Guys Guys chill...
Today i just unplugged mu N75 and it just got me 5psi tops
Im saying the problem should be the N75 Valve not working correctly... ill get a borrowed N75 to check if it is solved... if it is i may be up for the Race N75 ECS offers
Ill keep you posted i guess?
-2011 MK4.5 1.8T VW Motorsport GLI R Proyect. Codename ".:Rolling Thunder"
-"The ammount of Love, Money and HorsePower We Can Have Is Never Enough" -Sensei Mawy Luna
04 225QC Black/F23/IE Rods/Gonzo StageIII/E85/Bosch EV14 750cc/LiquidTT/Podi/AEM dry flow/Forge WG/MadMAxDV/Forge hoses/Treadstone TR8/42 Catch can/42 DP/Magnaflow Cat back/Eibach coilovers/Neuspeed RSB /KMAC/Defcons & poly/25mm & 17mm/RS4 Reps/ Brembo Calipers/ Zimmerman rotors/Hawk pads/Braided lines/B&M shifter/Votex body/Suede/Carbon/shaved..
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
I dont know if that is... i dont think it is,
But what about my tune? Its Sedox Stage 2 Software... wouldnt another OEM n75 just go bad again in 3 months?
#11
#12
#13
#14
#15
Sounds like you're having a wastegate actuator issue. Check the nuts and rodyou may have to adjust the nuts a little
Seriously though, check them.![]()
PROTECTED BY SMITH & WESSON
MAESTRO - 3"MAF - IE Rifle Drilled Rods - 550cc Bosch EV14 Injectors - Gonzo Tuning GTT K04 Hybrid Turbo - Devils Own Water Meth - Walbro 255 inline - Eurosport FMIC - Peloquin LSD - Madmax wastegate mod - Werk in Progress INTEGRATED ENGINEERING
#16
#17
Yes, the nut could be loose.
if they aren't try tightening them down a little (cranking it) a couple threads and see how she reacts. If the actuator is on its way out you may have to crank it dow every once in a while until you run out of threads... then need a new actuator, or turbo for the price.
