Results 1 to 23 of 23
Thread: Hi flow cats vs. test pipe.
  1. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-04-2012 01:44 PM #1
    Which is better in terms of power gains and why? I'm getting ready to change tunes from GIAC to UM and I want to either eliminate my cats or get hi flow cats at the same time.
    Quote Originally Posted by VincewagenR32 View Post
    Torque is a motherf***er
  2. Member ParkeR32's Avatar
    Mar 22nd, 2012
    Jackson, NJ
    MkIV .:R32
    10-04-2012 02:07 PM #2
    Also curious about this
  3. Member Khunez's Avatar
    Feb 27th, 2009
    Dallas TX
    2004 Vw R32
    10-04-2012 02:17 PM #3
    this has been settled and tested....NA = HF cats You loose power with the straight pipe.
    Turbo is a different story.
  4. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-04-2012 02:28 PM #4
    Quote Originally Posted by Khunez View Post
    I saw threads with debates of which was better, but wasn't sure which to believe...thanks
  5. 10-04-2012 02:32 PM #5
    Got the usp test pipe being dropped off today. Probably have it in tomorrow or Saturday. Fingers crossed its not too raspy or ill b throwing some hfc's in it.
    I feel 10 feet tall right now, And strong as a Ox
  6. Member Khunez's Avatar
    Feb 27th, 2009
    Dallas TX
    2004 Vw R32
    10-04-2012 03:09 PM #6
    Quote Originally Posted by Billkelly25 View Post
    it will be raspy(unless yours is turboed) and you will loose some power
    May 30th, 2006
    Mesa, Arizona
    '04 R32 - '95GTIVR6 - '02 TTQuattro
    10-04-2012 03:29 PM #7
    That's just great, what we're looking for, a loss of power.
  8. Member r32dub88's Avatar
    Dec 9th, 2007
    NH
    BMP Golf, TR GTI
    10-04-2012 03:29 PM #8
    its been a while since i read over those debates but from what i remember on a NA car test pipe adds about 2-3 hp but you lose about 15 ft lbs of tq. Hope this helps
  9. Member Khunez's Avatar
    Feb 27th, 2009
    Dallas TX
    2004 Vw R32
    10-04-2012 07:30 PM #9
    ^this is true.
    Search powerdubs topics. He has put this car to the test in every NA combination.
    Also I hear good things about adding a resonator to the set up to tune the sound.
  10. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    10-05-2012 12:46 AM #10
    As someone who had no cats for 4 months then welded in highflow cats I can tell you this :
    - W/O sounds like ass
    - W/O you lose low end
    - W/O you do not gain high end
    No cats is just ****ing dumb.
    Quote Originally Posted by BlownR View Post
    I have seen several open slots, usually after tequila. Wait, I think that's different.
    MKIV DBP .:R32 | Photo Gallery
    Projects | Custom Exhaust : It Begins | Solid MKIV Sub-Frame Mounts ||Build Journal| Draxus's GoKart
  11. Member EIPtuningR32's Avatar
    May 3rd, 2008
    Gainesville, FL
    2004 VW .:R32, 1982 Porsche 928S Euro, 1923 Ford T-Bucket, 1962 VW Myers Manx (sold), 2000 Trans Am
    10-05-2012 03:35 AM #11
    dude... you dont lose power. You lose torque down low, but it pulls a little better up top. Its just one more modification that specifies where you want your power.
    Edit** Yes, it is raspy, but on WOT its awesome.
    This is a USP test pipe and an EIPtuning competition series exhaust
    same car, more video:
  12. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-05-2012 10:58 AM #12
    Quote Originally Posted by Draxus View Post
    Exactly what I wanted to know. Thanks.
  13. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    10-05-2012 11:36 AM #13
    Quote Originally Posted by v2. View Post
    Yeah when u remove the cats, u cap out TQ unless you have a turbo. If u have a turbo, **** it make it a 5 " straight pipe
  14. Member Budgeezer's Avatar
    Apr 7th, 2005
    Edina, MN
    TR R32 (soon to be HPA'd), Surly 1x1 Fixed
    10-05-2012 04:25 PM #14
    EIP Street Series, usp test pipe, magnaflow HFC's in car footage.
    RA 2012 from Paul Anderson on Vimeo.
  15. Member jampy's Avatar
    Nov 19th, 2010
    mk4 r32/93 gsi16v
    10-05-2012 07:31 PM #15
    i found this in old thread,i think is a good example as the test pipe work well,i run with no cats 1year ago and the car loss torque in low..yes this is true but have great top end power imo..i tested this between 2 points in a road,with stock cats put 188km/h and at the same point with no cats put 195km/h,test pipe works! just another way to make power. .
    http://forums.vwvortex.com/showthrea...test+pipe+dyno
  16. Member
    Mar 4th, 2012
    NJ
    2002 Audi TT ALMS Edition (Avus silver), 2006 350z, 2009 Dodge Caliber SRT4
    10-06-2012 01:56 PM #16
    I have supersprint resonated test pipes mated to a resonated milltek on my girl's 3.2TT and felt no loss of low end power and def a gain in the midrange and top. Tuned by Eurotech Motorsports in Mahwah, NJ with APR Stage 2 software. Other mods include Modshack VDTA intake. Sounds great.
  17. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-06-2012 05:08 PM #17
    what about a combination of both? A test pipe with a HFC welded in.
  18. Member jampy's Avatar
    Nov 19th, 2010
    mk4 r32/93 gsi16v
    10-07-2012 03:29 AM #18
    Quote Originally Posted by Kacz07 View Post
    you have a pm..
  19. Member LIFE.:R's Avatar
    Mar 11th, 2012
    St.Augustine,Fl.
    2004 vw R32
    10-10-2012 12:12 PM #19
    If a testpipe was retro'ed to a HFC. Would 2 HFCs(like stock pipe) be more adequate than just one on the end? I've seen both, which is more affective?
  20. 10-18-2012 04:17 PM #20
    MK4 with TT test pipe and C2-Step software. Dyno graph, drive by and launch:
    http://www.rennenparts.com/index.php...-Software.html
    Dyno:
    Drive-By:
    Launch:
  21. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-20-2012 10:46 AM #21
    Quote Originally Posted by FalmouthMK5 View Post
    Dyno:
    Drive-By:
    Launch:
    The drive by sounds great!
  22. Member CEL is On's Avatar
    Jul 9th, 2010
    Virginia Beach
    10-20-2012 11:15 AM #22
    ^^ Stock exhaust with those TT test pipes?
    2004 .:R32 | VR Alliance #123 | BFC Retrofits | Auto Elite |
  23. Member jampy's Avatar
    Nov 19th, 2010
    mk4 r32/93 gsi16v
    10-20-2012 02:13 PM #23
    yes,oem catback with tt testpipe,as i said the test pipe works! and with sport catback the gains are much better.
