VWVortex.com - mk4 GTI throttle issues/EPC light/engine cut-out
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: mk4 GTI throttle issues/EPC light/engine cut-out
    1. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      B6 a4, 4mo B5.5, B5 S4, M-tdi caddy
      10-03-2012 08:30 PM #1
      So ive got an 02 1.8t gti 5 speed
      The car ran fine and i decided to replace the front suspension components and change the oil.
      I didnt start/move the car for 2 days til it was done and when i started it, it seemed to be ok until i hit the gas pedal....NO THROTTLE RESPONSE and the EPC light was on
      scanned and codes were P2128/P2133 and also the CEL for P0038/P0300
      I removed the throttle body for a good cleaning and no luck.
      Went ahead and purchased a second hand TB which im garunteed is Working.
      Yes i know i need a throttle body alignment. So my question is will this fix my Throttle issue?
      BTW i need VagCom if anyone can hook me up to help
      I run vdub..
    2. Member Scigano's Avatar
      Mar 10th, 2011
      2000.5 Audi TT 180 Quattro
      10-03-2012 10:15 PM #2
      I hope I'm wrong, but check the condition of your O2-sensor wires. Are they frayed, cut, or damaged/exposed in any way?
    3. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-03-2012 11:32 PM #3
      I checked them all the way to the fire wall. No damage as far as I can examine.
      I run vdub..
    4. Junior Member Rmnorth1.8t's Avatar
      Jan 11th, 2009
      Mesa Town
      2004 VW GTI 1.8t
      10-08-2012 04:00 PM #4
      I have had the same thing happen to my 04 1.8t . I run water/meth and it has seized 2 throttle bodies resulting with the same symptoms you are currently having. You might want to do a hard reset of the computer in the car to fully remove all fault codes. Hope this helps!
      2004 MKIV Bagged Jti 1.8t: Things and stuff and cars and things!
    5. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-08-2012 04:34 PM #5
      Will do when I get vagcom this week. If a TBA doesn't fix it
      I run vdub..
    6. 10-09-2012 09:16 PM #6
      I was having the same exact problems as you.
      I smoke checked my insane for leaks, did a tba, cleaned tb, and checked basically everything. The last thing i checked was the maf because i feel it's become a cliche around here.. Lol.
      But anyway, i noticed that with the maf unplugged my epc light stopped coming on. Its a fairly new (not reman) maf so i decided to check the wires from the maf to the ecu. And sure enough i found that the red wire (your maf wires may be dif) was almost completely cut and must have been shorting out or something.
      I fixed that and i haven't had the epc light come on since.
    7. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-10-2012 12:49 AM #7
      Oh really? I'll defly check that out tmrw. Not that It's a good thing but I hope it is the issue to make for an easy fix.
      Thanks
      I run vdub..
    8. Member rodebaugh99's Avatar
      Apr 14th, 2010
      South Jersey 609
      02 1.8trash
      10-10-2012 12:29 PM #8
      hey man I'm having the same problems with my car I replaced my whole gas pedal assembly as told to do from a bunch of people at h20 but it didn't fix me problem so I was starting to think my ecu may be fried until I started researching and the only thing that I've noticed with the ecu frying is usually the car won't start or you will have the epc light and the traction control but I only have the epc light on if you guys could help me out it'd be great I'm going to check my o2 sensors today
    9. Member DMACK's Avatar
      Dec 5th, 2003
      2012 Jetta GLI & 2004 Jetta GLI Big Turbo SEM MOTORSPORTS FTW!
      10-10-2012 12:57 PM #9
      In for you to figure it out? mine did the same i boosted it to 18psi and im mafless 630cc than epc light and asr came on and there was no throttle response. turned the car off and back on and its been fine for two weeks now?
    10. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-10-2012 04:40 PM #10
      My MAF wires seem fine. I already checked my pedal plug and it's ok as we'll. Friday should be when I do the throttle body alignment.y traction control light is on now and then but that's because my wires were shredded but temporarily fixed them. O2 wires are fine as well but the sensors themselves might not be good but can't get them loose.
      My car shuts off after a few seconds, thinking its due to lack of intake intake to the manifold.
      I run vdub..
