VWVortex.com - Will I Ever Be Able To Go Back To a "Normal" Naturally Aspirated Engine?
    The Car Lounge
    Page 5 of 8 FirstFirst 12345678 LastLast
    Results 101 to 125 of 199
    Thread: Will I Ever Be Able To Go Back To a "Normal" Naturally Aspirated Engine?
    1. Member NOTORIOUS VR's Avatar
      Sep 24th, 2002
      Toronto
      D3 A8 4.2 - E36 Turbo
      10-05-2012 11:45 AM #101
      Quote Originally Posted by MFactor View Post
      I did. Had a 300whp WRX and had an S2000 after. At the End of the day, I found the S2000 to be the most enjoyable. I think James May said it best web he stated that the most fun you will have in a car is when you're pushing it to its limits. You will rarely find yourself pushing your high powered car to its limits simply because you will most likely run out of road. It's not all about power. It's about everything that makes a car enjoyable and have all of that work cohesively. I have to say that some people are all about power and speed. I respect that but for me, I'll take a slower but more enjoyable car than one with gobs of power any day.
      I don't get this logic at all. You're saying the slower car will be more enjoyable. I'm sorry but slow cars for me are well, boring AND slow.
      It is all about power to a point, and going from a decently quick car to a fairly slow car is working backwards IMO.
      If you have a decently quick car or a fast car, you need to do what you need to it to make it fun for you in all situations. You saying you will run out of road with a fast car, well I say you're not driving it right or to it's potential then because basically you're saying anything faster then a S2k (which are balls slow) is too fast for the road. That's just crazy talk
      SCHNELL ENGINEERING · BLOG · STANDALONE ECUS · TUNING · DYNO · WIRING · PARTS · VEMS
    2. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      10-05-2012 11:49 AM #102
      Quote Originally Posted by NOTORIOUS VR View Post
      I agree. I never find 700whp to be "not fun" when driving on the roads.
      Especially when there is no waiting period for turbos, because there is a positive displacement blower providing boost off idle.
    3. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      Perpetually Searching For the Next Car . . .
      10-05-2012 11:49 AM #103
      Quote Originally Posted by Dandbest View Post
      I answered the question the OP asked, but I'll reiterate- in a nutshell, you need a V8.
      Btw, the graph you posted is for a car with no cats and running 100 octane...yep, because we all run 100 octane on our daily drivers, every day. Totally realistic. And yeah, 500 ft/lbs torque is totally realistic on a stock turbo N55...daily driven as per the OP...
      Actually, asshat, I do run either 100 octane or a 45% E85 mix most of the time, even for daily driving. I am running catless, and I also occassionally run meth-injection (although I have it disable now for the E85 fueling wires).
      A car with the exact same mods as mine regularly generates 360-375 whp and 425+ lb-ft of torque. Do I have a dyno of my specific car? I do not. I can show you dozens of cars with the same mods, but you don't seem to care.
      400hp/500lb-ft is a more than realistic and fair guesstimate of the power my car is making. That isn't even the point of this thread. I don't understand all of the negativity
    4. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      10-05-2012 11:51 AM #104
      Quote Originally Posted by SchnellFowVay View Post
      Your car is not making 400hp/500lb-ft. Your engine is.
      Your car is putting 360-375whp/425lb-ft to the ground. THAT IS ALL THAT MATTERS.
    5. Member NOTORIOUS VR's Avatar
      Sep 24th, 2002
      Toronto
      10-05-2012 11:54 AM #105
      Quote Originally Posted by SVTDanny View Post
      Exactly... and while we can all argue what is the best way to deliver the power (N/A, S/C, Turbo), in the end slow cars are slow. Why on earth would I drive a slow car with a capable chassis over the same car with more power and the accompanying upgrades? I can't fathom who would really thing it would be less enjoyable.
    6. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      10-05-2012 11:54 AM #106
      Bwahahahahaha. Give me a break.
      Is it really worth arguing over semantics like this? The industry standard on cars is to quote crank hp. If this thread was legitimately about trying to specify the output of my car, you might have a point. I was just throwing out some estimates. You guys get so huffy about this stuff.
      Aug 20th, 2012
      Orange County, CA
      2015 Mustang Ecoboost, 2011 EX35
      10-05-2012 11:55 AM #107
      I think his point was that it's more fun to driver a slower car fast than it is to drive a faster car slow.
      To many people, it is more "fun" to be able to go flat-out in something like a Miata or GTI, and really use all of the power and grip available, than it is to drive something like a M6 on the same road, where you might only be able to use 40% of the throttle, and would never even approach the limits of grip without ending up in jail or a ditch.
      Yeah, my GTO was fast and that was fun on open roads and long sweepers, but it wasn't very fun to drive on narrower, more winding roads becuase you there is no room for the car to be pushed. My GTI has literally 1/2 the power and is much, much slower, but on a twisty, low-speed road, it's going to be more fun to drive becuase the limits of the car are lower, so I can really wring it out and get closer to the limits of the car.
      That's probably why the most "fun" cars I have ever driven were a 116hp n/a miata that I could literally redline every gear save 5th in and not break a speed limit, and a base porsche 944 that was slower than a modern 4-cyl camry. Not fast, but very fun!
    8. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      10-05-2012 11:55 AM #108
      For factory stock cars that have had engine dyno after engine dyno performed, sure.
    9. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      10-05-2012 11:58 AM #109
      Except that even factory numbers aren't all that accurate. Numerous companies severly underrate their cars for marketing reasons (see: BMW), and some companies overrate (see: Mazda).
      At the end of the day I agree that whp is the most accurate way to measure power output if you are trying to compare cars. But who gives a crap?
