature knob, then the A/C button.
Disclaimer: I have not driven a post-1985.5 944/951/968. However upper and lower vents are the only functions that aren't present on the other knobs, and it's got up and down arrows.
