Coil. Replace it.
hello vw brothas and sistas
once again, i need your input on something. this morning when i left my house, i realized i forgot something, had to turn around to get something. When i got into my car, i couldnt start the car. the engine kept cranking but didnt start. i waited couple minutes, tried to start again, didnt start. just kept cranking. I stopped starting the car and waited another couple of minutes and this time, it started. this is the first time that this happen. Is this a sign of something bad later on?
thank you for your input!!
Frank![]()
is your alarm still hooked up?
mine did this too, some times it wouldn't crank at all ant some times i could sit there and crank with no start. look up alarm bypass, its a simple jumper wire and doesn't cost anything to try.
WOW!
7200 rpm in 5th is ~ 82mph!
do you get into 3rd leaving your driveway?
