pop the ign lock cylinder out. There's a tab inside to unlock the steering column.
Did this today....
My ign cyl had been out before (prev owner? bad ign switch?) so the hole to release the lock cyl was already there. If yours doesn't have the hole, check your bentley. You drill the hole so you can reach the tab so you can remove the lock cyl.
-Dave
