Results 1 to 11 of 11
Thread: Winter tires/rims help
  1. 10-03-2012 10:50 PM #1
    Running stock 18in. BBS's right now with touring tires. Trying to prepare for winter and not sure what I should do. After some searching on the forum it seems like there is a decent balance between people going with a 16in rim/steelie and snow tires and saving their other set for summer.
    My current tires will need changing in the spring regardless and I have come across a set of 16in Jetta rims with a beefier tire on them with good tread left for a steal.
    My question is, should I just buy new all-seasons for my 18's, the jetta rims with the beefier tire, or try and find rims with snow tires?
    Also, I am located in Wisconsin and winter can really go either way here- loads of snow or dry and very cold.
    Thanks!
    Jun 21st, 2010
    Darlington
    10-03-2012 10:58 PM #2
    Really depends on the type of driving you do. Are you in and out of gas stations and parking lots in the middle of winter? How much do you drive it during snow?
    If you really need to get around town with this car, go with a smaller wheel and snow tires. If you just go short distances or have alt vehicles you can use, go with some good all-seasons.
    All-seasons: I'm running Continental ECs currently. Have yet to drive them in the snow, but they apparently do decent. I previously had Hankook HRIIs and while a good dry tire, wet or snow where pretty bad, but worked.
    Snow: Look into Bridgestone snow tires. They do pretty damn good in snow.
    GLI / 1.8T / F23 / 550cc / Autotech Cam
    912 / Widebody / EJ20T / 915
  3. 10-03-2012 11:04 PM #3
    I live downtown in the city. It is my daily driver and my commute to work is about 15 minutes, all highway. I'm pretty close to everything (grocery store, gas station, etc.) so I don't drive too far.
    Jun 21st, 2010
    Darlington
    10-03-2012 11:23 PM #4
    If you know your roads are well maintained, you can probably get away with good all-seasons on your stock wheels. But, a smaller wheel and a good snow tire will allow you to get up and go quicker from stop-and-go traffic and all around be more reliable in heavy snow fall.
  5. Member Haxes's Avatar
    Sep 2nd, 2007
    West Bend, WI
    2002 VW GTI 1.8t. / 1998 Audi A4 1.8t quattro. / 2001 VW Jetta GLS 1.8t
    10-04-2012 01:13 AM #5
    I've lived in, and driven in Milwaukee enough to know you'd be better off picking up the 16" wheels/tires for winter. I don't even bother driving my GTI in winter anymore because it was just lame. My wife's Jetta does just fine in the snow with 16" wheels and all seasons. Trying to drive with the 18"x7.5" wheels in snow can be done, but I don't care for it.
    Sent from my ADR6300 using Tapatalk 2
  6. Member ninjapants's Avatar
    Mar 2nd, 2007
    Takoma Park, MD
    '04.5 GLI
    10-04-2012 08:05 PM #6
    Run a spare set of 16s and run winter tires, a good set of winters isn't much more than a set of all-seasons. If you are going to run a spare set of wheels get the best out of each set of tires you can. High performance summers and performance winters. I ran dunlop wintersport m3 tires on a cheap 16" wheel on my GLI for about 4 seasons. The tires were awesome in the snow, surprising actually, and I grew up in southern Maine and went to college in NY on the border of Canada so I saw all kinds of winter conditions and I was incredibly pleased with my choice.
    Go with a spare set of 16" and performance winter tires, by far the best bang for the buck.
    Better yet... Buy Mine!
    I've moved to DC and no longer need them.
    Floss Filthy x Team Big Shark x Dirty $$$
    Quote Originally Posted by Bork
    you're such an og nooob <3
    Buy My Winter Setup! | Master Project Thread: The Life of a GLI | Need polishing? PM me for info.
  7. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    10-07-2012 08:56 AM #7
    I would buy dedicated snow tires. Smaller diameter doesn't matter much, but a skinnier tread profile helps.. Think 205/50/17 (matches factory overall diameter of the 225/40/18). That size is actually the factory recommended size
  8. 10-10-2012 10:05 PM #8
    I found some 17in wheels with snow tires on them for a really good deal. However, they have a 35 offset and a gli stock is 40 I believe. Will these work or will I need spacers?
  9. 10-10-2012 11:45 PM #9
    Sorry, should've said they are 17x7.5
  10. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    10-11-2012 12:32 AM #10
    Those are perfectly fine. And no, the GLI factory wheels are 18x7.5 et38, so those winter wheels only have 3mm less offset, really it's a perfect match
  11. 10-11-2012 08:11 AM #11
    Awesome! Thank you
