Results 1 to 17 of 17
Thread: MPG question
  1. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    2005 Honda Civic Si 1988 VW Fox Wagon
    10-03-2012 10:08 PM #1
    I'm driving my wagon on a semi-regular basis (new job is a 100 mile round trip). I forgot the average miles per tank I was getting when it was my primary car.
    I might get 250 miles out of this tank with some city driving and highway driving. The car is averaging ~24-28 MPG.It's a stock 1.8 with 170,805 miles.
    I feel my mileage could be better. It is easy to start when cold, but is difficult to keep a smooth idle shortly after starting. But, I digress. This is another matter I need to investigate at another time.
    What do you average per tank with mixed driving?
    "It's dark and you want to go home?"
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-03-2012 10:17 PM #2
    20mpg
    I really suck at smog.
    Aug 17th, 2011
    Brooklyn, NY
    '88 Fox GL Wagon, '04 Jetta GLS Wagon TDi, '89 Fox Coupe (sold)
    10-03-2012 10:53 PM #3
    I tend to drive ~270-280 on a full tank then fill up - trying to keep at least 1/4 tank at all times. I am averaging 28-32 depending on load and amount of stop & go. The best I've done is just over 34 w/ just my buddy and I - no extra baggage - all highway down to DC.
    Vacuum leaks always tend to drop my MPG. Random tanks I got 20-22 - and immediately found a cracked hose or something. Fixed it - and back to normal the next tank.
    I'm sure I can tweak a few things still - my #1 culprit being the cracked or missing o-ring at the idle adj screw.
    How a VW Fox Wagon sucked me back in...a build thread
  4. Member 1993vw fox's Avatar
    Jan 15th, 2011
    Littleton Colorado
    1993 Vw Fox,1998 Mazda 626,2006 Kia Optima,
    10-03-2012 11:13 PM #4
    I'm pulling 315 miles to a tank. But that is a lot of highway driving.
    Aug 7th, 2012
    Vancouver
    88 fox wgn, 93 F150, 87 1490 Gixxer, KTM300,CRF450X +R
    10-03-2012 11:33 PM #5
    my Fox wagon got 10 litres to the 100kms with heavy footed city driving = 23.5 mpg with no gear not even a spare tire... hwy I got 29.4 mpg but we live in the mountains and the speeds are 75 to 86 mph... hope that helps... I also cleaned my injectors in a sonic bath and found the orig injector o-rings in dire straights including vacum hoses
  6. Member bluetoes591's Avatar
    Apr 3rd, 2009
    Vancouver, BC
    1990 2dr Fox
    10-04-2012 01:28 AM #6
    All of this information is useless without mention of four vs. five speed.
    With my four speed and aggressive driving style I have averaged 27.7 miles per American gallon over the past 7,500 miles which is split near 50/50 city/highway. My best was 30.9 mpg on a mountainous highway trip and a worst of 24.6 which involved mostly city driving and extensive right foot testing of a small performance mod.
    And yes, I have an extensive spreadsheet.
    Aug 17th, 2011
    Brooklyn, NY
    10-04-2012 07:06 AM #7
    I didn't notice much of a difference between 4 and 5 speed.
    I've also kept a log since day 1 (mainly because my fuel gauge didn't work at first)
  8. Member reddfoxx's Avatar
    Sep 18th, 2005
    one-room schoolhouse, central Ohio
    87 Fox wagon turbo, 90 Fox 2-door
    10-04-2012 12:13 PM #8
    I figure on 300 miles in the wagon, if I run it low (I usually fill at around half a tank though.) I'm getting about 28mpg, but that's with the modifications. I think stock it was typically 30.
    4-speed, of course, is standard... bah-dum-dump. With the 5-speed in my '93, I got more like 33 on average. Part of that may be due to Digifant, too. I have that tranny, and might put it in one of my CIS cars eventually, so I could compare more directly.
  9. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    10-04-2012 04:59 PM #9
    I filled the tank today with 10 gallons, and traveled 255 miles.
    My wagon is the four speed model.
    I'll see how this tank improves over the next week.
    It's good to know the mileage isn't too bad. The only changes to the motor have been the dual outlet exhaust manifold, down pipe, and a WOT switch. Otherwise, all internals are stock.
