Welcome to the Thunderdome
Idle isn't adjustable at all.
Whenever the throttle body is cleaned, disconnected, etc, you must perform an adaptation (effectively an idle position learn on AEG) with VCDS or an OE-capable scan tool. That only teaches the ECU the throttle stops though, there is no manual idle speed adjustment. The ECU adjusts as necessary.
