Results 1 to 6 of 6
Thread: aba turbo set up
    Sep 20th, 2004
    se pdx
    87abat drag gti, 95 jetta beater
    10-02-2012 11:14 PM #1
    For sale aba turbo set up
    Comes from a obd1 87 gti,
    Custom short runner intake, obd1 aba throttle body
    #42 pound injectors just had them completely cleaned and flowed
    Cast exhaust manifold, heli coiled for stage 8 locking fastners which are included
    T3t4 godspeed turbo with internal waste gate and custom adaptor to 3in down pipe
    3in custom down pipe fit to 87 gti comes with two o2 sensor bungs welded in and had 3 in v band on lower end.
    Obd1 aba head with tt 260 cam, light port and polish on exhaust side.
    Dual stage boost controller with toggle switch set at 12psi low and 22 psi high, and adjustable.
    Obd1 aba computer with c2 #42 chip installed along with wiring harness from fuse block to engine and ecu,
    3in maf sensor with 3inch intake tubing,
    Along with other odds and ends, oil supply and return lines, cut off valves and what not.
    This is a complete set up bolt on this set up with stacked gaskets and arp studs and push 20 psi daily, which I have done, car is making 280 hp and 300 ft pounds at 5200 ft elevation when I lived in slc, down here in Portland it feels even stronger.
    I will also have a set of obd1 pistons and rods for sale soon.
    Whole package 2000obo,
    I really don’t want to breaj it up at this point but if there is enough intrest I might.
    Either pm me or text 435-225-4958 pics to come.
    Thanks ryan
    Sep 20th, 2004
    se pdx
    10-02-2012 11:32 PM #2
    Sep 20th, 2004
    se pdx
    10-02-2012 11:34 PM #3
    Intercooler is not included in sale, I can include piping for that set up if wanted,
    Also have new vr6 after run pump, and small radiator for water to air set up, along with obd1 o2 sensors, harness will come with all sensor I even have a distributor and coil to go with it.
  4. Member ((a.v.))mk-1's Avatar
    Dec 9th, 2010
    salt lake city, ut.
    1984 rabbit GTI, 95 jetta, 2011 yaris :)
    10-06-2012 12:24 AM #4
    Are you willing to sell just the short runner?
    aww mah gawdz teh b0rk3n sahspenshun yoo roond et~
    Sep 20th, 2004
    se pdx
    10-06-2012 02:01 AM #5
    i have another guy interested in the short runner but as of now i dont want to brake up the set up.
    im looking to sale all this so i can put the money towards my new bigger build
  6. Member ((a.v.))mk-1's Avatar
    Dec 9th, 2010
    salt lake city, ut.
    10-06-2012 02:29 AM #6
    Understood
