Results 1 to 11 of 11
Thread: 1995 Golf GTI VR6 alternator help?
  1. 10-03-2012 01:15 PM #1
    I have a car as stated above. I am replacing the alternator in it. The old one came out hard and now the new one is going in hard. Is that just the way they are made? Or am I missing something? Thx
  2. 10-03-2012 03:22 PM #2
    Take the alt out. Then put the bolts in the alt take a hammer and start hitting the top of the bolts. Then it should go in nicely
  3. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    10-04-2012 03:21 PM #3
    Quote Originally Posted by brian500 View Post
  4. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    10-04-2012 04:21 PM #4
    NOOOOO!!!!!! there is a gentle way of doing this, get a spare bolt with nut of the same thread pitch. Put bolt in hole where it normally goes on top, before you start to thread the bolt into the nutplate on the alternator take the nut and put it between the bolt and nutplate, spin nut to top of threads, then start threading the bolt into the nutplate. As you tighten down the bolt the but will push the nutplate back so the install is easier. Use a deep well socket on the ground for the bolt to go into, unless you have a vice.
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  5. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    10-04-2012 04:28 PM #5
    Clean the crap off the mating surfaces. Lube it install.
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  6. 10-04-2012 05:31 PM #6
    Quote Originally Posted by lathan View Post
    The tension sleeve has closed/tightened up. Just push it open with a C clamp and some sockets to permit the sleeve to move back into the alternator frame.
  7. 10-04-2012 06:14 PM #7
    Just screw the bolt into the sleeve couple of taps with a hammer and your good to go.
  8. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    10-05-2012 05:40 AM #8
    Maybe it's just me, but I am completely against using a hammer on an alternator
    Boo ya tapatalk! If you haven't got it yet get it!
  9. 10-05-2012 09:06 AM #9
    Thx guys I'll try those
  10. 10-05-2012 09:11 AM #10
    Well you are entitled to your opinion.
  11. 10-05-2012 09:14 AM #11
    It is not brain surgery. When the alt is out all you have to do is take the the bolt screw it back in the sleeve a couple of taps on the bolt to press in the sleeve and thats it.
