Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 36 to 70 of 111
Thread: Tablet install progress
  1. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-05-2012 10:10 AM #36
    What did you get banned for?
  2. 10-05-2012 11:30 AM #37
    Quote Originally Posted by bots4444 View Post
    Trolling :p
    The noobs are destroying that forum I post lots of memes and it makes them a little butthurt
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
  3. Member jmj's Avatar
    Feb 6th, 2001
    MA
    06 GTI
    10-05-2012 05:03 PM #38
    I went with this tablet because I already have the Samsung Galaxy SII phone with unlimited data....so it will make it as seamless as possible.....in theory. Ill just tether my phone to the tablet for internet.
    That's a good idea. I'm curious to see this come together.
    Quote Originally Posted by Taipei_E92 View Post
    If you generalize...you are always going to get it wrong.
  4. Member Thagodeus's Avatar
    Nov 13th, 2010
    Haymarket, VA
    07 RS Rabbit
    10-05-2012 05:17 PM #39
    That would be sick for car trips, plug the phone into the cig lighter so it doesn't die, and run the tablet on the Internet for the whole drive watching Netflix and such
    Tapatalkin'
  5. 10-05-2012 05:41 PM #40
    I gotta ask as far as size is that pretty comparable to double din or will ounting that be a bit different
  6. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-05-2012 09:05 PM #41
    It is actually the exact size of a double din. I was afraid there would be some fabrication that needed to be done but there is none. It fits perfect and there will be no fabrication needed beside the plastic welding it into the front face plate
  7. Junior Member
    Jun 3rd, 2009
    Tampa, FL
    2006 VW Jetta TDI
    10-05-2012 09:15 PM #42
    Well us "IT people" always need some project to work on. If this works, its gonna be sick!
    IT people here, I can confirm he is correct. ;-) we always need something to break and then fix.
    Sent from my ADR6425LVW using Tapatalk 2
  8. 10-05-2012 10:29 PM #43
    Quote Originally Posted by myterribear View Post
    Sad but true lol
  9. Junior Member
    Jun 1st, 2012
    Boxborough MA
    2010 Candy White Jetta TDI
    10-06-2012 11:57 AM #44
    I like where you're going with this, but one question from a practicality standpoint: how do you plan on power cycling the tablet when necessary? I assume you're going to have to pull the dash
  10. Member RobbS's Avatar
    Jul 13th, 2011
    Harrisburg, PA
    Bagged 2006 VW Jetta GLI, 2000 VW Golf (Stage 3, K04)
    10-06-2012 12:05 PM #45
    Quote Originally Posted by themortalwombat View Post
    This was one of my questions as well. That and easy access to volume control.
  11. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-06-2012 11:40 PM #46
    The volume control of the tablet will be controlled by the headunit in the arm rest. I was thinking of porting the volume control of the headunit to one of the dead buttons where the esp button is....depending on if its a pain in the ass to adjust from the arm rest. For power cycling im going to use the app called Tasker. I will program it so that when the tablet senses voltage going to the tablet (aka the car turning on) it will wake the tablet and begin charging via the usb connection. When the car is shut off the tablet will sense no more voltage and will put that tablet into standby. Does that make sense?
  12. 10-07-2012 10:38 AM #47
    I think we are talking more about actual power cycling turning the tab on or off or rebooting if needed
  13. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-07-2012 01:47 PM #48
    Im going to port the power button as well to one of the dead buttons
  14. Member
    Jun 16th, 2011
    2007 Rabbit
    10-07-2012 11:19 PM #49
    I actually thought about doing this with a playbook but don't have the know how.. Looks good hope everything works out
  15. 10-08-2012 03:49 PM #50
    My buddy was going to put an HTC Flyer tablet in his Lincoln LS. I don't know if he ever finished it though. Anxious to see the final results! Gonna look clean. Also, if you have a Samsung Android phone, check out FoxFi. If you don't want to root your phone, it's a free hotspot app. I've had it for a couple months now and at&t hasn't said anything yet. I recommend it or as others have mentioned, xda has a ton of info.
  16. Member jmj's Avatar
    Feb 6th, 2001
    MA
    06 GTI
    10-08-2012 05:27 PM #51
    Not to seem too much like a blackberry fanboi, but if you have a BB phone you can use the Bluetooth "bridge" to access the 4g network with the Playbook without any additional fees for tethering. It does use your data just as if you were using the phone, though. AT&T disables this feature (not the entire bridge, just the ability to access the 4G network through it), but there's a very well known site that has a workaround download that gets around the block. The latest playbook OS automatically uses wifi to stream data if you're bridged and you connect to a network, while the bluetooth connection maintains the connection with the phone.
    I realize the OP already has the Samsung hardware, but perhaps someone else might try this with a Playbook. The 16G is being discontinued, so they're going pretty cheap. Even the 64G can be had for about $250. I would guess that someone could use the HDMI output for HD rear seat video output?