    11. 10-10-2012 05:48 PM #11
      Just an update
      I'm still epc and cel free. I've also done a lot of reading up on our mafs. I've come to the conclusion that regardless of the code that's thrown, check your maf and wires first lol.
      The reason for my codes was the fact that the wire that was all effed up was the one sending the signal to the ecu telling it how much air was coming in. That signal also meets up with the one the accel pedal sends before actually going to the ecu.
      Before i fixed that wire the only codes that were thrown were for the accelerator pedal assembly and tb.
      All of those sensors are so intertwined with each other that they don't really know the root of the problem, just that there is one. If that makes sense.
      If you don't end up finding the cause, the last thing u should do would be to make up some overlay harnesses. Cuz it's most likely an electrical problem.
      Oh also idk if this was mentioned but check fuse #43
    12. 10-10-2012 05:54 PM #12
      Oh i forgot to ask you. Which wires were all chewed up? If you mean the wires for your maf then im pretty sure that's the problem. And i can get u a new harness for 10$ lol. That's what i ended up doing.
      But if you're taking about your O2 wires then your probably shorted out your ecu and that's your problem
    13. Member Scigano's Avatar
      Mar 10th, 2011
      10-10-2012 07:04 PM #13
      Quote Originally Posted by DMACK View Post
      Have you VAGCOMed your car to see what codes the ECU threw? What you could be experiencing is the damned "Torque Sensor: Limit Exceeded" code.
      Does it happen if you boost under certain condition only, or all the time (like part-throttle boosting throws it, but WOT is fine, or visa versa — details like that)?
    14. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-10-2012 07:19 PM #14
      Bmp #1746
      I checked the wires for the MAF as well as the o2 sensors. All wires were fine still wrapped in tact. The wires we pulled apart on accident were near the oil filter (found out they are for the a/c).
      Anyhow, I can't wait for vagcom to show up in the mail so I can at least see if I can tinker with the problem and fix that TB. If not.. I'll recheck wires and see if I can figure out a new custom harness of some sort to find the issue. Which I'm sure I'll need help on that one. But thanks man. Will keep updated
      I run vdub..
    15. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-11-2012 09:13 PM #15
      So here it is. Finally got vagcom today and ran a scan and these are the results
      (Also did a throttle body alignment and still no throttle)
      VCDS Version: Release 11.11.4
      Data version: 20120807
      Thursday,11,October,2012,19:59:19:05301
      Chassis Type: 1J - VW Golf/Bora IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      VIN: 9BWDE61J424020055 Mileage: 418250km/259888miles
      Address 01: Engine Labels: 06A-906-032-AWW.lbl
      Part No: 06A 906 032 DL
      Component: 1.8L R4/5VT G 0006
      Coding: 07500
      Shop #: WSC 14390
      VCID: 6BDE291B19914540E47
      5 Faults Found:
      18039 - Accelerator Position Sensor (G79)
      P1631 - 35-00 - Signal too High
      18042 - Accelerator Position Sensor 2 (G185)
      P1634 - 35-00 - Signal too High
      17513 - Oxygen (Lambda) Sensor Heating; B1 S2; Heating Circuit
      P1105 - 35-10 - Short to Plus - Intermittent
      17953 - Throttle Valve Controller
      P1545 - 35-10 - Malfunction - Intermittent
      Readiness: 0100 1100
      Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
      Part No: 1C0 907 379 D
      Component: ASR FRONT MK60 0103
      Coding: 0021505
      Shop #: WSC 00000 785 00200
      VCID: 2B5EE91B89118540A47
      4 Faults Found:
      00285 - ABS Wheel Speed Sensor; Front Right (G45)
      008 - Implausible Signal - Intermittent
      00283 - ABS Wheel Speed Sensor; Front Left (G47)
      012 - Electrical Fault in Circuit - Intermittent
      01314 - Engine Control Module
      013 - Check DTC Memory - Intermittent
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 F
      Component: 08 AIRBAG VW6 0202 0004
      Coding: 12344
      Shop #: WSC 00000
      VCID: 3A70DC5F264B2CC82F1
      5 Faults Found:
      00592 - Seat Belt Switch; Passenger (E25)
      32-10 - Resistance too High - Intermittent
      00591 - Seat Belt Switch; Driver (E24)
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      01217 - Side Airbag Igniter; Driver Side (N199)
      01218 - Side Airbag Igniter; Passenger Side (N200)
      Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 906 J
      Component: KOMBI+WEGFAHRSP VDO V65
      Coding: 07232
      Shop #: WSC 09128
      VCID: 2F66FD0BED09F96088F
      9BWDE61J424020055 VWZ7Z0A3994656
      4 Faults Found:
      01176 - Key
      65-10 - Unauthorized - Intermittent
      01177 - Engine Control Unit
      64-10 - Not Currently Testable - Intermittent
      49-10 - No Communications - Intermittent
      01304 - Radio
      49-00 - No Communications
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 09128
      VCID: F0E4BE77B0B72698515
      2 Faults Found:
      01304 - Radio
      Address 46: Central Conv. Labels:
      Part No: 1C0 959 799 C
      VCID: 3776C56B155931A0D0F
      End ---------------------------------------------------------------------
      I run vdub..
