Results 1 to 7 of 7
Thread: 98 vw jetta wont shut off! help!
  1. 10-04-2012 04:39 PM #1
    I have a 98 Jetta wolfsburg. Last night my alarm went off so.I went. Outside and my radio was on and my dash was lit up. I started the car and it wouldn't shut off unless I stalled it out. And the dash lights and radio stay on until I unhooked the battery. I changed the ignition switch this morning and no difference. Any help would be greatly appreciated.
  2. 10-05-2012 07:49 AM #2
    Cmon guys
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    10-05-2012 08:38 AM #3
    Sticky load reduction relay maybe? Don't think that would keep the fuel pump relay energized though.
    Time to break out the wiring diagrams and start checking, start with the ignition switch harness. Something's shorted somewhere.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  4. 10-05-2012 11:14 AM #4
    i know in the more simple times, a bad diode in the alternator would feedback the coil and keep the engine running. Obviously this wouldn't keep the dash lights on. You sure there's not a malfunctioning remote-start system installed? those cheap ones always seem to get weird after a few years.
    Mar 6th, 2002
    1998 GTI 2.0
    10-05-2012 08:55 PM #5
    Bad remote start is a possibility as well. I was assuming the car was all stock...is it?
    I should not ASSuME.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
    Feb 2nd, 2010
    mA
    95 VW GOLF GL 170k, 1996 GTI 2.0
    10-07-2012 11:28 AM #6
    maybe the ignition switch is stuck on.
  7. 10-09-2012 11:13 AM #7
    There is no remote starter. The car is bone stock. I replaced the ignition switch right after the problem arised so that's not it either. Someone said it could be the factory alarm module gone bad. I changed the start relay too #175