  17. Member jojowasher's Avatar
    Apr 17th, 2006
    Calgary, Canada
    2007 CW GTI
    10-08-2012 09:23 PM #52
    I so want to do this as well, was thinking the playbook just cuz they are so cheap, and since it is just playing music and the basics, should be ok.
    Jojo
  18. 10-08-2012 10:13 PM #53
    I was considering using a Nexus 7, but I'm not sure what software to use for a good UI.
  19. Member
    Jun 16th, 2011
    2007 Rabbit
    10-09-2012 12:38 AM #54
    http://crackberry.com/check-out-cool...ember-mark-rpp aside from the car, the hinged access is a neat touch
  20. Member jmj's Avatar
    Feb 6th, 2001
    MA
    06 GTI
    10-09-2012 10:17 AM #55
    I saw that video a while back. You're right; the tablet install is great, but the rest of that car is, how should I say it, "over the top"?
  21. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-09-2012 11:48 AM #56
    I really wont have any reason to remove the tablet. I don't use it for anything now as it is...and with having a hard drive connected to it, I will be able to remove that if I need to add anything. They only time I would have to undo the dash to take it out is when I have to power cycle it, which will be barely ever.
  22. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    REVO STGII+ 06' PG GLI, C2 97' GLX
    10-10-2012 02:24 PM #57
    Didn't see it mentioned. Where did you get the bezel? I was thinking of the same thing except using a 4-channel amp for power. I'd add a BT OBD2 fob for engine monitoring as well.
    Chapter 11 Dubs
    Revo STGII+ Kegerator
    Quote Originally Posted by jhines_06gli View Post
    I fix Pete's car to keep cold, cheap beer flowing for the club at shows.
  23. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-11-2012 10:37 AM #58
    I got the bezel from Crutchfield.com. Fits in there perfectly. Im watching a BT OBD2 fob on ebay right now too haha. That would be really cool to have
  24. Member tonsef's Avatar
    Dec 9th, 2011
    Brunswick, Ohio
    07 GTI FSI, '77 Diesel Rabbit, '78 8v Rabbit
    10-11-2012 12:46 PM #59
    Subd! Can't wait to see the final product
  25. Member BIGJEFF64's Avatar
    Aug 8th, 2011
    Gainesville,FL
    MkV 2008 Jetta S
    10-11-2012 12:56 PM #60
    me likey
    great install
    AMBER club
  26. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-11-2012 01:00 PM #61
    Right now im waiting on the low profile hard cover I ordered for it from ebay. Damn China takes forever to ship stuff. Hopefully I should get it in another 10 days, and can keep posting pics of the progress.
  27. 10-11-2012 09:19 PM #62
    That + torque app + free widget pack for said app = a very nice homescreen :p
  28. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-12-2012 04:26 PM #63
    Already bought Torque and Tasker for the tablet, so im ready to go!
  29. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-25-2012 01:39 PM #64
    Ok guys here is a quick, small update on what is going on with this install. The slim case finally came in from China (that only took a month). I decided to go without the dock, it made the tablet not sit flush in the face plate. Instead im going to notch out small holes in the sides of the frame for the power chord and the 3.5mm jack to come out. Tonight I will be attaching the tablet to the face plate in a semi permanent fashion with Plasti-Weld. I will post pictures of that tonight. Oh and one more thing....just a little sneak peak of some software hacking I did while waiting for the case to come. Enjoy!
  30. Member
    Sep 22nd, 2011
    East bay, Cali
    2010 mk5 jetta 2.5 PG
    10-25-2012 02:04 PM #65
    OP, keep up the good work, looking forward to the end
    FS/FT OZ Alleggerita
    Quote Originally Posted by bryangb View Post
    Everyone has ****ty roads. Lower it
  31. 10-25-2012 03:58 PM #66
    Did somebody root lmao grabbed sixaxis app off play store and a nice super nes emulator
  32. Member bots4444's Avatar
    Feb 24th, 2009
    Wilmington, DE
    09 Jetta SE
    10-25-2012 04:08 PM #67
    Hahah how could you tell!?!?
  33. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    10-25-2012 04:23 PM #68
    Keep it up. Anxious to see the final product.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  34. Semi-n00b brendanjones's Avatar
    Oct 19th, 2012
    Rochester, NY
    2009 Volkswagen Jetta 2.5
    10-25-2012 06:23 PM #69
    thats so sick... good looks on staying away from the ipad
  35. Member Seppdelaney's Avatar
    Apr 11th, 2011
    West Chester, PA
    2010 VW Jetta Wolfsburg Edition and a 2009 VW Tiguan 4 Motion SE
    10-25-2012 07:02 PM #70
    In for results.
    ///KCH2O ”VDUBkill 2:0 – The path of 2.0T is beset on all sides by the injustice of the speedtrap and the Plague of the Prius drivers. But blessed is he who in the name of disparity overwhelmeth the exotic in the valley of the s-bends. And I shall strike down upon thee with great revs and furious acceleration those who attempt to obstruct or delay my overtaking and you will know my engine is turbocharged when I lay my powerband upon thee.”
