Results 1 to 12 of 12
Thread: Speedo not working and ABS Module will not keep coding
  1. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    1992 Saab 9000T,1997 audi A4 2.8l
    10-02-2012 02:28 PM #1
    The car is a 2003 Audi A4 1.8T with a manual transmission.The original complaint was speedometer
    inoperative.Our scan showed a defective ABS sensor left front.We did a pin to pin continuity test and the circuits showed no breaks.We replaced the left front abs sensor and also tried with 2 other new sensors and swapped it with the right front ABS sensor and retested each time.The same code came back and the speedometer is still inoperative.A recheck of the circuit shows continuity to and from the sensor as ok,no shorts or breaks.We ordered a new ABS module feeling that this was the issue but we get the same code and symptoms.Also we can perform the ABS module coding and it accepts it until the key is cycled off then on at which time all the coding goes to 00000.I am now thinking instrument cluster.Any advice would be welcome.Thank you.
    Chris
    Auto scan included below;
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Tuesday,02,October,2012,14:06:50:26373
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAULC68E23A310265 Mileage: 173900km/108056miles
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0003
    Coding: 0016701
    Shop #: WSC 63351 000 00000
    VCID: 74EC692B14DC2AB835D
    No fault code found.
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 H
    Component: ABS/ESP allrad 2328
    Coding: 04275
    Shop #: WSC 12345
    VCID: 2D5ABC4FE7763B70BA3
    2 Faults Found:
    00301 - ABS Return Flow Pump (V39)
    35-00 - -
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    30-00 - Open or Short to Plus
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 L
    Component: A4 Klimaautomat 1116
    Coding: 00000
    Shop #: WSC 63351
    VCID: 2A50B753D6982C485F1
    2 Faults Found:
    00710 - Defroster Flap Positioning Motor (V107)
    41-10 - Blocked or No Voltage - Intermittent
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul KAN 0305
    Coding: 00014
    Shop #: WSC 63351
    VCID: 346CA92B045C6AB8F5D
    1 Fault Found:
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 C
    Component: Airbag 8.4EP 2000
    Coding: 0010607
    VCID: 37769E27452A81A0D0F
    2 Faults Found:
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    012 - Electrical Fault in Circuit - MIL ON
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 00041
    Shop #: WSC 63351
    VCID: 3E788B033A10B0E8139
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 900 L
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 03300
    Shop #: WSC 94708
    WAULC68E23A310265 AUZ6Z0B0330291
    1 Fault Found:
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1311
    Coding: 11838
    Shop #: WSC 94842
    VCID: 72E06F333EC82488271
    Subsystem 1 - Part No: 8E1959801E
    Component: Tőrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E1959802F
    Component: Tőrsteuer.BF BRM 0002
    Subsystem 3 - Part No: 8E0959801D
    Component: Tőrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8E0959802D
    Component: Tőrsteuer.HR BRM 0002
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 040C39EB147C1A3805D
    1 Fault Found:
    00774 - Level Control System Sensor; Left Rear (G76)
    31-00 - Open or Short to Ground
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 F
    Component: symphony II NP2 0051
    Coding: 01001
    Shop #: WSC 94753
    Results of second Autoscan after codes cleared;
    Tuesday,02,October,2012,14:21:43:26373
    69 75 76 77
    Coding: 0016701
    Coding: 04275
    Shop #: WSC 12345
    2 Faults Found:
    35-00 - -
    Coding: 00000
    Shop #: WSC 63351
    2 Faults Found:
    Coding: 00014
    Shop #: WSC 63351
    1 Fault Found:
    Coding: 0010607
    2 Faults Found:
    Coding: 00041
    Shop #: WSC 63351
    Coding: 03300
    Shop #: WSC 94708
    Coding: 11838
    Shop #: WSC 94842
    Coding: 00060
    Shop #: WSC 63351
    2 Faults Found:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    30-10 - Open or Short to Plus - Intermittent
    Coding: 01001
    Shop #: WSC 94753
  2. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    10-02-2012 05:47 PM #2
    I have an update to the above post.The speedo was working for about 15km then stopped.Fuel level when the car came in showed 3/4 full but now shows empty,it does not move at all.The measuring blocks show a combined value of a 3/4 full tank.Also the ABS programming has been successful,it showed up as correct after the last road test with no further input from us.
