Results 1 to 3 of 3
Thread: No communication with k-line with engine running: ALH engine swap
  1. Member hans j's Avatar
    Nov 29th, 2002
    City 'O Salt
    2001.5 S4 - 1986 Syncro Westfalia TDI - 1981 caddy ABA - 1980 caddy EV - 1978 bunny - 1973 T-181
    10-02-2012 08:55 PM #1
    I'm at my wits end here and without being a software engineer, I can't figure it out.
    Engine is a 2002 ALH TDI with a 038 906 012 FF (or FD, I have two ECUs to work with). IMMO3 disabled via full version VAGdashCAN on both ECUs. Vehicle is 1986 VW syncro westfalia
    VCDS (v11.11.4) USB-HEX-CAN communicates just fine key on, engine off. I scoped the k-line with our picoscope/breakout box and it has a normal waveform.
    When I try to communicate with the engine running, VCDS comes up with too many communication errors. It usually manages to pull the ECU part number off and once pulled the full information and lit up the buttons. When I scoped that, the k-line voltage rises up to alternator voltage ~14v but instead of the waveform dropping slightly to almost ground while communicating, it falls on it's face, full ground signal for a significant amount of time. Only once while VCDS is trying to open the ECU does it give me a normal waveform (very short amount of time). So it's obvious I have an issue with the k-line.
    CAN high/low lines communicate pretty much the same with engine running or not.
    I have tried adding in another ground to ECU connections, unplugging the wire to the front DLC, different ECUs, multiple tools (VCDS, superVAG, Launch, I'll try our 5052 once the battery charges) and everything says the same thing.
    Anyone have any insight into this? I scan cars all day long at work with my VCDS cable, never any issues so my hardware on my PC is correct.
    Utah Imports - 858 South State SLC UT - 801-533-9600
  2. Member hans j's Avatar
    Nov 29th, 2002
    City 'O Salt
    10-03-2012 09:46 PM #2
    Looks like I can communicate a little longer with generic OBD2 function, but it isn't giving me any readings to look at. The pull down menus are blank. Seriously, any ideas? I really don't want to ruin another ECU trying stuff like I did tonight I also really don't want to break in my new engine at idle because I can't time it and adjust the QA...
  3. Member jetta ,97's Avatar
    Jul 25th, 2009
    Dallas (Plano),TX
    Jetta TDI 97 & 99.5
    10-11-2012 10:21 PM #3
    Something is bugging K-line.
    Simple solution ,
    run K-line direct form ECu to OBD and it will work.
