Results 1 to 13 of 13
Thread: Scirocco 1.8t swap
  1. 10-04-2012 02:50 PM #1
    My mom totaled her jetta GLI and I am going to take her motor and wiring in my scirocco I just need to know what I need to make it possible. You help is dearly appriciated
  2. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    '78,81S,TTQ,S2 8V, race Corvette
    10-04-2012 03:01 PM #2
    get the wiring diagrams for BOTH cars...that's a good start.
    What is the engine code number?
    Then figure out the fuel injection
    Then figure out mounting
    Then figure out cooling.
    Fgure out the inter-cooler ducting
    Then figure out exhaust.
    Then figure out the suspension
    Then the brakes for twice the horsepower
    Do you have the skills for this big job?
    A 1.8 swap is not especially difficult but there are pit-falls for the noobie. A 1.8 TURBO is a very big job
    The feeling of immortality extends right up until the moment of impact.
    I cannot teach you how to be a Zen mechanic, grasshopper.
    The VW Scirocco, the worlds fastest ECONOMY car.
  3. 10-04-2012 06:00 PM #3
    Yes I do have the skills for the job I just need to know what to do
  4. Member 8716vrocco's Avatar
    Feb 12th, 2001
    Chitown
    86 Scirocco 16v, 90 Celica GT, 05 Honda VTX1800F
    10-05-2012 08:41 AM #4
    NLS makes mounts, Techtonics makes a swap downpipe. Those alone will help out plenty. The rest is pretty much on you. The gli is drive by wire so you'll have to fab the pedal into your car, you'll need to make a choice on what trans to use too. I'm sure the immobilizer will have to dealt with as well. Search plenty before you start into the swap.
    Project 16v Lysholm
    "I hope you go commando, otherwise your panties would always be in a bunch"
  5. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    10-05-2012 11:07 AM #5
    Amongst others....Rocco Julie has done what you are proposing.
  6. 10-08-2012 01:36 PM #6
    I looked for her username but I didn't find it
  7. Member GoKraut's Avatar
    Mar 28th, 2005
    North Bend, WA
    10-09-2012 06:12 PM #7
    ABA 20vT or go home
    www.GoKraut.com
    "I didn't break it, I just adjusted it out of spec!"
  8. 10-09-2012 09:07 PM #8
    I built this motor from the pan to the crank to the rods and pistons to the valves retainers valve springs all the details on the motor and trams are taken care of this monster smokes brand new Porsches and my fathers friends 360 Modena
  9. Member J. Daniel's Avatar
    Dec 3rd, 1999
    Gaithersburg, MD
    10-10-2012 08:41 AM #9
    Awesome!
    Since you've done all that and have the skills for the swap then you should also have the knowledge to know what needs to be done to complete the swap.
    Carry on.....
  10. Member J. Daniel's Avatar
    Dec 3rd, 1999
    Gaithersburg, MD
    10-10-2012 08:43 AM #10
    BTW, Rocco_julie runs a 16V turbo unless I'm mistaken.
  11. Member 85roccoZ400's Avatar
    Jan 27th, 2002
    Litchfield County, CT
    85 Scirocco 8VT; 2002 VR6 Jetta; 2005 C230 Sport
    10-10-2012 08:53 AM #11
    Quote Originally Posted by J. Daniel View Post
    Awesome!
    Carry on.....
    "Everything is possible to the man who does not have to do it for himself"
  12. Member 20vRocc's Avatar
    Mar 19th, 2006
    1987 20v scirocco e30
    10-10-2012 10:01 AM #12
    pretty simple swap. i went aeb with mine instead of making mounts, but now NLS makes the mounts. but its not to bad to do. no sure on wiring differences between the aeb and the newer 1.8t's but mine was simple.
    Quote Originally Posted by saddest6day66 View Post
    Anymore most of them are just mk3-6 kids that want to be "old school" and got a mk2...
  13. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    10-12-2012 10:59 PM #13
    Deal with it.
