Look like your friend have no electronic skils, only mechanical. If he fixed body, now need to focus on the controlers, wire's, fuses etc.
#1
My friend has an S4 B7 after repairing the front that was damaged this is the auto scan that I get, which I am having problems with. I can`t communicate with the air bag module. Why is there so many no communication between modules.
Any help would be greatly appreciated.
Wednesday,03,October,2012,18:09:52:39091
VCDS Version: Release 11.11.4
Data version: 20120807
Tactik Motorsport
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUGL98E67A044421 Mileage: 132590km/82387miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E2 910 560 B HW: 8E2 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0007771
Shop #: WSC 06325 000 00000
VCID: 26490334917FBE287B9
4 Faults Found:
005685 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 132590 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Mileage: 132590 km
Time Indication: 0
Freeze Frame:
RPM: 193 /min
Load: 60.4 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 24.0°C
Voltage: 10.795 V
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 132590 km
Time Indication: 0
Freeze Frame:
RPM: 193 /min
Load: 60.4 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 24.0°C
Voltage: 10.795 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 M HW: 09L 927 156 B
Component: AG6 09L 4,2 MPI USA 0030
Revision: --H01--- Serial number: 4205804
Coding: 0000002
VCID: 3163E068A8B1E9909EB
2 Faults Found:
006241 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 97.0
Temperature: 8.0°C
T.B. Angle: 60.0°
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004902
VCID: 2E59FB14B98FF668839
6 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 79
Reset counter: 37
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0183
Hex Value: 0x0001
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x6202
Hex Value: 0x0029
Hex Value: 0x01A6
Hex Value: 0x0001
00532 - Supply Voltage B+
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0003
Hex Value: 0x22D6
Hex Value: 0x0001
00495 - ESP-Sensor Unit (G419); Supply Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x0047
Hex Value: 0x01D7
Hex Value: 0x0001
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x001E
Hex Value: 0x43D7
Hex Value: 0x0201
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 37
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4000
Hex Value: 0x0013
Hex Value: 0x168C
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6DDB3C1827094D70FA3
3 Faults Found:
00819 - High Pressure Sensor (G65)
30-10 - Open or Short to Plus - Intermittent
07-10 - Signal too Low - Intermittent
53-10 - Supply Voltage Too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 06325
VCID: 3D7BCC5837E91DF00A3
3 Faults Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
01320 - Control Module for Climatronic (J255)
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G08NB4
Coding: 0033607
VCID: 3C7DC15C7FF314F83DD
8 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
00589 - Airbag Igniter 1; Passenger Side (N131)
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 1
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
01219 - Rear Side Airbag Igniter; Driver Side (N201)
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04141
Shop #: WSC 06325
VCID: 4183B0A84B1179106EB
2 Faults Found:
01304 - Radio
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 N HW: 8E0 920 931 N
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023361
Shop #: WSC 94753 999 84025
VCID: 336FEA6051ADDB80EC7
4 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus - Intermittent
00668 - Supply Voltage Terminal 30
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E3A068BB3129905EB
3 Faults Found:
01447 - Sensor for Driver Seat; Height Adjust (G231)
36-00 - Open Circuit
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US H72 0260
Revision: 03S Serial number: AUZBZ7F2465224
Coding: 0309617
Shop #: WSC 00000 785 00200
VCID: 2B5FF200899D8340A47
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 88
Time Indication: 0
Date: 2005.02.20
Time: 00:23:40
Freeze Frame:
Voltage: 12.40 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 88
Time Indication: 0
Date: 2005.02.10
Time: 00:00:38
Freeze Frame:
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 53
Time Indication: 0
Date: 2005.02.10
Time: 00:00:31
Freeze Frame:
Voltage: 14.90 V
Mileage: 655350 km
Count: 1002
Clock: 00:00
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Time Indication: 0
Date: 2005.02.10
Time: 00:01:00
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11820
Shop #: WSC 06325
VCID: 78F51D4C584BF8D8195
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
6 Faults Found:
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 295308088061915056B
Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0010
Component: AFS-Modul rechtsH03 0010
2 Faults Found:
02769 - Headlight Swivel Module; Left
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110011
Fault Priority: 2
Fault Frequency: 10
Reset counter: 40
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Time Indication: 0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309617
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 88
Time Indication: 0
Date: 2005.02.20
Time: 00:23:40
Freeze Frame:
Voltage: 12.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 88
Time Indication: 0
Date: 2005.02.10
Time: 00:00:38
Freeze Frame:
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 53
Time Indication: 0
Date: 2005.02.10
Time: 00:00:31
Freeze Frame:
Voltage: 14.90 V
Mileage: 655350 km
Count: 1002
Clock: 00:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Time Indication: 0
Date: 2005.02.10
Time: 00:01:00
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0063022
VCID: 2A51F70486679A485F1
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 22
Time Indication: 0
Freeze Frame:
(no units): 255.0
Voltage: 6.40 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 22
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Temperature: 21.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020619
Coding: 0001304
VCID: 3163E068ABB1E9909EB
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Time Indication: 0
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H21 0290
Revision: 00000001 Serial number: 00000000494192
Coding: 0011877
VCID: 3D7BCC5867E91DF00A3
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 210
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 210
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
End ---------------------------------------------------------------------
#2
Activate needle illumination in ALL MICRONAS cluster since 2004 up to 2010. Activate STAGING for all NEC cluster since 2008 even if not availabe in adaptation chanel.
