Looking for advice from the 4mo crowd....
Since the 4mo (or maybe all VR6's?) uses larger rotors, I'm concerned about clearance. I've got an old set of 16" Mille Miglia Spyders from my B5.5 that I KNOW won't fit. Looking at the clearance on the 18" Daytona's that are on there, I seriously wonder if a 17" rim will fit. Any thoughts or recommendations would be appreciated!
I'm starting to search CL for some rims.... Picked up a mint set of OEM rims for my Treg for $100 a while back - now my winter setup for the Egg. CC needs the same treatment.
Thanks!
Might get more responce on the Passat forum. IRK, my ex used to put 16" Beetle wheels on her 225 TT Quattro... I think that the GTI guys also run a similar set-up.
I am 90% sure your gonna say 17 are your safe bet. that what I got coz I think I read it somewhere
2010 VW CC 3.6L 4motion - STOCK
2000 BMW ///M Roadster - Dinan Tuned
Gone - 07 MKV GTI - Stage II unitronic, Full Eurojet TBE, EBC slotted rotors & pads, neuspeed intake
16" won't clear the 345mm front brakes on VR6's
need 17" min
2008 Passat wagon, 2.0T 6MT with mods
Other Rides:
- 2013 Cannondale CAADX-6
- 2010 Specialized Secteur Elite
- 2009 Specialized Rockhopper Comp 29-er
I too am looking for a winter set of wheels. I like the look of my 18" Daytona's for the summer but want to drop down to 17" rims for the New England roads in the winter. I was considering the 17x7.5 OEM Monte Carlo's that I have seen on some Passats.
Has anyone used these? I know the offset is 47 vs 41 for my Daytona's.
a cc IS a passat in sexier sheetmetal
Other Rides:
#11
I was about to buy some conti DWS tires for my 18" Daytonas and run them all year long but found a set of used Daytonas with Michelin pilot alpins! Other than not having tps mounted I couldn't beat that for a winter setup. Good luck in your search! It can be done.
#14
They'll fit!
They'll just be narrower (only 7.5" wide) and combine that with a high offset (of 50), will sit more inward (15mm) than your stock wheels do....which is fine
'13 Passat VR6
#15
I ended up getting a set of Monte Carlo 17x7.5 rims and they do fit! They are quite close though. There is maybe 3/16" clearance between the inside edge of the rim and the calipers. Be careful with wheel weights they get really close! I will have to keep an eye on this with snow and ice.
These rims have fatter spokes than the Daytona and the outside surface of the rim is less concave, flatter. I am hoping since the outside edge of the rims are pulled in slightly it should keep more of the white salt off the sides of my black car!
