Results 1 to 3 of 3
Thread: Surging Idle..
  1. Member Run_That's Avatar
    May 15th, 2009
    Sturgis, MI
    10-03-2012 12:31 PM #1
    Here's what I know:
    - Automatic B3
    - TB is clean
    - Airflow plate is clean
    - ISV is good
    - TPS is good
    - No vacuum leaks
    - No broken wires
    - Car has EGR (cali car)
    - If I unplug the yellowish/tan plug (WOT??) the idle goes to 1500 and holds.
    - Doesn't change if I unplug the CTS, ISV, CSV, EGR, O2 sensor, or anything else.
    It runs fantastic! However, when in park or foot off of the gas, the idle surges up and down a few hundred RPM. I swapped throttle bodies hoping it was a TPS and it wasn't that.
    Any ideas?
    '91 GTDECO
  2. Banned ellocolindo's Avatar
    Jan 14th, 2010
    10-03-2012 10:32 PM #2
    have you had the car scanned for codes?
  3. Member Run_That's Avatar
    May 15th, 2009
    Sturgis, MI
    10-04-2012 08:40 PM #3
    Nope.
    Anyways, it ended up being a loose-ish connection at the fuel distributor potentiometer on the PS top of the fuel distributor.
    '91 GTDECO
