You forgot rust and water leaks, in addition to the electrical problems and crap engines.
#1
The first car I enjoyed was a brand new 1988 Jaguar XJ-6, British Racing Green, I might have been only 4 at the time but I told the guy I would own one someday.
...but as I've gotten to know that era for Jaguar, I reconize two things: 1) They're prone to electric problems and 2) they're prone to engine problems.
So when I read that some people have swapped smallblock Chevy engines into their Jaguars it makes me wonder, is it worth it?
Take this 1985 Jaguar XJS HE Coupe that's for sale in my area:
It's solid except for the engine, but apart from that it's going for $700.
Now if I bought this, swapped out the engine for a Chevy LSx engine, I might be looking at a healthy 400-450hp Jaguar that would set me back $5-6K (or less).
So I guess it comes back to my question of is it worth it to do such a thing?
#2
All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
#3
Only you can answer that
would likely diminish the value.
I went to the "All British Field Meet" @ Portland International Raceway a couple years back, and was amazed how many 80s Jags were there .. all with original motors (quite a few with the V12). So perhaps their reliability is underrated. Aside from being British.
#4
#5
#6
Engine swapped XJ or XJS jags do not have diminished value, so long as the swap isn't a hack job. In fact, a properly done swap will increase the value.
That being said, the cars themselves are not as bad as made out to be, so long as a few simple upgrades are done (this is speaking to the 6 cyl XJs specifically, as the XJS cars have different needs). I've had a couple mid '80s XJ6s and other than rust, they were good cars. Parts are easy to come by, and fairly cheap, so long as youre not trying to make them showroom new again (and any car can be that way. As soon as you try to make a used car new again, it costs a good chunk of money).
I love cars, but the problem is they are like schroedinger's hobby. They're always in a quantum superstate of being both awesome and a huge waste of time and money... until observation momentarily forces them into one state or another.
#7
What specifically is prone to failure on the V12 models?
#8
if the bodywork/trim and interior is in good shape ; and the suspsion is in tact, you can buy an inexpensive conversion kit to put chevy power in it.
most of the electrical gremilins are rooted out with the conversion, sans the climate control system, and most of those parts are GM based.
Larry
#9
I really like this one. And its already V8 swapped.
http://akroncanton.craigslist.org/cto/3293913286.html
I'm considering parting out my 350/700R4 equipped G20 and swapping that powertrain into an old Jag. Its TBI, so it should be a breeze to wire.
Another interesting one in my area.
http://akroncanton.craigslist.org/cto/3248466927.html
Chris
| 2012 Nissan Leaf | 1995 Jeep Wrangler |
| 2007 Toyota Prius | 1999 Plymouth Voyager |
#10
#11
Most of what you can see herre:
Seriously, the engines were so band-aided with emissions equipment that they had a lot of electronic and vacuum failure points.
The cooling system is adequate but needs to be maintained; any overheating can result in severe damage like dropped valve seats, blown head gaskets, etc... And from JagLovers, this bit of info:
"The V12 is a big engine installed in a fairly small engine bay resulting in a lot of heat trapped especially after shutdown. Not shutting down the car immediately after a hard run helps reducing chances of heat damage to ignition and injection components. Until 1989, Jaguar used Lucas electronic ignition, first the same OPUS system used in the E-type and after 1982 a Constant Energy Ignition system. Despite the common jokes related to Lucas, both systems are reliable but shared a common problem with the distributor centrifugal advance having a history of seizing resulting in power loss and overheating. In 1989, Jaguar switched to a Marelli electronic system using crank sensors to adjust timing (no more frozen centrigugal advance) and a single distributor with a separate coil for each bank of the V12. Because each bank uses a separate coil, it's possible for one bank to fail while the other will still be running; the engine will obviously lack power but still run smoothly. If the driver doesn't stop the car right away, the fuel injection keeps sending fuel to the dead bank and the unburned fuel sets the catalytic converter on fire... Periodic inspection and replacement of the cap and rotor is key to avoiding this problem although there are a number of modifications which can also eliminate the risk. Regular inspection of fuel injection hoses is equally important, there is nothing like fuel spiling over a hot engine to ruin your day!"
#12
#13
Ooh. This one is tasty!
http://cleveland.craigslist.org/cto/3219972533.html
Chris
#14
#15
Larry
#16
#17
Larry
#18
For $700 buy it and put in in your living room as an art instalment. Otherwise, hit up Jags that run.
http://www.jagsthatrun.com/Pages/Jaguar_V-8.html
#19
If you have kids you can use it in the yard as a play car.
A coworked of mine had an 86' or so XJ6. It was constantly in the shop, average was every 2-3 weeks. This was back in the mid 90's, so it was only 10 years old at the time. The body was great, but man, electrical problems galore. He must of put the owners kids through college.
Before that car he had a Dodge Dart. He kept potatoes on the dash to supposedly help keep the fog and condensation down
I worked with him until he was 75 or so.
RIP Derrick![]()
#20
actually that was a series III and there were far more reliable than the earlier series II's. most jag's were never maintained as they should have been, and pretty much after the series III they were all junk. the XJ40's that replaced them was complete junk. if he was having electrical issues, I'd guess it was more to do with someone not familiar with the quirks of jag wiring (use of diodes to manage multiple devices powered from a single circuit), etc. if you knew what and were to look for issues, then working on them wasn't that bad.
I maintained several late series III cars for customers (back when I was a porsche tech) as the dealer I worked at stretched the rules for certain customers.
Larry
