Results 1 to 4 of 4
Thread: mk1 rear excessive wheel bearing and tire wear??
  1. Member rocco 4.5's Avatar
    Feb 18th, 2006
    Mass
    scirocco 16v
    10-04-2012 08:47 AM #1
    I have a 92 cabby I finished building a few months ago. It's lowered about 2" with 15x8 wheels, scirocco 16v rear beam/discs, berg kit. Anyways, after about 10k the front tires still look like new, but the rears are completely bald. Even wear side to side-1mm tread left! The rear wheel bearings are now a bit crappy as well, but I believe the bearings wore due to the wheel, not vice versa. Based on my vw car knowledge toe is the only thing that would excessively and evenly wear away rear tire tread is toe. But as far as I know there is no toe adjusting on the rear Does anyone have any idea why my rears are wearing so quick, how I could adjust rear toe, or if there's a different issue all together???
  2. Member rocco 4.5's Avatar
    Feb 18th, 2006
    Mass
    scirocco 16v
    10-12-2012 07:04 PM #2
    How does one go about correcting toe on mk1 rear torsion beam
  3. Member JohnnyRado's Avatar
    Mar 12th, 2009
    mill city
    90 rado G60 , 04 jetta 1.8t (gone) 2013 Kia soul , slammed 97 probe gt daily !
    10-17-2012 06:08 PM #3
    How low does you're car sit ? The lower you are and the further out you're wheels sit makes them wear differently .
  4. 10-24-2012 11:04 PM #4
    They sell shims for the rear. Here is a link and there are other places that sell these and various different styles also. They are fairly common, just make sure you buy decent shims and stay away from the cheap plastic stuff. Also note, they are a bit of a hassle to install and dial in.
    When I had my rears adjusted last year, there is also a website that you enter your current rear specs and desired rear specs and they machine and mail you the needed left and right rear shims. Pretty cool and it takes all the guess work out of the process.
    http://eurosportacc.com/camber_caste...lts_plates.htm
