Results 1 to 4 of 4
Thread: coolant wont stay in engine!
    Nov 16th, 2010
    Lancaster, pa
    91 Gli MK II, 83 MKI Rabbit
    10-04-2012 04:48 PM #1
    Installed new billet 42DD crack pipe and it leaks like a sive on the lower side is there suppose to be some sealeant im suppose to put around it?
    Quote Originally Posted by VegasJetta View Post
    Nitrous is like a smokin hot chick with AIDS and Herpes. You REALLY wanna hit it, but are afraid of the consequences...
  2. Member ajhvw93's Avatar
    Oct 26th, 2009
    PA
    80 Rabbit Diesel....87 16V Scirocco...87 8v Gti..93 vr6 Corrado
    10-04-2012 06:40 PM #2
    Quote Originally Posted by Greensteeldragon View Post
    Do a search this has happend b4 but I think it may have been wrong o ring size for one of the billet crack pipe manufacturers. One manufacturer was diff from the rest as far as o ring usuage....i think??
    Walldoctor
    These cars are like women. You always have to make them happy... Other wise it will tend to f....k u in the bad way.
  3. Member JeremiahSOW's Avatar
    Apr 9th, 2007
    cape coral,FL/Leominster,MA
    02 jetta 01 jetta wagon VR6
    10-06-2012 03:52 PM #3
    Did you clean the block where the crack pipe slides into the opening? Also use a tiny bit of engine assembly lube(comes in a tube) on the o-ring before sliding it into the block. You probably pinched the o-ring.
    Take some sand paper to knock down any scaling on the block before installing the crack pipe. That'll also help you get a nice tight fit and stop the o-ring from getting pinched.
    slumz of worcester
    dub militia
  4. Member kennybo's Avatar
    May 31st, 2004
    Huntersville, NC
    2000 GTI VR6, 1997 GTI VR6, 1995 Jetta 2.0
    10-11-2012 09:58 AM #4
    It never hurts to brush-on a little sealant on the end of the crack pipe/over the o-ring before install to ensure a sealed fit:
    http://www.permatex.com/products/Aut..._Sealant_a.htm
