VWVortex.com - no start sometimes when warm cranks just fine
    Results 1 to 6 of 6
    Thread: no start sometimes when warm cranks just fine
    1. 10-02-2012 05:28 PM #1
      1998 MKIII Jetta vr6 starts fine when cold. cranks but no start sometimes when engine is warm. Starts fine with no changes when engine is cold again. No errors codes. =^..^=
    2. 10-04-2012 11:27 PM #2
      Quote Originally Posted by jaxcat View Post
      I think I have a fault in my crank position sensor. From everything I have read it sure sounds like the most likely culprit. I hate to replace good parts but I do have a 150K miles on the car and the part time malfunction when the car is hot and works fine cold doesn't point to many other places. I will come back and let you know if I invested wisely or if I am sporting a new crank sensor and still looking for the cranks but hot not start gremlin. =^..^=
    3. 10-06-2012 10:21 PM #3
      What did you use to scan the engine ECU? VCDS?
    4. 10-24-2012 04:39 PM #4
      Frontal Lobe of my Cerebral Cortex. I appears to have worked. =^..^=
    5. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      10-24-2012 05:02 PM #5
      You dont need to guess at the CPS as you can test it to see if its wack. Do a google search on testing vr6 CPS and you'll well on your way.
      But yes I would suspect it to be your issue. Next time it happens see if you have spark when cranking.
      diesel life cause cold feet are fun....
    6. 10-26-2012 12:55 PM #6
      I believe this issue has been resolved. As this was my first Vortex post I am pretty sure I did a poor job of getting it where it might help anyone. If any of you can help improve it please be my guest. Thanks, =^..^=