    Chris
  3. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    10-03-2012 08:52 AM #3
    False WSS faults can be caused by the incorrect ABS module but providing that fault didn't return, these Bosch 5.7 ABS modules require a 3 step coding process:
    http://wiki.ross-tech.com/wiki/index...28Bosch_5.7%29
    Were you completing the Login, Coding and G85 BS in that order within the same diagnostic session?
    In regards to the VSS try logging measuring blocks in several modules. I would start by checking the 01-Engine and 17-Instrument cluster but I haven't looked at a wiring diagram on this one yet and you may have VSS shown in several other modules.
    Dana Marie
    P.S. No Scan = No Soup
  4. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    10-03-2012 10:25 AM #4
    Thank you for the reply Dana.Yes we followed the 3 step procedure and the coding is correct now. The code for; incorrect module coding has not returned.We have the same DTC with the old ABS module and the new ABS module for the left front abs sensor.We have the vehicle in today to pull the instrument cluster to see if there is anything obvious.Observations this morning;code for left front ABS sensor still there(will not clear), fuel level still shows empty(3/4 full),measuring block for speedo shows 361kph(car is stationary).
  5. 10-03-2012 01:08 PM #5
    That speedo condition usually exists when the cluster has been tampered with a very bad China tool for correcting odometer, or even just attempts to glitch read the eeprom.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  6. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    10-03-2012 04:20 PM #6
    Hi Jack,thank you for the reply.Is there any way for me to check if the instrument cluster has been tampered with with VCDS?We removed the instrument cluster(no visible signs of anyone in there before)and checked all the pins,opened it up to look inside and saw no visible signs of trouble.We sprayed contact cleaner on pins and plug,cleaned off and plugged it all back together.Inside up on the lift everything worked;no codes for the left front abs sensor,speedo worked and fuel gauge reads 3/4 full.I took it on a road test and all was fine after 15 minutes,upon returning to the garage and bumping up onto the driveway in reverse there was a chime sound from the dash and ABS light came back on and when taken for a short drive the speedo is not working again.The same code for the left front ABS sensor is back.The customer needs the car so I will not have a chance to look at it again until next Tuesday.
  7. 10-03-2012 05:24 PM #7
    VCDS cant detect this issue unfortunately, or can physical visual inspection unless using a programmer to verify the actual data in editor with a valid compare image.
    This is usually a fault I see for the speedo, and gas gage, due to crap OBD burglar tools from China.
    What we could do, is look at the cluster for you. Maybe possibly fix it, or at least transfer all the keys and data needed to a new, re-man, or used unit from the dump.
    We have seen speedo heads just fail in this cluster unit.
    It got quiet. http://www.youtube.com/watch?v=K8E_zMLCRNg
  8. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    10-05-2012 01:10 PM #8
    I have an update to this car.The car is fixed.We did a wiggle and tap test on all components and harnesses with the VCDS hooked up and monitoring wheel speed.Only when lightly tapping the ABS module did the signal for the left front ABS sensor drop from 16kmh to 1kmh.We did this a number of times.It also set the same code for the sensor and the speedo stopped working.We reinstalled the new ABS module and after a few tries it accepted the coding.I drove it home last night and back in this morning (100km +) and had no problems.No ABS lights or codes and the speedo works. Thank you for all your help.We did notice that as long as the ABS sensor code was there the speedo did not work,clear the code the speedo would work.
  9. 10-05-2012 02:47 PM #9
    What about Mr. Gas gage?
  10. n00b chrisqc's Avatar
    Aug 7th, 2008
    Montreal Quebec
    10-07-2012 06:34 AM #10
    Sorry about that Jack,yes the gas gauge would drop out also.That is also back to normal.
  11. 10-07-2012 06:23 PM #11
    Cool,..... I thought so, just wanted to check.
  12. Junior Member
    Mar 4th, 2010
    Edmonton, AB
    2004.5 GLI
    11-05-2012 11:38 AM #12
    hey..... i've been having issues with my cluster as well...
    very sporadic, and as you mentioned, when it works it'll only work for a short distance then cut out.
    this has been going on for over a year and haven't been able to figure it out.
    We replaced a bunch of sensors, even tried a new cluster.
    When the speedo stops working, the ABS light comes on and so does the traction control light.
    Everything else works including RPMs & gas.
    Think it could really be the ABS module? What should i do?
    The fault that keeps coming up is Speed Sensor "A" (Which i believe is front left wheel)
    Thanks!!