    Sep 12th, 2012
    Elkton MD
    93 VW Fox GL ( black )
    10-04-2012 05:55 PM #10
    Quote Originally Posted by mike in SC View Post
    try what i did and clean the charcoal canister pull it off the hoses and get a air compressor and fill it with 50Psi of air ONLY! no water or cleaners it will boost your MPG cus over the years all the fumes and dirt clog the canister and doesnt allow all the gas fumes to go back to the gas tank for combustion hope this helps i know it helped me
  11. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    10-04-2012 08:30 PM #11
    I'll have to try that. Honestly, I've done nothing with the charcoal canister. Thanks
    Sep 12th, 2012
    Elkton MD
    10-05-2012 05:34 AM #12
    heres the best link i found to describe so i dont
    LINK---> http://www.ehow.com/how_8104632_clea...-canister.html
  13. Member
    Nov 27th, 2011
    Toronto, On, Canada
    1988 VW Fox, 1989 Peugeot 505 Wagon rolling shell
    10-05-2012 09:27 AM #13
    88' Fox sedan 4 spd~
    I've been getting 30-35 mpg lately, since I bumped the timing up to 12. You may have to burn premium fuel, but I am using less fuel than before so I end up spending about the same.
    When the timing was at the stock 6, which actually was 4, I was happy if I could break 30 mpg with a tail wind, at 55 mph.
    And the car felt strangled, esp below 3000 rpm.
  14. Member dacolino's Avatar
    May 31st, 2002
    Hawthorne, NJ
    1985 Ford Mustang GT, 1989 GTi 16v, 1988 Fox GL wagon, 02 Suzuki SV650
    10-07-2012 05:18 PM #14
    My 88 wagon was getting between 300-340mi out of a tank and I do a lot of mixed driving and use the engine. Worked out to get around 28-32 mpg usually around 30...this was all stock save for a tt catback &hiflo cat and ignition timing set to 9deg running regular fuel. I have since done a lot of engine work so I cant fully comment on that yet...JH head heavily ported &polished, ported intake, bigger tb, wot switch, 16v ecu, Dual manifold/downpipe, I HAD a TT 280/276 cam in it, just removed the cam yesterday for a G Grind because it was too radical for what I need. Last tank I got around 260 with the large cam, should be more with the G grind because I dont need to get on it as hard for normal driving. Still running 9deg ignition timing advance and it runs great has great power, I also tweaked my CIS-E and it really shows now, but If I can get the car to get 28 again id be thrilled.
    Side note...I have had many CIS cars and they frequently get great fuel mileage, I had a 84 Jetta GLI I sold last year with a Elgin 272 cam...some other mods as well and it got 30mpg all day long running 14 deg ignition timing advance and 93 octane.
  15. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    10-07-2012 08:06 PM #15
    I changed the timing a little today. It was driving well, but I changed it to a little past 6*(degrees).
    It seems to drive smoother, and doesn't slow as much going uphill.
    Ever since the DPR started leaking ( four years ago!!!) on the original fuel distributor (FD), I've had more trouble with mileage than I care to think about. I finally located and installed a FD that didn't have the aluminum plug drilled out. I got it out of a CIS-e GTI. I don't think that would cause poor mileage, but I could be wrong. I picked up and installed the GTI camshaft too.
    Driving the wagon 120 miles on Monday and Tuesday. I'll be interested to see how the mileage proves out.
    How does the G grind cam feel compared to stock? Always wanted a drivings opinion.
  16. Member dacolino's Avatar
    May 31st, 2002
    Hawthorne, NJ
    10-07-2012 10:22 PM #16
    Well keep in mind all at once I went from: Stock long block with a hiflo cat and a tt 2" catback to a Heavily ported and polished JH solid lifter head, ported intake manifold, bigger tb, dual exhaust manifold, dual downpipe etc. I also installed a 16v CIS-E ecu (only reason its a 16v one is because I had two spares on hand), and a wot switch that I set to switch on around 80% throttle. I then worked on getting my a/f sorted as it was obviously way too lean, and at this point its about as good as its gonna get. The only similarity between this is I am running the same base ignition timing setting I was before...the whole point of the "build" was to give the car more driveability power BUT keep it running on 87 octane because I own two other cars that require 93 due to the way I have them tuned.
    As of now, the G grind cam wins all around in my book. I have the cam timing retarded 2 degrees and currently from idle-6k the car pulls very hard, mind you on conservative ignition timing. the G grind I would similarly compare to a 268 hydraulic cam, seems to have a similar power range.
  17. Member QuantumSyncro's Avatar
    Apr 28th, 2000
    Des Moines, IA
    97 Jetta TDI, 89 Fox diesel, 92 300SD turbo, 82 GS1100E
    10-09-2012 01:50 AM #17
    Mine gets 43mpg in town and 53mpg on the highway...then again it's a diesel...lol.
    I typically get to around 440 miles (in town) before I consider filling up, and typically it takes a little over 10 gallons.
    I'd like to take it on an extended run in the near future, before winter sets in, and see how good it gets. I think it'll do better both in town and highway but there's a tiny fuel leak on the IP right now and I haven't picked up the o-ring I need to fix it.
    steve
    Gir - "won't the sploding hurt?" Zim - "Silence!"
