Results 1 to 26 of 26
Thread: FS/FT 1996 VW GTI Turbo VR6
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-03-2012 11:36 PM #1
    Selling my 1996 VW GTI Turbo VR6 Black on Black leather 151,756 miles on chasis 115,000 on block around 5,000 on cylinder head less than 1000 on the turbo
    Thousands invested but i have three cars and i need the space so its time for it to go price is firm no low ballers please asking $4000
    Will consider trades looking for a mk4 jetta
    http://nh.craigslist.org/cto/3300985049.html
    MODS
    -Audi Fat five wheels, will need new rear tires
    -supersport 60/40 cup kit
    -VF engineering motor mounts
    -poly urethane control arm bushings
    -mk4 rear brake calipers
    -b&m short throw shifter
    -eclipse 8443 head unit
    -RPI ported and polished head with 5 angle valve grind, heavy duty valve springs, titanium valve seats and retainers
    -custom built short runner intake manifold
    -kinetic motorsports exhaust manifold
    -Garrett t3/t4 turbo 60 trim AR 82 hotside
    -9:1 head spacer
    -42# injectors
    -GIAC 42# chip
    -Tial 38mm external waste gate
    -3" stainless downpipe
    -Autotech 2 1/2" stainless steel exhaust with magniflow muffler
    -Baily motorsports diverter valve
    -4"MAF housing
    -front mount intercooler, with stainless charge piping
    -ARP head bolts
    -oil to air oil cooler
    -Autometer boost gauge and oil pressure gage
    -AEM wide band air/fuel gauge with o2 sensor
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-07-2012 05:40 PM #2
    Bump for a killer deal!
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-07-2012 10:36 PM #3
    go FAST!
  4. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-08-2012 01:34 PM #4
    Fastest car ive ever driven!
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-08-2012 09:20 PM #5
    bump !
  6. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-09-2012 06:53 PM #6
    bump please!
  7. Junior Member
    Dec 19th, 2011
    04 gli
    10-09-2012 10:27 PM #7
    Hows the paint and body condition.. also how much Hp?
  8. Junior Member
    Oct 10th, 2012
    Rhody
    10-10-2012 04:34 PM #8
    Could you pm your number?
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-11-2012 11:08 PM #9
    The car puts down a little over 400 hp and 400ftlbs @ 19lbs of boost I don’t run 19 lbs. because the clutch can’t handle it and the bottom end really needs to be built to run that consistently. I’m currently running 13-15 lbs. of boost which should put me somewhere between 340-360hp I don’t race the car I just enjoy the thrill of going fast and that’s fast enough for me. The body and paint is in reasonable shape for its age and asking price but could use some work. The car does not have an lsd or upgraded clutch; I have kept it that way to preserve the integrity of the transmission. I am currently running 13-15lbs of boost and notice slight clutch slippage at full throttle in third gear, first and second just spin the tires/tire. The car has new front ball joints as of last summer and tie rods were replaced a year before that. Brakes works fine but could use some attention in the rear (common for these cars) new ebrake cables were installed this spring and rear shocks last fall. Rear swing arm bushings are needed I just haven’t had the time to replace them. The rain tray was removed to help vent excess heat generated by the turbo, also making simple maintenance much easier. The ecu was moved to the interior of the car with the wires run through the front frame rails. Car does not leak any coolant although I would recommend replacing the upper rad hose to eliminate the ugly splice for the overflow. There is a problem with the heater core and because of that the core is bypassed. I haven’t done much looking into this problem because I only drive the car during the summer months. (In my spare time I have been looking into replacing the heater core) Rocker panels need some help but I have never owned a mk3 vr6 that didn’t and this is my third mk3 vr6 (the plastic side skirts harbored sand and salt wreaking havoc on the rockers). This is my third car and does not get driven much more than a few thousand miles a year so simple wear items last much longer than that of a daily driven car. The value of the mods alone warrant the asking price without taking into consideration the value of the vehicle its self-Thank you all for your interest
  10. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-13-2012 10:51 PM #10
    bump
  11. Member CTdubbin7's Avatar
    Apr 15th, 2009
    Bethlehem CT
    2000 gti 6262 Vrt
    10-14-2012 12:00 PM #11
    good price...nice vrt GLWS!
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-14-2012 09:51 PM #12
    Yeah ive had lots of fun with this project, but its time to move on
  13. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-16-2012 11:33 PM #13
    Bump
  14. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-17-2012 10:04 PM #14
  15. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-18-2012 04:53 PM #15
    I cant believe how little interest there has been for this
  16. 10-18-2012 11:05 PM #16
    Sucks your so far away I'd trade my mk4 gti with a bunch of mods.for it
  17. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-19-2012 05:15 PM #17
    how far is too far?
  18. Member
    Jul 31st, 2011
    Misissippi
    2008 civic si sedan 2006 acura tsx 1997 vw golf gl 1995 vw jetta glx vr6
    10-19-2012 05:56 PM #18
    Nice car wish you were closer if trade my vrt corrado for it
    2008 civic si sedan
    2006 tsx
    1997 golf gl (for sale)
    1995 jetta glx vr6
  19. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-20-2012 07:25 PM #19
    I’m located in Barrington NH and like it says in the post it’s in pretty good shape for a 16 year old car but the rockers are rusted along with a few other spots here and there and there is a couple spots on the floor boards that need help, the cylinder head and the turbo kit are worth more than the asking price of the car along with all of the other mods so people need to understand that the car its self does need some work all of that aside I have put hundreds of hours and thousands of dollars into this project and I do know what it is all worth if you are seriously interested in this kind of a project you will be able to appreciate the car for what it is people need to start taking advantage of this powerful resource we call Facebook and spread the word we can make a difference but we all need to do our part, share this link we can all make a change
  20. Member
    Jul 31st, 2011
    Misissippi
    10-20-2012 08:16 PM #20
    It's def worth the asking price someone will be very pleased.
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
  21. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-21-2012 06:31 PM #21
    Thank you, thats how i feal too. I know if i saw this a couple years ago when i started this project and bought the turbo kit i would be all over it. its a great deal and would make a great doner car for a mk2 vrt also
  22. 10-21-2012 06:56 PM #22
    Interested in a 95 mulberry gti vrt?
  23. 10-21-2012 09:24 PM #23
    Trade for another gti?
    Sent from my iPad using Tapatalk HD
  24. Member
    Oct 17th, 2006
    Newmarket
    95 Audi 90 VRT
    10-22-2012 06:04 PM #24
    any pics?
  25. 10-22-2012 06:09 PM #25
    Your all the way in new hampshire im in baltimore md, i think thats too far
  26. Member
    Jul 31st, 2011
    Misissippi
    10-22-2012 09:07 PM #26
    Quote Originally Posted by 12psigti View Post
    I just paid the same price for a fully built vrt corrado that's 22 years old body is not that great but I basically paid for the engine it's a monster I would love to swap it into a mk2 or 3 gti.
    2008 civic si sedan
    2006 tsx
    1995 jetta glx vr6
