VWVortex.com - Shift knob broken
    Results 1 to 7 of 7
    Thread: Shift knob broken
    1. Member zachhillmann's Avatar
      Jun 9th, 2011
      Chicago, IL
      25th Anniversary GTI
      10-02-2012 11:08 PM #1
      The top black piece of my shifter rotates freely on my shifter. Any DIY on this or do I need a new shift knob? I already tired a few searches maybe not the correct keywords
    2. 10-02-2012 11:35 PM #2
      this might work... i know it works on 5 speed mk4s
      you will need either a ziptie or better a small clamp the screw type.
      pull the boot up so you see the bottom of the plastic shift knob
      then either ziptie or put that clamp on the bottom of the plastic piece there might be a metal piece there already just remove it or try and clamping it down more.
    3. Member zachhillmann's Avatar
      Jun 9th, 2011
      Chicago, IL
      10-03-2012 12:07 AM #3
      Sorry maybe I wasn't clear just upper half of the golf ball is rotating
    4. Member leftygibsonplyr's Avatar
      Feb 15th, 2006
      Plainfield, IL
      2012 CSG Golf R (His), 2012 PG Beetle (Hers)
      10-03-2012 04:30 PM #4
      Super glue?...
      - Jon
    5. Member zachhillmann's Avatar
      Jun 9th, 2011
      Chicago, IL
      12-16-2012 07:01 PM #5
      Finally decided to take a look at this after washing my car. if you take a pic or a small flat head screwdriver and pry off the GTI emblem at the top(its only lightly glues on) it will reveal a 3mm allen-head bolt. simply tighten that and the top and bottom haves of the golf ball will stop rotating. wait re-glue you gti emblem until after you re-install the knob so you can make it straight! hope this helps!
    6. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      Algeria.
      THE IY AWD BT 20TH and Ti edition RS4
      12-17-2012 01:00 AM #6
      Good to know, sometimes bolts just come loose
    7. Member zachhillmann's Avatar
      Jun 9th, 2011
      Chicago, IL
      12-17-2012 09:14 AM #7
      yup I'm just glad it was an easy fix. I also epoxied it down because I am never going to do this again.