    10. Member Rav_VW's Avatar
      Apr 1st, 2005
      Philly Burbs
      135i, Z4si, A6
      10-05-2012 11:59 AM #110
      I daily drive a tuned N54, and I previously had a 1.8T. I just love the powerband and tuneability that turbo engines give you, and that rush of torque especially at low RPMs.
      But still, in certain situations I do miss the throttle response and smoothness of a well designed NA engine. The N52 in the Z4 I co-own is super responsive and revs so smoothly. Sure it is down 150HP and 200ft/lbs on my 135, but on super tight back roads and in a lighter car it works very well. Daily driving and on more normal streets I like the 135 better though.
    11. Member
      Aug 20th, 2012
      Orange County, CA
      10-05-2012 12:10 PM #111
      Quote Originally Posted by Rav_VW View Post
      I really wish BMW would have put the 255hp N52 in the 1-series. Call it the 130i or something.
    12. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      Current: Audi S4, B9 Allroad, Porsche Boxster S, Ford F-150 FX4 4x4
      10-05-2012 01:00 PM #112
      [IMG]http:/img.photobucket.com/albums/v294/heyheyhey3/shomegrown/309_1033317388182_1082820280_120506_433_n.jpg[/IMG]
      So you actually do search for pictures of me and store them on your hard drive.
      Seek help brah. That's creepy. Just like when you emailed Ann Arbor's police department on my behalf.
    13. Member
      May 14th, 2009
      DBP 08 .:R32
      10-05-2012 01:07 PM #113
      When you are talking modded vehicles, wheel horsepower is the standard.
      When you are talking stock vehicles, crank horsepower is the standard.
      This isn't arguable. If a shop out there engine dynos each one they build, that is a different story. I guess all those 1,000 whp GTR and Supra guys just got a free dick enlargement pill to the tune of 200 hp inflation when they are talking about their cars.
      Awesome, my talon has 530hp now instead of 463!
      08 DBP .:R32
      92 Eagle Talon TSi
    14. Member zhenya00's Avatar
      Aug 7th, 2003
      Ithaca, NY
      10-05-2012 01:10 PM #114
      My position is that it is much harder to learn to become a really good driver with a very powerful car. Power makes up for so many mistakes that it is difficult to really know what you are doing wrong. It robs you of the subtleties that make you a better driver. It's no accident that rookie race drivers don't start with F1 levels of power.
      1987 Mercedes 190E 16v Cosworth
      1997 Volvo 855 T5
      1998 Volvo V70 AWD
      2010 Volvo XC90
    15. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      10-05-2012 01:16 PM #115
      Quote Originally Posted by Shomegrown View Post
      I would hotlink directly from the source, but then if you close it off it will only show a red X and the lol's will be lost forever.
      Emailing police? I think you have me confused for your other creepy stalker. Sorry.
    16. Junior Member
      Jun 27th, 2001
      Miami
      2013 BMW E92 M3
      10-05-2012 01:21 PM #116
      Try one of theese
    17. Member NOTORIOUS VR's Avatar
      Sep 24th, 2002
      Toronto
      10-05-2012 01:26 PM #117
      Quote Originally Posted by rynodyno312 View Post
      In which I respectfully disagree. Slow cars are boring, because they're slow.
      Quote Originally Posted by zhenya00 View Post
      So the lesson here is not to drive slower cars faster, or drive faster cars slower. But to learn how to drive period.
      That I can't speak for. Maybe the people that are advocating slower cars just aren't good drivers. But saying slow cars are more then then fast cars just doesn't make any sense.
    18. Member Shomegrown's Avatar
      Feb 26th, 2002
      Detroit
      10-05-2012 01:28 PM #118
      Grow up and move on.
    19. Member MonsterM's Avatar
      Aug 9th, 2005
      Never enough boost.
      10-05-2012 01:29 PM #119
      What is "slow" in your "book"? Is the S2000 slow? I would have a LOT more fun in a S2000 than a modified 335i anyday. I would also take E36 M3 over 335 as well.
    20. Member MonsterM's Avatar
      Aug 9th, 2005
      Never enough boost.
      10-05-2012 01:31 PM #120
      AA tune will bring it up to 245 hp. You will need a three stage manifold to bring it up to 260 hp or so. BMW should have offered the euro version with DI, which makes around 267 hp if I am not mistaken. It should be standard in the 1 and optional in the 3.
    21. Member
      Aug 20th, 2012
      Orange County, CA
      10-05-2012 01:31 PM #121
      So puttering around a parking lot in a Z06 is more fun than thrashing a Miata around the backroads?
      To each his own.
    22. Member zhenya00's Avatar
      Aug 7th, 2003
      Ithaca, NY
      10-05-2012 01:32 PM #122
      That's not the lesson at all. I'm sorry you don't get it.
      1997 Volvo 855 T5
      1998 Volvo V70 AWD
      2010 Volvo XC90
    23. Member
      Aug 20th, 2012
      Orange County, CA
      10-05-2012 01:32 PM #123
      Quote Originally Posted by MonsterM View Post
      Noted.
    24. Banned justanotherusername's Avatar
      May 26th, 2007
      Palm Beach, FL
      '08 135i, '00 4runner, '85 Huntsman (Toyota) RV
      10-05-2012 01:33 PM #124
      To each his own.
      No, thrashing a Z06 on backroads is more fun than thrashing a Miata on backroads. Unless you're restricted to a parking lot....why even ask that question?
    25. Member
      Aug 20th, 2012
      Orange County, CA
      10-05-2012 01:35 PM #125
      Quote Originally Posted by justanotherusername View Post
      You are missing the point.
