Results 1 to 10 of 10
Thread: check engine light
  1. 10-03-2012 04:33 PM #1
    code is po411
    help
    Mar 4th, 2012
    Ohio
    03 Passat AWM, previous B4 Passat, previous Mk3 GTI
    10-03-2012 05:09 PM #2
    VWForum
    This is your warning. Next time get a flame suit on and a butt plug in because there's some real a$$holes on here and they'll tear you apart when it's obvious that you hadn't searched...
    "My timing belt is like all shredded on the edges...is that normal?"
  3. 10-03-2012 05:15 PM #3
    hahahahahaa well let me tell you that I have. and if you have read any of my other post you will know that my car isnt stock therefor every google search on this code is with the stock air box secondary intake and I do not have the stock airbox. so while were here any ideas> or anyone know how to fix this?
  4. Member
    Mar 4th, 2012
    Ohio
    10-03-2012 05:25 PM #4
    What's your engine
    You should actually get away with doing a SAI delete... I haven't done it, so I'm not sure how though
    Mar 4th, 2012
    Ohio
    10-03-2012 05:28 PM #5
    Do a vac test on the car via the FAQ stuff. It's either a leak through the housing for the SAI or the pump itself is shot
  6. 10-04-2012 12:16 PM #6
    okay will do in the mean time is it bad to drive?
  7. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    10-04-2012 01:07 PM #7
    Quote Originally Posted by aprpassat View Post
    No. The SAIP is a pollution control device and only runs briefly at startup. It has no effect on the operation of the engine. Depending on where you live, you'll probably have to get it fixed to pass inspection.
    Ideal solution is to restore the stock airbox; usually improves performance as well. Some "chip" manufacturers, as part of upgrading your ECU, will delete the code that checks the SAI system.
  8. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    10-04-2012 01:10 PM #8
    Quote Originally Posted by IanInOhio View Post
    Ian, if he has deleted the stock airbox we have no idea of the condition or even presence of the SAI hoses that should be connected to it. Testing as though it was stock won't tell him anything; for all we knew those parts went out in the trash.
    Mar 4th, 2012
    Ohio
    10-04-2012 04:55 PM #9
    Quote Originally Posted by scotts13 View Post
    Didn't think of that. I was under the assumption he still kept the stock box and such. I don't know anything bout what he's done lol
  10. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    10-04-2012 11:20 PM #10
    That code just popped up on my 01 Wagon with AWM engine in it...this is the first time so I just cleared it.
    Motor is 100% stock at this point.