    16. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      10-11-2012 11:34 PM #16
      Unplug your rear 02 sensor and clear the codes and do a tb adapt
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    17. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-12-2012 12:09 AM #17
      Quote Originally Posted by Slimjimmn View Post
      That was my next move thanks. Not sure how I'm gonna get that rear sensor out but I'll find a way
      I run vdub..
    18. 10-12-2012 01:10 AM #18
      Just look up under the right side of car near your front door. There should be a black square that houses the o2 sensors plugs.
      Just see which one goes to the rear and unplug it
      The cover is held on by two 10mm plastic bolts
    19. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-16-2012 07:04 PM #19
      So i got a new o2 sensor. Cleared the code and still no throttle!?
      There were other items scanned, but non related (airbag/door locks/abs)
      Do these codes mean the ECU/ECM is shot or that something is wrong with the wiring harness?
      Tuesday,16,October,2012,17:50:37:05301
      76
      Coding: 07500
      Shop #: WSC 14390
      2 Faults Found:
      Coding: 07232
      Shop #: WSC 09128
      4 Faults Found:
      01176 - Key
      01304 - Radio
      Coding: 00006
      Shop #: WSC 09128
      2 Faults Found:
      01304 - Radio
      I run vdub..
    20. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      10-16-2012 07:17 PM #20
      Bad O2 sensor cooked the throttle drivers in the ECU. Verify the O2 sensors and wires (with a meter, not visually), and then replace the ECU.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    21. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-16-2012 07:27 PM #21
      Quote Originally Posted by Anony00GT View Post
      Oh joy! well i have a brand new 02 sensor. Hook that up then replace the ECU?
      What specificly needs to be done?
      Find an ECU for 1.8t 5/6 speed, AWP does engine code matter?
      Then how do i swap the ECU, electronically. I know how to pull it out.
      Your help is greatly appreciated, but the bad news is not
      I run vdub..
    22. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      10-16-2012 07:32 PM #22
      Quote Originally Posted by runvdub View Post
      Yeah, this isn't exactly an uncommon problem. I've seen it caused by bad O2 sensors, and on cars with big downpipes, O2 sensor wires melted against the pipe.
      You're going to need an ECU that matches the EXACT part number as yours to start. Then you need to find someone who can match the new ECU to the immobilizer in your car (cluster, keys, etc). Basically you're limited to the dealership for this, not much availability in the aftermarket. You might be able to find a tuner to disable the immo altogether, but these ECU's are not just plug and play. Contact Jack@european parts on here, he does immo work.
      The most important thing is that you confirm 110% that the original problem (O2 heater short) has been fixed, because if not, you're going to immediately let the magic smoke out of the new ECU as well.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    23. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-16-2012 08:30 PM #23
      So buying a used stage 1 united motorsports ECU for AWP manual transmission with immo defeat. That should be compatible correct?
      I run vdub..
    24. Member runvdub's Avatar
      Mar 23rd, 2011
      Chambersburg
      10-16-2012 10:50 PM #24
      Well this isn't factory ECU but car ran fine on it before.
      Will this ECU work to replace it?
      The last two digits (DL vs RN) make a difference?
      I run vdub..
    25. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      10-17-2012 12:02 AM #25
      RN - awp
      DL- aww
      it should work,
      just make sure the rear o2 sensor is new and or the short is fixed.
