Results 1 to 4 of 4
Thread: Any nova locals in here??
  1. Member Noodleboy's Avatar
    Mar 2nd, 2006
    Culpeper va
    1990 corrado g60(gone) 1990 corrado g60(project) 1991 gmc sonoma(tank)1984 rabbit vert
    10-03-2012 02:21 PM #1
    Looking for someone local to culpeper warrenton area. 1984 rabbit convertible 1.8 jh CIS.
    I believe what you really learned is... bring lube next time you start a fight in the corrado forum
    Aug 15th, 2007
    Virginia
    G60 on CIS-E and a bunch of other VW's
    10-19-2012 02:45 PM #2
    For what?
    PM me if you have a G60 (G Lader) and don't want it.
    Here is why
    http://forums.vwvortex.com/showthrea...-CIS-E-G-Lader
  3. Member Noodleboy's Avatar
    Mar 2nd, 2006
    Culpeper va
    10-19-2012 09:43 PM #3
    Crank no start or start no idle. Timing is correct firing order is correct fuel injection system has been completely gone through. Idk if it needs adjusted. Ignition box and wiring harness has been replaced. I'm at my wits end.
  4. Member
    Aug 15th, 2007
    Virginia
    10-23-2012 04:39 PM #4
    Did you check the Lambda fuse?
    I had the same issue and IIRC #21 was blown for no good reason.
    Is your coil to valvecover ground hooked up.
    That energizes the Hall and ignition.
    Here is why
